Power supply cable options
------Question for NPORT 5150A-T Please Put your question below------
Do you provide power supply options for this device that plug into C13/C14 outlets?
Hello kyle.peterson,
Wecome to the DigiKey TechForum.
It looks like this will require a 12-48VDC power supply. We can see what we have available with the C13 type input connector, but we need to know the size of the barrel plug, that will plug into this device. There is no information about it, in the datasheet, or the supplier’s website.
Do you have the outside diameter of the plug, along with the inside diameter (center pin diameter)?
