Replacement for PVD11-C030V33-UNV3-HE-P
This post is for informational purposes only. Please review the manufacturer’s datasheet to verify that any recommended product is suitable for your application.
PVD11-C030V33-UNV3-HE-P is an adjustable constant current LED Driver that was originally manufactured by EPT (Electronic Power Technology Co, Ltd). The full specifications can be found here: PVDXX-CyyyVzz-UNV3-HE-P Datasheet
The “C030V33” in the part number calls out a max current of 300mA and an output voltage of 33VDC, which makes it a non-standard item, based on their datasheet. In searching for a good replacement option, 1800-1090-ND from ERP Power came up. It is not a direct cross for the original, so please compare the specifications before purchasing, but it is a reasonable alternate based on my review.
This part is in stock but no longer manufactured, so once current stock is depleted you will have to switch over to part number 1800-ESS015W-0500-42-ND, the manufacturer’s recommended replacement.
