I have a question, please answer it. Can the STM32F030CCT6 microcontroller be programmed without a PCB board?
sikwal
Thank you for contacting DigiKey , the only programmers / debuggers for this are all in circuit from what I am seeing on the manufacturer web site , under Hardware development tools , https://www.st.com/en/microcontrollers-microprocessors/stm32f030cc.html#tools-software
Thanks Craig
Thank you very much, my warm regards to you and sorry if my question is embarrassing to you
If you mean without soldering it to a PCB board, then yes, it’s possible. However, I don’t believe we have any out-of-circuit any programmers to offer you that would work with the F0. An alternative option is to use a programming socket to make the required connections from your ICSP programmer to the MCU. The 2366-PE047X06-ND board from Elprotronic looks promising.
Hi what I mean thank you for asking
Hi I will use it in my project
Hi, thank you for the clarification and thank you for the wonderful and beautiful forum in understanding microcontroller programming and for electronics lovers.
You are very kind, Yassam. You are a sales engineer. I will study and write a topic. A special greeting to you. I thank you for your kindness.
I thank Engineer Sam, he is very nice and if I have a question I will ask him. Thanks for the help.
I will buy the board thank you
Hi what is the name of the program
Does Digikey sell programmers?
Yes, DigiKey sells programmers. We have a category dedicated to Programmers and Debuggers Located Here
Before you go out and buy a programmer however, It should be noted that many microcontrollers have dedicated development boards that often have either built in programmers/debuggers or have something called a bootloader, where code has been uploaded to the microcontroller that allows it to program itself.
Hi I will buy it. I bought the T56 programmer a long time ago. It is at home. Do you know anything about it? Tell me.
DigiKey does not sell that programmer, unfortunately I’m not going to be able to help with that one.
ST-LINK/V2I will buy this
Thank you very much
I buy electronics from all over the world. Best regards.
Special greetings to you I am very happy to know your services are excellent Thank you for the help
I want to order from digikey, but I can’t. Please help.
