Can someone help me identify the chip in the picture and find a replacement? Probably some kind of MOSFET.
Thanks,
Jake
Hello Jake,
Thank you for your inquiry. We are checking into this and will let you know what we find.
@Brock_Olson did you find anything?
No. Did you?
I can’t tell from the picture, but it looks like there are 10 pins to a side there, for 20 total. Can you verify if this is accurate, please? The numbers on the chip packaging don’t bring anything up, so if you could also give info on what this is out of? It may be possible to find some kind of data sheet or schematic with that info, which could possibly give some replacement info.
Hopefully we can find something for you!
