Please help identifying this Ic package SOIC-8
Hello Avjr, and welcome to the DigiKey TechForum.
Unfortunately, I have been unable to find anything based on the markings on this IC.
I’ve been looking everywhere and so far no luck
Thank you
What is this device, name the model?
Can you draw a diagram?
It looks like this chip controls the switching on of the D882 transistors.
What is connected to the connectors installed next to the D822 transistors?
Make a larger photo.
Hi, this is a small blue laser machine, the IC controls the laser and motor.
Thank you
Hi @avjr ,
Would not be surprised if this turns out to be a re-labeled PIC12F683.
Cheers, heke
Thank you so much! It definitely looks like it is by the IC pdf
