Does this prong insert (RPA-AB01B-H): https://www.digikey.com/short/qqtmt8w5
work with this power supply body (PSAC12R-120)?: https://www.digikey.com/short/qd3n4qch
Thank you.
Thank you.
Hello MichaelG,
Yes, the 993-RPA-AB01B-H-ND plug will work with the 993-1359-ND power supply. I found this Datasheet on the manufacturer’s website that says they will work together.
Thank you.
I tried to download the datasheet on the PSAC12R page, but the link was bad.
Thanks again!
You’re welcome MichaelG.
Come back again, anytime.
