becky 100-135vac 50-60hz What product can replace this LED driver? THANKS
We do not have any drivers with 100-135VAC input.
Is there a part number on the driver you are trying to replace?
We do have these that are very close to those specifications, one of them will likely work depending on your application. Please review the datasheets to ensure the alternative will work for your application.
Thank you for your inquiry.
Kindly see the following LED Driver:
This one has dimming, if you leave the dimming wires unwired the driver will be fully on.
