I have an application that requires a reed switch to sense a door closing. The door has a neodymium magnet embedded into it and when the door is closed, I want the reed switch to be open (open circuit) and when the door is open, I want the reed switch to be closed (shorted - i.e. closed circuit). I proceeded to purchase two reed switches from Digikey just to make sure:
a SPST NC switch:
and a SPST NO Switch:
I received them today and tested them with my magnet. Unfortunately, both behave as a NO (Normally Open switch). My understanding is that the MK15-B-2-OE/2765323 which is listed as an NC (Normally closed) should be shorted when NO magnet is present. This is the behavior I need for my circuit.
I’m I missing something is my definition of NC and NO incorrect? I took a closeup image of both of them, just to make sure that the parts were inventoried correctly and their marking identify them correctly.
Mark
