For the MachineKit builds on the BBB, would I need to use the Docker container system to update/upgrade or can I use the build for the BBB as is?
I found this online: http://www.machinekit.io/docs/developing/machinekit-developing/ .
I know you may not know everything about this subject but any ideas would be helpful.
For instance:
First:
I installed the image via etcher on the BBB.
Second:
I went into the image via HDMI to DVI-D via the debian distro.
Third:
I found some GUI applications and I tried to enter in some info. to test.
After not being able to completely enter in the correct info, I was routed, by my own doing, to MachineKit.io docs.
I found the Docker ideas and .deb file ideas. Is this side of MachineKit already done for the BBB or should I need to install and upgrade specific components from: https://cloudsmith.io/~machinekit/repos/machinekit/packages/ ?
Seth
