Programming led driver
do you guys program PHB30W-0700-42? i need them at 700MA and the factory cut sheet says they are programmed from the factory @ 350MA
Hello matt8 and welcome to the DigiKey TechForum.
I do not see that we offer programming for PHB30W-0700-42, but according to the datasheet PROG-JACK-USB would be what is used to program this power supply.
If it’s any help some of these drivers will do the same thing and don’t need to be programmed.
Thanks for the reply, I have seen the option to buy the programming cable but cant find anything on the process to program said driver. Is there software that needs to be downloaded onto the computer in order to program these drivers?
LED drivers can be a bit confusing when you’re first dealing with programming and configuration options, so having the process laid out clearly helps a lot.
Hi matt8,
I believe the software can be found here: https://www.erp-power.com/led-driver-software/
