Product have electrical noise
MWA150015A-12A and 800-18-0OD-GR-0006F When used together, the products produce a lot of electrical noise. Is this a problem or is it normal?
Hello Ting, thank you for your inquiry. Have you used other cords with your MWA150015A-12A without experiencing this noise? Is there anything else plugged in on the same circuit?
Any other details you can offer?
I’ll ask about that and get back to you. Thank you so much for your help!
Josh_Lawrence via Engineering and Component Solution Forum - TechForum │ Digi-Key <digikey@discoursemail.com>于2021年2月26日 周五上午10:22写道:
