Replacement for AMD Spartan IC
I need help identifying a replacement for an AMD Spartan Xilinx IC with the part number XC6SLX25, FGG484BIV1601, 2C. Have attached a picture of the same. The closest that I can find is XC6SLX25-2FGG484I. However, am not sure whether it will work as a replacement.
Kindly assist.
Yes, both of these parts should work as direct replacement:
484 FBGA
XC6SLX25-2FGG484I with -40°C to +100°C (TJ) Industrial Temperature Range
C6SLX25-2FGG484C with reduced -40°C to +85°C Consumer Temperature grade maximum specification for the Junction
Thank you very much
you’re very welcome – we’re here to support you … :wink:
