Sir/Madam, I need a replacement dimmerable LED driver for my light fixture.
ESD
ES0256D-E060
120/300ma
Output:34-40
600m
60hz PF 70.9
Thank you for your assistance.
< Personal Contact Information Removed >
ESD
ES0256D-E060
120/300ma
Output:34-40
600m
60hz PF 70.9
Hello Knowles,
thank you for posting on our forum and welcome our community.
These are the options I was able to find so far from the specs you listed.
To clarify, is it . . .
How is it dimmed? Variable resistor, 0-10V, triac, etc.?
Yes, David..
Here’s a short list of drivers which have close to the same max current, will operate over the same input and output voltage ranges, and which have various dimming options. You would need to select one which matches your dimming method.
