Q & A
Hello, we need help identifying the correct mating connector for the following custom ODU MEDI-SNAP part:
Part number: G91M07-P09LCC0-0000
Description: Custom receptacle with female contacts (Style 9)
We require the matching plug with solder-cup contacts.
I will attach photos of the G91M07-P09LCC0-0000 connector for reference.
Could you please provide:
  1. The exact mating plug part number, and
  2. One sample unit so we can verify fitment?
Thank you.
Odu lists the mating products for this on their site.
Depending upon what kind of cable diameter you’re working with here are some of the gray options:
S11M07-P09MCC0-3970
S11M07-P09MCC0-5270
To inquire for if samples are an option, you can contact our Sales department at 1-800-344-4539 or Orders@DigiKey.com
Thank you for your reply. We are using 28 AWG wires for this connection.
Could you please confirm that this is still the correct mating plug for part G91M07-P09LCC0-0000, and that its solder-cup contacts are suitable for 28 AWG wire?
The drawing indicates they are compatible with 28awg wire.
ODU’s website confirms these are some of the recommended mating connectors for the part number you provided.
