Request for Confirmation of Packaging Type
------Question for UPC277G2(20)-E2-A Please Put your question below------
UPC277G2(20)-E2-A
2337pcs
Could you please confirm whether the product mentioned above is supplied on a reel? If not, could you advise on the available packaging options?
Thank you for your assistance.
Hi @megumi.furuhashi
Welcome to the community!
For part UPC277G2(20)-E2-A, if you order 2,500 pieces, they will be delivered in the manufacturer’s standard packaging: Tape and Reel.
For quantities less than this, the parts will be supplied in Cut Tape (CT) or Digi-Reel packaging.
Please chcek the details about packig from product page
Cut Tape (CT) :Cut tape is a length of tape, cut from a reel (described above), containing exactly the number of parts ordered. Cut tape does not contain a leader or trailer, rendering it unsuitable for many automated assembly machines. The piece(s) of tape are then packaged according to the ESD (ElectroStatic Discharge) and MSL (Moisture Sensitivity Level) protection requirements determined by the manufacturer.
What is a Digi-Reel ? A Digi-Reel® is a custom set of uninterrupted belt section on reel made by a manufacturer’s roller. At the beginning and at the end, 18-inch pieces of bench are mounted so that the pinion holes are aligned, allowing for direct and flawless feeding into automated board-mounting equipment. Thereafter, the entire tape is rewound onto a plastic reel in accordance with the industry standards of the Electronics Industries Alliance (EIA). There is no minimum order quantity, so whether you need a single component or a thousand components; we can provide the appropriate digi-reel.
Hi @megumi.furuhashi ,
Welcome to DIgiKey TechForum and thanks for your inquiry.
The MFG original packaging quantity was 2500pcs per reel. Therefore, 2337pcs should be packaged in the cut tape or Digi-reel packaging.
For more details about the Cut-Tape and Digi-Reel:
