Replacement for Sola 30S24-DN
Hi Do you have a recommendation for the replacement of the Sola power supply 30S24-DN?
fisichel
Take a look at the link below for 2 possible options , check data sheets to see if these will work for you .
Thanks Craig
Here are some additional options which meet the basic specs of the 30S24-DN. Depending on what your specific requirements are, some of these may work as well.
Thank you, all I am looking at the Traco Power TMP 30124C. It turns out that power supply is not really a DIN mount power supply.
fisichel
Here are some chasis mount options , AC DC Converters | Electronic Components Distributor DigiKey
Thanks Craig
