What is the DigiKey part number for Omron Relay Isolation Plate
P2RV-P3.1ST P2RV8201H OMRON Accessory for G2RV-ST/G3RV-ST, Insulation Plate, 3 mm width
We do not carry part number P2RV-P3.1ST.
We do not carry part number P2RV8201H.
We do not carry part number G2RV-ST/G3RV-ST.
any alternative option available for this in DigiKey?
Unfortunately we do not have alternatives for these.
Hi arshad,
We do not currently carry the P2RV-P3.1ST isolation plate.
If you can tolerate a wider separation, we do stock the following:
A couple of other alternatives to add spacing are the following:
Both of these Phoenix options are only 2.2mm wide, so 2 would be required to be at least as wide as the 3.1mm P2RV-P3.1ST.
