Phototransistor equivalent
Hi everyone, I need to replace a TLP504A 8-pin phototransistor that is no longer in production. Can you help me find an equivalent? Thanks.
Here’s a simpler comparison + a substitute recommendation for the TLP504A. I also noticed a useful project that uses something similar — maybe that helps you confirm form-factor or wiring: Arduino Photogate PCB on PCBWay.
TLP504A is a phototransistor optocoupler (LED input → transistor output), typically in an 8-pin DIP for the 2-channel version, or 16-pin for the 4-channel version (TLP504A-2).
Key specs: collector-emitter voltage ~ 55 V, isolation voltage ~ 2500 Vrms, CTR (current transfer ratio) of at least ~ 50% under certain test conditions.
The PS2505-2 is a strong candidate. Some highlights:
V_CE up to ~ 80 V, high isolation (5000 Vrms in some specs) which gives a margin over the 55 V of TLP504A.
Similar switching speeds, and current transfer ratios in the same ballpark.
Pin-package may differ (depending on channel count), so check if your PCB matches or if you’ll need minor wiring change.
thank you, you were very kind
Unfortunately it is not available on the DigiKey website
Hello @andreug1
The closest part I found that is an active part on our website to TLP504A Phototransistor is part number TLP621-2XGB Isocom Components 2004 LTD | Isolators | DigiKey
