PRE 57079 PWM-DC
I recently purchased a PCB that is supposed to convert Pulse Width Modulation current to straight DC. The item number is PRE 57079, 5 amp Linear Plug & Play Board.
I operate battery powered large scale LGB trains. To control the trains I use a product manufactured by G Scale Graphics. The particular module is their Railboss Plus. The Railboss Plus takes power from a 14.8 Volt Li-On battery pack and through the PCB converts it into PWM.
This system works fine for all but one of my locomotives. This particular locomotive doesn’t like PWM. So I was directed to DigiKey and their PRE 57079 PCB.
On my test bench I powered up the 57079 from my Railboss Plus Module and connected the output terminals to the locomotive. Unfortunately nothing happened. I checked the input voltage with a meter and then checked the output. No reading on the output !
I am attaching a photo of the PRE 57079. The photo shows the jumper required as per the hobby shop owner I purchased everything from.
Well, I’m not sure the photo made it to this posting.
I could not find part number PRE 57079 PCB. Do you have the DigiKey part number?
I thought that was the DigiKey number. I’ll email Gigi-Key again. They directed me to this forum. By the way, did the photo show up of the module ?
You didn’t get that from DigiKey, looking at google:
This looks like it… https://www.revoelectronics.com/product/accessories/linear-p-p-board.html
Regards,
I believe you are correct. I was given the wrong info. Thanks for clarifying. I’ll try to contact them.
