Suggested replacement for 1145-1140-ND
This Digikey part number is now low stock and says not recommended for new designs.
suggested replacement for 1145-1140-ND
Is there a recommended
replacement Delta power supply for this one?
2967-FSP090-ABBU3-ND is 1 option or these other parts that use other input cable https://www.digikey.com/en/products/filter/ac-dc-desktop-wall-adapters/130?s=N4IgjCBcoCwBxVAYygMwIYBsDOBTANCAPZQDa4YAnAOxjUgC6hADgC5QgDKrATgJYA7AOYgAvoQCs9aCBSQMOAsTIgAzGDhgYABhCF1mmKsYt2kLr0Ejx4AEzTkaLHkIlI5W5TgA2OMaYgbBzc-MJihFRwlIiyToquKroMNrYaDrHyzkpu5N7aAAQA6nog3mBFJd4SFYTUBcUBQeYAqgJ8rADyqACyuOjYAK48uGKiokA
2967-FSP090-ABBU3-ND is the closest we currently have in stock, however the closest matching option we have available is TR9LZ3420LRPCIMR6B GlobTek, Inc. | Power Supplies - External/Internal (Off-Board) | DigiKey
If you are willing to use a straight barrel plug rather than a right angle, and an IEC 320-C14 rather than IEC 320-C6 input then we have this one in stock that matches most of the other specifications of the original. VEC65US19 XP Power | Power Supplies - External/Internal (Off-Board) | DigiKey
Please review the datasheets to ensure they will work for your application.
