Pulse Width Modulation Possibility
------Question for HLG-600H-20AB Please Put your question below------
Is it Possible to input pulsating signals so that i can get LED pulsating. If not can you suggest other drivers for high current outputs to control LED in pulse mode
The datasheet for 1866-HLG-600H-20AB-ND calls out that the suffix AB.
This function is Io and Vo adjustable through built-in potentiometer & 3 in 1 dimming function. (0~10VDC, 10V PWM signal and resistance)
Here is the diagram for wiring the PWM.
