"Noisy Power" or Bad Power Remedies
Sometimes a power company will send higher voltage, lower voltage (brownouts), noisy voltage, or no voltage at all. Products to remedy bad electrical behaviors are listed below. Please review datasheet specifications prior to purchase.
Click here for Line Conditioners, to regulate incoming voltage and clean up power line noise.
Click here for Power Line Filter Modules, to help clean up noise from power lines.
Click here for Surge Protectors, to help prevent over-voltage damage to equipment. Verify datasheet it has surge/protection feature as some are only outlet strips (without surge or fuse protection).
Click here for Uninterruptible Power Supply UPS Systems, to keep power consistent and on during a brown-out or short term power loss, these usually have additional protection also.
-We carry similar products for signal lines also, regarding isolation, conditioning, and protection.
See Also:
Replacement intervals for lead-acid UPS batteries
Tripp-Lite SMX & OMNIX UPS Tower System Battery Option
