hi i would like to order PQDE6W-Q48-S12-T but they are out of stock can you tell me if you have a suitable alternative?
Thanks
Greetings,
It’s not possible from this side of the screen to know the reasons why the original part was chosen; whether or not any particular alternative would be suitable for your specific needs is a matter that’s ultimately up to you to determine.
The process of finding potential alternatives starts from the product page for the item in question. Use the check boxes to select parameters that you need to match exactly, then click “view similar” to see products in the same family that share these characteristics.
From there, one can select ranges for parameters for which some flexibility exists; you’re probably looking for something that’s of similar power output, which is in stock and has a similar input range.
Applying those filters and sorting by price ascending, there are near the top a number of results that appear to have a very similar form factor, and appear to be slightly higher-power versions of the same/similar product. These options, shown in comparison view here, would be likely options to consider.
