Request for recommended stencil design for TDK TPX322690MT-7017C1
Hello DigiKey TechForum Team,
I am currently designing a PCB using the TDK part number TPX322690MT-7017C1.
I have reviewed the public datasheet, but it only provides the recommended PCB land pattern. I could not find the recommended solder paste stencil design.
Could you please help me obtain the following information from TDK?
  • Recommended stencil thickness
  • Recommended solder paste aperture dimensions
  • Whether the stencil aperture should be 1:1 with the PCB land pattern
  • Recommended aperture reduction ratio, if required
  • Recommended solder mask opening
  • Full delivery specification, mounting guideline, or SMT assembly document for this part
If this information is not publicly available, could you please escalate the request to the TDK FAE or product engineering team?
Part number: TPX322690MT-7017C1
Manufacturer: TDK Corporation
Thank you for your support.
Hello @nguyenvananhhieu2002
I need your DigiKey order details so that I can contact the manufacturer regarding this. If you have the order information available, please share.
Alternatively, you may contact the manufacturer directly using the following link. Contact Us | TDK
