Hello everyone,
I’m looking for an rotary encodre similiar in size to : https://www.digikey.ca/en/products/detail/bourns-inc/PEC12R-4030F-S0024/6153385
The rotary encoder should have a switch and a spring to return to center, and another rotary encoder with a switch .
Can you help me out, so many different rotary encoder, I’m at a lost here.
Thank you very much for your help.
Simon
Hello @pesantsi,
Thank you for contacting us on our TechForum. I wasn’t able to search for a rotary encoder by its size, or if it had a spring to return to center option. I did find some similar encoders and you will have to check the datasheets and specifications to determine which one will work for you.
https://www.digikey.com/en/products/filter/encoders/507?s=N4IgjCBcoGwJxVAYygMwIYBsDOBTANCAPZQDaIAzABwCsADAOx0gC6hADgC5QgDKnAJwCWAOwDmIAL6EATDSqIQKSBhwFiZSlQAsOmaw7dIfQaInTKcCouWq8hEpHIV5NMAjYguPfsPFTCKjgYGzQsew0ncBBCbRkKChkPQx9Tf0kMoA
Hello @Brock_Olson,
Thanks for the help, I will look into it.
