PlayStation dualsense edge
Hi I’m looking for replacement part usb c for dual sense edge the one I took off the controller had these numbers on it 20161. Thanks in advance
Hello Justtooktolong,
Nothing comes up in our system for the 20161 number.
Without pictures, and measurements, I do not know what item may work for you.
Click here for the USB-C connectors that we have available.
You can check the datasheets for pin and support measurements, to help determine compatibility to your application.
Hi here some pics and I measure how wide it is
@Justtooktolong
I found the 670-DX07S016JA3R1500CT-ND
DX07S016JA3R1500 JAE Electronics | Connectors, Interconnects | DigiKey
drawing
Ty I will order that and try it !!!
This worked thank you
