I could use some help identifying this rectangular connector. I don’t see the “1.1mm” pitch as an option in DigiKey’s rectangular connectors, so that adds to the confusion.
This connector has:
- 8 blade-style pins
- 1.1mm pitch (measured by digital calipers as 8.8mm across all 8 pins. A photo with a ruler is attached here.)
- through-hole vertical mounting
- the color is ivory, or some similar off-white color
- the outside dimensions of the shrouding are ~11.75mm x ~3.15mm
Thanks!
Hello Chris,
Thank you for contacting the Technical Forum. I tried multiple searches and was not able to find this one either. Unfortunately it does not appear we sell this one.
Hello Chris. Welcome to the Digi-Key Technical Forum!
I have reviewed the information and images you have provided. I think this connector from TE Connectivity looks like the correct item.
A99920-ND
1734598-8
TE Connectivity AMP Connectors
CONN HEADER VERT 8POS 1.25MM
https://www.digikey.com/en/products/detail/te-connectivity-amp-connectors/1734598-8/2074079
More options like this one can be found clicking this link.
I hope this helps!
Wow, such a fast response!
Thanks! I think you’ve got the right one.
For future reference: pin pitch = total pitch / (number of pins - 1), so it’s 8.8 /7 ~= 1.25
It’s the old fence post problem that usually bites me every time.
Thanks, @PaulHutch . I’m not sure what happened to my math there today, but you’re definitely correct.
