Greetings.
I am looking for an explanation of the linearity tolerance.
What I think it means is that at any point in the potentiometer’s travel, the deviation from the theoretical linear value could be +/- x% depending on the tolerance.
Like a scatter plot around a linear trendline bounded by the tolerance.
The linearity tolerance refers to the allowable curve in the linear line from the bottom to the top of your resistance range. The Resistance tolerance would have to do with the overall value of that range.
It’s actually a bit more complicated for most precision potentiometers (better than 2%) because there are four different versions of linear conformity. So you’ll need to refer to the official standard for potentiometer specifications and measurements from the Variable Resistive Components Institute (VRCI). http://www.alliantech.com/pdf/technique/norme_potentiometre.pdf
The official standard is very difficult to read and fully understand but fortunately Bourns produced a handbook to explain it all in much easier to understand language. See the sections on conformity and linearity.
