Powering the LattePanda
The LattePanda requires a micro USB power supply that provides 5V and a minimum of 2A.
Here is a list of 5V 2A Wall Adapters that would work with the LattePanda.
The second option that you would have would be to choose a USB wall adapter that would require a USB A to micro USB cable.
Another option that works well for the LattePanda, RaspberryPi, and many other boards that are powered via a microUSB port is Adafruit’s microUSB to DC barrel jack adapter cable 1528-1798-ND when used in conjunction with a standard 5V center positive power supply such as these. This allows easy usage of higher current supplies for more power hungry applications.
1528-1798-ND
