Understanding Rotary Encoders: Key Types, Technologies, and Use Cases
Introduction:
A rotary encoder is an electromechanical device that attaches to a motor/shaft assembly in order to accurately report the position, speed and acceleration of the rotary shaft. It converts the angular position or rotational position of an object to analog or digital output signals.
They are widely used in automation, robotics, industrial machines, and other applications where precise motion control is required.
Types of Rotary Encoders:
Encoders can be divided into two basic types: incremental and absolute encoders.
whereas depending upon the sensing technology rotary encoders are divided into categories like magnetic, optical, laser and capacitive.
Based on operating principle:
1. Incremental Rotary Encoder:
Incremental rotary encoders, determine position information by calculating the changes in the rotating component of the assembly. They immediately report changes in position, which is an essential capability in some applications. However, it does not report or keep track of the device’s absolute position.
The key feature of an incremental encoder is that it shows changes in angle, not the exact position. That is, when an incremental encoder is turned on, it doesn’t know its starting position. It needs a reference point to start measuring from before it can tell you the angle.
Advantages:
They are generally simpler and less costly.
Application:
Incremental rotary encoders are suitable for applications requiring basic position feedback at a lower cost, such as ordinary industrial machinery, consumer electronics, and motion control systems.
Incremental Rotary Encoders from Digikey
Applicable Part Numbers
DigiKey Part Number Manufacturer Part Number
PEC11R-4220K-S0024-ND PEC11R-4220K-S0024
102-3992-ND ACZ11BR2E-20FD1-20CZ-0546
102-1307-ND AMT102-V
102-1308-ND AMT103-V
2223-AMT10E3-V-ND AMT10E3-V
102-6644-ND AMT132S-V
987-EN10VT1224N3HH2-ND EN10VT1224N3HH2
PEC12R-4215F-S0024-ND PEC12R-4215F-S0024
PEC12R-4030F-S0024-ND PEC12R-4030F-S0024
PEC12R-4115F-S0012-ND PEC12R-4115F-S0012
118-PEC12R-4015F-S0024-ND PEC12R-4015F-S0024
PEC12R-3217F-S0024-ND PEC12R-3217F-S0024
4809-EC12E24204A2-ND EC12E24204A2
4809-EC12E24204A8-ND EC12E24204A8
4809-EC12E24204A9-ND EC12E24204A9
102-1760-ND ACZ11BR1E-20FD1-12C
118-PER281-P115-N0015-ND PER281-P115-N0015
4809-EC12E2440301-ND EC12E2440301
118-PER231-P19-N0010-ND PER231-P19-N0010
102-1759-ND ACZ11BR1E-15FD1-12C
102-1768-ND ACZ11BR1E-20FD1-20C
102-1752-ND ACZ11BR1E-20FA1-20C
4809-EC11E15244G1-ND EC11E15244G1
4809-EC11E18244A5-ND EC11E18244A5
102-1764-ND ACZ11BR1E-20KQD1-20C
102-1785-ND ACZ16NBR1E-15FD1-24C
118-PER561-P115-N0015-ND PER561-P115-N0015
102-AMT103-2048-N4000-S-ND AMT103-2048-N4000-S
102-6645-ND AMT132Q-V
2223-AMT13A2Q-V-ND AMT13A2Q-V
102-3367-ND AMT313Q-V
102-1786-ND ACZ16NBR1E-20FD1-24C
102-1751-ND ACZ11BR1E-15FA1-20C
102-1753-ND ACZ11BR4E-15FA1-20C
102-1758-ND ACZ11BR4E-20KQD1-12C
102-1739-ND ACZ11BR1E-15KQA1-12C
102-1763-ND ACZ11BR1E-15KQD1-20C
2223-AMT13A2S-V-ND AMT13A2S-V
2223-AMT13A3Q-V-ND AMT13A3Q-V
2223-AMT13A3S-V-ND AMT13A3S-V
102-1780-ND ACZ16NBR1E-20KQD1-12C
102-1783-ND ACZ16NBR1E-15KQD1-24C
4809-EC12D1524403-ND EC12D1524403
4809-EC12D1564402-ND EC12D1564402
4809-EC12E1220407-ND EC12E1220407
4809-EC12D1524406-ND EC12D1524406
4809-EC12D1564404-ND EC12D1564404
4809-EC12E1240406-ND EC12E1240406
4809-EC12E24204A7-ND EC12E24204A7
4809-EC12E1220405-ND EC12E1220405
4809-EC12E24404A6-ND EC12E24404A6
4809-EC12E2430404-ND EC12E2430404
4809-EC12E1240405-ND EC12E1240405
4809-EC12E24404A8-ND EC12E24404A8
4809-EC12E1220406-ND EC12E1220406
4809-EC12E2430401-ND EC12E2430401
4809-EC12E24104A6-ND EC12E24104A6
2266-ACZ11BR1E-15FA1-12C-ND,102-1743-ND ACZ11BR1E-15FA1-12C
2223-RIC11-22S13D5S-TH-ND RIC11-22S13D5S-TH
2223-RIC11-31S10K3-GSMT-ND RIC11-31S10K3-GSMT
2223-RIC11-31S15.5D7-TH-ND RIC11-31S15.5D7-TH
2223-RIC11-31S10K2-GSMT-ND RIC11-31S10K2-GSMT
2223-RIC11-22S11K5S-USMT-ND RIC11-22S11K5S-USMT
2223-RIC11-31S15D7-TH-ND RIC11-31S15D7-TH
2223-RIC11-22S15D7-TH-ND RIC11-22S15D7-TH
2223-RIC11-31S17D7-USMT-ND RIC11-31S17D7-USMT
2223-RIC11-22S10D5S-TH-ND RIC11-22S10D5S-TH
2223-RIC11-31S15K7-TH-ND RIC11-31S15K7-TH
2223-RIC11-31S15D7-GSMT-ND RIC11-31S15D7-GSMT
4809-EC12E1240301-ND EC12E1240301
4809-EC12E1220301-ND EC12E1220301
4809-EC12E2420301-ND EC12E2420301
102-1777-ND ACZ16NBR1E-15FA1-24C
2266-ACZ16NBR1E-15FD1-12C-ND,102-1781-ND ACZ16NBR1E-15FD1-12C
118-PER211-P115-N0009-ND PER211-P115-N0009
4809-EC12E1220813-ND EC12E1220813
4809-EC12E2420803-ND EC12E2420803
4809-EC12E2420802-ND EC12E2420802
4809-EC12E2420801-ND EC12E2420801
4809-EC12E2430804-ND EC12E2430804
4809-EC12E2460802-ND EC12E2460802
4809-EC12E2430803-ND EC12E2430803
118-PER351-P115-N0010-ND PER351-P115-N0010
4809-EC11E09204A4-ND EC11E09204A4
4809-EC11E15204A3-ND EC11E15204A3
4809-EC11E1820402-ND EC11E1820402
4809-EC11E09244BS-ND EC11E09244BS
4809-EC11E09244AQ-ND EC11E09244AQ
4809-EC35AH240403-ND EC35AH240403
4809-EC35AH120401-ND EC35AH120401
4809-EC35AH260403-ND EC35AH260403
4809-EC35AH220403-ND EC35AH220403
118-PER601-P117-N0015-ND PER601-P117-N0015
4809-EC11M1565403-ND EC11M1565403
4809-EC09E1520407-ND EC09E1520407
4809-EC35AH260502-ND EC35AH260502
4809-EC35AH220502-ND EC35AH220502
4809-EC35AH240502-ND EC35AH240502
4809-EC35CH120401-ND EC35CH120401
4809-EC11M1575403-ND EC11M1575403
4809-EC09E1524417-ND EC09E1524417
4809-EC09E1524418-ND EC09E1524418
4809-EC1110120005-ND EC1110120005
4809-EC1110120201-ND EC1110120201
4809-EC111012010H-ND EC111012010H
102-6646-ND AMT133S-V
516-AEDR-9940-102-ND AEDR-9940-102
2266-ACZ16NBR1E-15KQA1-24C-ND,102-1775-ND ACZ16NBR1E-15KQA1-24C
ACZ16BR1E-20KQD1-24C-ND ACZ16BR1E-20KQD1-24C
2266-ACZ09BR2E-15KQA1-20C10P-ND,102-2217-ND ACZ09BR2E-15KQA1-20C10P
4035-E8T-512-197-S-D-D-2-ND E8T-512-197-S-D-D-2
4035-M3K-P-1024-5-250-7-S-2-ND M3K-P-1024-5-250-7-S-2
4035-E16-4000-079-S-D-D-2-ND E16-4000-079-S-D-D-2
4035-E5-400-250-IE-S-D-D-3-ND E5-400-250-IE-S-D-D-3
4035-E3-2048-250-IE-D-D-3-ND E3-2048-250-IE-D-D-3
2371-E40S6-100-3-T-24-ND E40S6-100-3-T-24
2371-E40S6-200-3-T-24-ND E40S6-200-3-T-24
2371-E50S8-600-3-T-24-ND E50S8-600-3-T-24
2371-E50S8-360-3-T-24-ND E50S8-360-3-T-24
2371-E50S8-100-3-T-24-ND E50S8-100-3-T-24
2371-E50S8-250-3-T-24-ND E50S8-250-3-T-24
2371-E40S6-360-3-T-24-ND E40S6-360-3-T-24
2371-E40S6-500-3-T-24-ND E40S6-500-3-T-24
2371-E40S6-1000-3-T-24-ND E40S6-1000-3-T-24
2371-E40S6-1024-3-T-24-ND E40S6-1024-3-T-24
2371-E40S6-600-3-N-24-ND E40S6-600-3-N-24
2371-ENC-1-1-T-24-ND ENC-1-1-T-24
2371-E40S6-2500-3-T-24-ND E40S6-2500-3-T-24
2371-E40H12-200-3-N-24-ND E40H12-200-3-N-24
2371-E40S6-2500-3-T-24-C-ND E40S6-2500-3-T-24-C
2371-E50S8-1000-3-T-24-ND E50S8-1000-3-T-24
2371-E50S8-1024-3-T-24-ND E50S8-1024-3-T-24
2371-E40H12-2000-3-V-5-ND E40H12-2000-3-V-5
2371-E50S8-5000-3-T-24-ND E50S8-5000-3-T-24
5322-M-0512-0-A-A-L-A-A-A-ND M-0512-0-A-A-L-A-A-A
4035-E6-2000-375-IE-S-D-D-3-ND E6-2000-375-IE-S-D-D-3
2371-E30S4-100-3-T-24-ND E30S4-100-3-T-24
2371-E50S8-200-3-T-24-ND E50S8-200-3-T-24
2371-E50S8-500-3-T-24-ND E50S8-500-3-T-24
2371-ENC-1-2-T-24-ND ENC-1-2-T-24
2371-E40S6-2000-3-T-24-ND E40S6-2000-3-T-24
2371-E40H8-1000-3-N-24-ND E40H8-1000-3-N-24
2371-E50S8-1000-3-T-24-C-ND E50S8-1000-3-T-24-C
2223-AMT10E2-V-ND AMT10E2-V
987-EN10HT1212N5HH3-ND EN10HT1212N5HH3
118-PEC12R-4215F-N0024-ND PEC12R-4215F-N0024
2223-AMT102-D2048-I8000-S-ND AMT102-D2048-I8000-S
2223-AMT102-D1024-I8000-S-ND AMT102-D1024-I8000-S
2223-AMT102-D2048-I5000-S-ND AMT102-D2048-I5000-S
102-6647-ND AMT133Q-V
516-AEDR-9930EL-102TR-ND,516-AEDR-9930EL-102CT-ND,516-AEDR-9930EL-102DKR-ND AEDR-9930EL-102
GH7771-ND 62SG15-L5-RAC
2223-RIC11-31S20D5S-TH-ND RIC11-31S20D5S-TH
2223-AMT102-D2048-I6350-S-ND AMT102-D2048-I6350-S
2223-AMT103-D2048-I6350-S-ND AMT103-D2048-I6350-S
2223-AMT103-D0512-I6000-S-ND AMT103-D0512-I6000-S
2223-AMT103-D0500-I6000-S-ND AMT103-D0500-I6000-S
2223-AMT103-D1024-I6000-S-ND AMT103-D1024-I6000-S
2223-AMT103-D1024-I8000-S-ND AMT103-D1024-I8000-S
2223-AMT102-D1024-I6350-S-ND AMT102-D1024-I6350-S
2223-AMT102-D0500-I6000-S-ND AMT102-D0500-I6000-S
2223-AMT103-D2048-I5000-S-ND AMT103-D2048-I5000-S
2223-AMT103-D1024-I5000-S-ND AMT103-D1024-I5000-S
2223-AMT102-D1024-I5000-S-ND AMT102-D1024-I5000-S
2223-AMT102-D0500-I8000-S-ND AMT102-D0500-I8000-S
2223-AMT103-D2048-I6000-S-ND AMT103-D2048-I6000-S
2223-AMT102-D2048-I6000-S-ND AMT102-D2048-I6000-S
2223-AMT103-D0512-I5000-S-ND AMT103-D0512-I5000-S
2223-AMT103-D0512-I6350-S-ND AMT103-D0512-I6350-S
2223-AMT103-D0500-I6350-S-ND AMT103-D0500-I6350-S
2223-AMT102-D0512-I6350-S-ND AMT102-D0512-I6350-S
2223-AMT102-D0500-I6350-S-ND AMT102-D0500-I6350-S
2223-AMT102-D0512-I6000-S-ND AMT102-D0512-I6000-S
2223-AMT102-D1024-I6000-S-ND AMT102-D1024-I6000-S
2223-AMT103-D1024-I6350-S-ND AMT103-D1024-I6350-S
2223-AMT103-D0512-I8000-S-ND AMT103-D0512-I8000-S
2223-AMT103-D0500-I5000-S-ND AMT103-D0500-I5000-S
2223-AMT103-D0500-I8000-S-ND AMT103-D0500-I8000-S
2223-AMT102-D0500-I5000-S-ND AMT102-D0500-I5000-S
2223-AMT102-D0512-I8000-S-ND AMT102-D0512-I8000-S
2223-AMT112S-0500-6000-S-ND AMT112S-0500-6000-S
2223-AMT113S-2048-6350-S-ND AMT113S-2048-6350-S
2223-AMT113S-0500-6000-S-ND AMT113S-0500-6000-S
2223-AMT112S-0500-5000-S-ND AMT112S-0500-5000-S
2223-AMT112S-2048-6350-S-ND AMT112S-2048-6350-S
2223-AMT112S-0400-5000-S-ND AMT112S-0400-5000-S
2223-AMT112S-4096-6000-S-ND AMT112S-4096-6000-S
2223-AMT113S-0400-6350-S-ND AMT113S-0400-6350-S
2223-AMT113S-0400-8000-S-ND AMT113S-0400-8000-S
2223-AMT113S-0400-6000-S-ND AMT113S-0400-6000-S
2223-AMT113S-0400-5000-S-ND AMT113S-0400-5000-S
2223-AMT113S-2048-5000-S-ND AMT113S-2048-5000-S
2223-AMT113S-0500-6350-S-ND AMT113S-0500-6350-S
2223-AMT113S-0500-8000-S-ND AMT113S-0500-8000-S
2223-AMT112S-0400-6000-S-ND AMT112S-0400-6000-S
2223-AMT112S-0500-6350-S-ND AMT112S-0500-6350-S
2223-AMT113S-0500-5000-S-ND AMT113S-0500-5000-S
2223-AMT113S-4096-6350-S-ND AMT113S-4096-6350-S
2223-AMT113S-2048-6000-S-ND AMT113S-2048-6000-S
2223-AMT112S-0500-8000-S-ND AMT112S-0500-8000-S
2223-AMT113S-4096-6000-S-ND AMT113S-4096-6000-S
2223-AMT112S-2048-8000-S-ND AMT112S-2048-8000-S
2223-AMT113S-2048-8000-S-ND AMT113S-2048-8000-S
2223-AMT112S-4096-5000-S-ND AMT112S-4096-5000-S
2223-AMT112S-4096-6350-S-ND AMT112S-4096-6350-S
2223-AMT113S-4096-8000-S-ND AMT113S-4096-8000-S
2223-AMT112Q-4096-5000-S-ND AMT112Q-4096-5000-S
2223-AMT112Q-0400-6350-S-ND AMT112Q-0400-6350-S
2223-AMT112Q-2048-6350-S-ND AMT112Q-2048-6350-S
2223-AMT112Q-2048-6000-S-ND AMT112Q-2048-6000-S
2223-AMT112Q-0500-5000-S-ND AMT112Q-0500-5000-S
2223-AMT112Q-0500-8000-S-ND AMT112Q-0500-8000-S
2223-AMT112Q-0400-6000-S-ND AMT112Q-0400-6000-S
2223-AMT112Q-0500-6000-S-ND AMT112Q-0500-6000-S
2223-AMT112Q-2048-8000-S-ND AMT112Q-2048-8000-S
516-AEDR-9930E-102TR-ND,516-AEDR-9930E-102CT-ND,516-AEDR-9930E-102DKR-ND AEDR-9930E-102
2223-AMT112S-0400-6350-S-ND AMT112S-0400-6350-S
2223-AMT112S-0400-8000-S-ND AMT112S-0400-8000-S
2223-AMT112S-2048-6000-S-ND AMT112S-2048-6000-S
2223-AMT112S-4096-8000-S-ND AMT112S-4096-8000-S
2223-AMT112S-2048-5000-S-ND AMT112S-2048-5000-S
2223-AMT113S-4096-5000-S-ND AMT113S-4096-5000-S
516-AEDR-9830DP-102-ND AEDR-9830DP-102
2223-AMT112Q-0500-6350-S-ND AMT112Q-0500-6350-S
2223-AMT112Q-0400-8000-S-ND AMT112Q-0400-8000-S
2223-AMT112Q-4096-6350-S-ND AMT112Q-4096-6350-S
2223-AMT112Q-4096-6000-S-ND AMT112Q-4096-6000-S
2223-AMT112Q-0400-5000-S-ND AMT112Q-0400-5000-S
1882-1088225-ND 1088225
1882-1090191-ND 1090191
1882-1037248-ND 1037248
1882-1052993-ND 1052993
1882-1082132-ND 1082132
1882-1051667-ND 1051667
1882-1056146-ND 1056146
1882-1055692-ND 1055692
1882-1088233-ND 1088233
1882-1088235-ND 1088235
1882-1036721-ND 1036721
1882-1036722-ND 1036722
1882-1095214-ND 1095214
1882-1083066-ND 1083066
3130-512-15020000011-ND 512-15020000011
4035-E4T-250-197-S-D-M-2 -ND E4T-250-197-S-D-M-2
5322-M-1024-4-A-A-E-B-A-K-ND M-1024-4-A-A-E-B-A-K
4035-E2-1000-197-IE-D-D-3-ND E2-1000-197-IE-D-D-3
2371-E30S4-100-3-V-5-ND E30S4-100-3-V-5
2371-E30S4-500-3-T-24-ND E30S4-500-3-T-24
2371-E30S4-360-3-T-24-ND E30S4-360-3-T-24
2371-E30S4-360-3-V-24-ND E30S4-360-3-V-24
2371-E30S4-100-3-N-24-ND E30S4-100-3-N-24
2371-E40S6-100-3-N-24-ND E40S6-100-3-N-24
2371-E40S6-200-3-V-24-C-ND E40S6-200-3-V-24-C
2371-E40S8-30-3-N-24-ND E40S8-30-3-N-24
2371-ENH-100-2-L-5-ND ENH-100-2-L-5
2371-ENH-100-1-L-5-ND ENH-100-1-L-5
2371-E50S8-360-3-N-24-ND E50S8-360-3-N-24
2371-ENH-100-1-T-24-ND ENH-100-1-T-24
2371-E50S8-150-3-T-24-ND E50S8-150-3-T-24
2371-E40H8-100-3-T-24-ND E40H8-100-3-T-24
2371-E50S8-100-3-T-24-CR-ND E50S8-100-3-T-24-CR
2371-ENC-1-5-T-24-ND ENC-1-5-T-24
2371-E40S6-3600-3-N-24-ND E40S6-3600-3-N-24
2371-E40S6-3600-3-T-24-ND E40S6-3600-3-T-24
2371-E40HB10-100-3-T-24-ND E40HB10-100-3-T-24
2371-E40S6-5000-3-T-24-ND E40S6-5000-3-T-24
2371-E50S8-1024-3-N-24-ND E50S8-1024-3-N-24
2371-E50S8-1800-3-N-24-ND E50S8-1800-3-N-24
2371-E40S6-2000-6-L-5-ND E40S6-2000-6-L-5
2371-E40H12-1000-3-V-24-ND E40H12-1000-3-V-24
2371-E40S8-5000-3-T-24-ND E40S8-5000-3-T-24
2371-E50S8-2048-6-L-5-ND E50S8-2048-6-L-5
2371-E40H8-2048-6-L-5-ND E40H8-2048-6-L-5
2239-15T-02SA-0100NV1ROC-M00-ND 15T-02SA-0100NV1ROC-M00
2239-15T-01SA-1024NV1RHV-M00-ND 15T-01SA-1024NV1RHV-M00
2239-15T-02SA-0100NV1RHV-M00-ND 15T-02SA-0100NV1RHV-M00
2239-15T-14SA-1000NV1RHV-M00-ND 15T-14SA-1000NV1RHV-M00
2239-15T-14SA-0500NV1ROC-M00-ND 15T-14SA-0500NV1ROC-M00
2239-15T-01SA-1000NV1ROC-M00-ND 15T-01SA-1000NV1ROC-M00
2239-15S-19M6-0100NV1ROC-M00-ND 15S-19M6-0100NV1ROC-M00
2239-15T-01SA-0600NV1RHV-M00-ND 15T-01SA-0600NV1RHV-M00
2239-15S-20M8-0500NV1ROC-M00-ND 15S-20M8-0500NV1ROC-M00
2239-15T-04SA-1000NV1RHV-M00-ND 15T-04SA-1000NV1RHV-M00
2239-15T-02SA-0200NV1RHV-M00-ND 15T-02SA-0200NV1RHV-M00
2239-15T-14SA-0100NV1RHV-M00-ND 15T-14SA-0100NV1RHV-M00
2239-15S-19M6-0600NV1ROC-M00-ND 15S-19M6-0600NV1ROC-M00
2239-15T-04SA-0600NV1ROC-M00-ND 15T-04SA-0600NV1ROC-M00
2239-15T-14SA-0100NV1ROC-M00-ND 15T-14SA-0100NV1ROC-M00
2239-15S-20M1-1024NV1ROC-M00-ND 15S-20M1-1024NV1ROC-M00
2239-15S-19M8-0100NV1ROC-M00-ND 15S-19M8-0100NV1ROC-M00
2239-15T-04SA-1024NV1RHV-M00-ND 15T-04SA-1024NV1RHV-M00
2239-15T-14SA-0500NV1RHV-M00-ND 15T-14SA-0500NV1RHV-M00
2239-15S-19M1-0200NV1ROC-M00-ND 15S-19M1-0200NV1ROC-M00
2239-15S-20M8-0100NV1ROC-M00-ND 15S-20M8-0100NV1ROC-M00
2239-15T-01SA-0600NV1ROC-M00-ND 15T-01SA-0600NV1ROC-M00
2239-15T-14SA-0200NV1RHV-M00-ND 15T-14SA-0200NV1RHV-M00
2239-15S-20M1-0600NV1ROC-M00-ND 15S-20M1-0600NV1ROC-M00
2239-15S-20M8-1024NV1ROC-M00-ND 15S-20M8-1024NV1ROC-M00
2239-15S-19M6-1000NV1ROC-M00-ND 15S-19M6-1000NV1ROC-M00
2239-15S-20M6-0200NV1ROC-M00-ND 15S-20M6-0200NV1ROC-M00
2239-15S-20M8-0600NV1ROC-M00-ND 15S-20M8-0600NV1ROC-M00
2239-15S-19M6-0500NV1ROC-M00-ND 15S-19M6-0500NV1ROC-M00
2239-15S-20M1-0200NV1ROC-M00-ND 15S-20M1-0200NV1ROC-M00
2239-15T-14SA-0600NV1RHV-M00-ND 15T-14SA-0600NV1RHV-M00
2239-15S-19M8-0500NV1ROC-M00-ND 15S-19M8-0500NV1ROC-M00
2239-15T-04SA-0100NV1RHV-M00-ND 15T-04SA-0100NV1RHV-M00
2239-15S-19M1-1024NV1ROC-M00-ND 15S-19M1-1024NV1ROC-M00
2239-15S-19M6-1024NV1ROC-M00-ND 15S-19M6-1024NV1ROC-M00
2239-15T-02SA-0600NV1ROC-M00-ND 15T-02SA-0600NV1ROC-M00
2239-15T-04SA-0200NV1RHV-M00-ND 15T-04SA-0200NV1RHV-M00
2239-15T-01SA-0100NV1ROC-M00-ND 15T-01SA-0100NV1ROC-M00
2239-15T-04SA-0200NV1ROC-M00-ND 15T-04SA-0200NV1ROC-M00
2239-15S-20M6-0500NV1ROC-M00-ND 15S-20M6-0500NV1ROC-M00
2239-15T-01SA-1000NV1RHV-M00-ND 15T-01SA-1000NV1RHV-M00
2239-15T-02SA-1024NV1RHV-M00-ND 15T-02SA-1024NV1RHV-M00
2239-15T-01SA-0100NV1RHV-M00-ND 15T-01SA-0100NV1RHV-M00
2239-15T-14SA-1024NV1ROC-M00-ND 15T-14SA-1024NV1ROC-M00
2239-15S-20M1-0100NV1ROC-M00-ND 15S-20M1-0100NV1ROC-M00
2239-15T-04SA-0100NV1ROC-M00-ND 15T-04SA-0100NV1ROC-M00
2239-15S-20M1-1000NV1ROC-M00-ND 15S-20M1-1000NV1ROC-M00
2239-15T-02SA-1000NV1ROC-M00-ND 15T-02SA-1000NV1ROC-M00
2239-15T-14SA-1000NV1ROC-M00-ND 15T-14SA-1000NV1ROC-M00
2239-15T-02SA-0600NV1RHV-M00-ND 15T-02SA-0600NV1RHV-M00
2239-15S-19M8-1024NV1ROC-M00-ND 15S-19M8-1024NV1ROC-M00
2239-15T-14SA-0600NV1ROC-M00-ND 15T-14SA-0600NV1ROC-M00
2239-15T-14SA-0200NV1ROC-M00-ND 15T-14SA-0200NV1ROC-M00
2239-15S-20M8-0200NV1ROC-M00-ND 15S-20M8-0200NV1ROC-M00
2239-15T-02SA-0500NV1RHV-M00-ND 15T-02SA-0500NV1RHV-M00
2239-15S-20M1-0500NV1ROC-M00-ND 15S-20M1-0500NV1ROC-M00
2239-15S-20M6-0600NV1ROC-M00-ND 15S-20M6-0600NV1ROC-M00
2239-15S-19M8-0200NV1ROC-M00-ND 15S-19M8-0200NV1ROC-M00
2239-15S-19M6-0200NV1ROC-M00-ND 15S-19M6-0200NV1ROC-M00
2239-15T-14SA-1024NV1RHV-M00-ND 15T-14SA-1024NV1RHV-M00
2239-15T-02SA-0500NV1ROC-M00-ND 15T-02SA-0500NV1ROC-M00
2239-15T-01SA-0200NV1ROC-M00-ND 15T-01SA-0200NV1ROC-M00
2239-15T-01SA-1024NV1ROC-M00-ND 15T-01SA-1024NV1ROC-M00
2239-15S-19M1-0600NV1ROC-M00-ND 15S-19M1-0600NV1ROC-M00
2239-15T-04SA-1024NV1ROC-M00-ND 15T-04SA-1024NV1ROC-M00
2239-15T-04SA-1000NV1ROC-M00-ND 15T-04SA-1000NV1ROC-M00
2239-15S-20M6-1000NV1ROC-M00-ND 15S-20M6-1000NV1ROC-M00
2239-15T-02SA-0200NV1ROC-M00-ND 15T-02SA-0200NV1ROC-M00
2239-15T-04SA-0500NV1RHV-M00-ND 15T-04SA-0500NV1RHV-M00
2239-15T-01SA-0200NV1RHV-M00-ND 15T-01SA-0200NV1RHV-M00
2239-15S-20M8-1000NV1ROC-M00-ND 15S-20M8-1000NV1ROC-M00
2239-15T-01SA-0500NV1RHV-M00-ND 15T-01SA-0500NV1RHV-M00
2239-15S-19M8-1000NV1ROC-M00-ND 15S-19M8-1000NV1ROC-M00
2239-15T-04SA-0500NV1ROC-M00-ND 15T-04SA-0500NV1ROC-M00
2239-15T-04SA-0600NV1RHV-M00-ND 15T-04SA-0600NV1RHV-M00
2239-15S-19M1-0100NV1ROC-M00-ND 15S-19M1-0100NV1ROC-M00
2239-15S-20M6-0100NV1ROC-M00-ND 15S-20M6-0100NV1ROC-M00
2239-15T-01SA-0500NV1ROC-M00-ND 15T-01SA-0500NV1ROC-M00
2239-15S-20M6-1024NV1ROC-M00-ND 15S-20M6-1024NV1ROC-M00
2239-15S-19M8-0600NV1ROC-M00-ND 15S-19M8-0600NV1ROC-M00
2239-15T-02SA-1024NV1ROC-M00-ND 15T-02SA-1024NV1ROC-M00
2239-15T-02SA-1000NV1RHV-M00-ND 15T-02SA-1000NV1RHV-M00
2239-15S-19M1-1000NV1ROC-M00-ND 15S-19M1-1000NV1ROC-M00
2239-15S-19M1-0500NV1ROC-M00-ND 15S-19M1-0500NV1ROC-M00
2371-E58SC10-2000-3-V-24-ND E58SC10-2000-3-V-24
2371-E40H12-2500-6-L-5-ND E40H12-2500-6-L-5
2239-15T-01SA-4096NV1ROC-M00-ND 15T-01SA-4096NV1ROC-M00
2239-15T-04SA-2048NV1RHV-M00-ND 15T-04SA-2048NV1RHV-M00
2239-15T-14SA-4096NV1ROC-M00-ND 15T-14SA-4096NV1ROC-M00
2239-15T-14SA-2500NV1RHV-M00-ND 15T-14SA-2500NV1RHV-M00
2239-15S-19M1-2048NV1ROC-M00-ND 15S-19M1-2048NV1ROC-M00
2239-15T-02SA-2500NV1ROC-M00-ND 15T-02SA-2500NV1ROC-M00
2239-15T-14SA-2048NV1ROC-M00-ND 15T-14SA-2048NV1ROC-M00
2239-15T-04SA-2500NV1RHV-M00-ND 15T-04SA-2500NV1RHV-M00
2239-15S-20M6-2048NV1ROC-M00-ND 15S-20M6-2048NV1ROC-M00
2239-15S-20M6-2500NV1ROC-M00-ND 15S-20M6-2500NV1ROC-M00
2239-15S-20M6-3600NV1ROC-M00-ND 15S-20M6-3600NV1ROC-M00
2239-15S-19M1-3600NV1ROC-M00-ND 15S-19M1-3600NV1ROC-M00
2239-15S-19M1-2500NV1ROC-M00-ND 15S-19M1-2500NV1ROC-M00
2239-15T-01SA-2500NV1RHV-M00-ND 15T-01SA-2500NV1RHV-M00
2239-15T-04SA-2048NV1ROC-M00-ND 15T-04SA-2048NV1ROC-M00
2239-15T-02SA-2048NV1ROC-M00-ND 15T-02SA-2048NV1ROC-M00
2239-15T-14SA-2500NV1ROC-M00-ND 15T-14SA-2500NV1ROC-M00
2239-15S-19M6-2500NV1ROC-M00-ND 15S-19M6-2500NV1ROC-M00
2239-15T-14SA-3600NV1RHV-M00-ND 15T-14SA-3600NV1RHV-M00
2239-15S-20M8-3600NV1ROC-M00-ND 15S-20M8-3600NV1ROC-M00
2239-15S-20M1-3600NV1ROC-M00-ND 15S-20M1-3600NV1ROC-M00
2239-15T-02SA-2500NV1RHV-M00-ND 15T-02SA-2500NV1RHV-M00
2239-15T-02SA-2048NV1RHV-M00-ND 15T-02SA-2048NV1RHV-M00
2239-15T-02SA-3600NV1RHV-M00-ND 15T-02SA-3600NV1RHV-M00
2239-15T-01SA-2048NV1ROC-M00-ND 15T-01SA-2048NV1ROC-M00
2239-15T-01SA-4096NV1RHV-M00-ND 15T-01SA-4096NV1RHV-M00
2239-15S-19M8-4096NV1ROC-M00-ND 15S-19M8-4096NV1ROC-M00
2239-15S-20M1-2500NV1ROC-M00-ND 15S-20M1-2500NV1ROC-M00
2239-15S-20M8-2500NV1ROC-M00-ND 15S-20M8-2500NV1ROC-M00
2239-15S-19M6-3600NV1ROC-M00-ND 15S-19M6-3600NV1ROC-M00
2239-15S-19M8-2048NV1ROC-M00-ND 15S-19M8-2048NV1ROC-M00
2239-15T-01SA-2500NV1ROC-M00-ND 15T-01SA-2500NV1ROC-M00
2239-15S-19M1-4096NV1ROC-M00-ND 15S-19M1-4096NV1ROC-M00
2239-15T-02SA-3600NV1ROC-M00-ND 15T-02SA-3600NV1ROC-M00
2239-15S-19M6-4096NV1ROC-M00-ND 15S-19M6-4096NV1ROC-M00
2239-15T-04SA-3600NV1ROC-M00-ND 15T-04SA-3600NV1ROC-M00
2239-15T-01SA-3600NV1RHV-M00-ND 15T-01SA-3600NV1RHV-M00
2239-15T-02SA-4096NV1ROC-M00-ND 15T-02SA-4096NV1ROC-M00
2239-15T-04SA-4096NV1RHV-M00-ND 15T-04SA-4096NV1RHV-M00
2239-15S-20M1-4096NV1ROC-M00-ND 15S-20M1-4096NV1ROC-M00
2239-15T-02SA-4096NV1RHV-M00-ND 15T-02SA-4096NV1RHV-M00
2239-15T-04SA-4096NV1ROC-M00-ND 15T-04SA-4096NV1ROC-M00
2239-15S-20M1-2048NV1ROC-M00-ND 15S-20M1-2048NV1ROC-M00
2239-15T-14SA-3600NV1ROC-M00-ND 15T-14SA-3600NV1ROC-M00
2239-15S-19M8-3600NV1ROC-M00-ND 15S-19M8-3600NV1ROC-M00
2239-15T-01SA-2048NV1RHV-M00-ND 15T-01SA-2048NV1RHV-M00
2239-15T-01SA-3600NV1ROC-M00-ND 15T-01SA-3600NV1ROC-M00
2239-15S-20M6-4096NV1ROC-M00-ND 15S-20M6-4096NV1ROC-M00
2239-15T-14SA-4096NV1RHV-M00-ND 15T-14SA-4096NV1RHV-M00
2239-15S-19M8-2500NV1ROC-M00-ND 15S-19M8-2500NV1ROC-M00
2239-15S-19M6-2048NV1ROC-M00-ND 15S-19M6-2048NV1ROC-M00
2239-15S-20M8-2048NV1ROC-M00-ND 15S-20M8-2048NV1ROC-M00
2239-15S-20M8-4096NV1ROC-M00-ND 15S-20M8-4096NV1ROC-M00
2239-15T-14SA-2048NV1RHV-M00-ND 15T-14SA-2048NV1RHV-M00
2239-15T-04SA-3600NV1RHV-M00-ND 15T-04SA-3600NV1RHV-M00
2239-15T-04SA-2500NV1ROC-M00-ND 15T-04SA-2500NV1ROC-M00
2371-E58SC10-2000-6-L-24-ND E58SC10-2000-6-L-24
2371-E60H20-1024-3-T-24-ND E60H20-1024-3-T-24
2371-E60H20-1024-6-L-5-ND E60H20-1024-6-L-5
2239-15T-14SA-10000NV1ROC-M00-ND 15T-14SA-10000NV1ROC-M00
2239-15T-14SA-8192NV1RHV-M00-ND 15T-14SA-8192NV1RHV-M00
2239-15S-19M6-10000NV1ROC-M00-ND 15S-19M6-10000NV1ROC-M00
2239-15T-02SA-8192NV1ROC-M00-ND 15T-02SA-8192NV1ROC-M00
2239-15S-20M1-10000NV1ROC-M00-ND 15S-20M1-10000NV1ROC-M00
2239-15S-20M8-10000NV1ROC-M00-ND 15S-20M8-10000NV1ROC-M00
2239-15T-01SA-8192NV1RHV-M00-ND 15T-01SA-8192NV1RHV-M00
2239-15T-04SA-10000NV1RHV-M00-ND 15T-04SA-10000NV1RHV-M00
2239-15T-02SA-10000NV1ROC-M00-ND 15T-02SA-10000NV1ROC-M00
2239-15T-02SA-10000NV1RHV-M00-ND 15T-02SA-10000NV1RHV-M00
2239-15T-01SA-10000NV1ROC-M00-ND 15T-01SA-10000NV1ROC-M00
2239-15T-04SA-8192NV1ROC-M00-ND 15T-04SA-8192NV1ROC-M00
2239-15T-01SA-10000NV1RHV-M00-ND 15T-01SA-10000NV1RHV-M00
2239-15T-04SA-10000NV1ROC-M00-ND 15T-04SA-10000NV1ROC-M00
2239-15S-20M1-8192NV1ROC-M00-ND 15S-20M1-8192NV1ROC-M00
2239-15S-20M6-10000NV1ROC-M00-ND 15S-20M6-10000NV1ROC-M00
2239-15S-19M6-8192NV1ROC-M00-ND 15S-19M6-8192NV1ROC-M00
2239-15S-19M8-10000NV1ROC-M00-ND 15S-19M8-10000NV1ROC-M00
2239-15T-02SA-8192NV1RHV-M00-ND 15T-02SA-8192NV1RHV-M00
2239-15S-19M1-8192NV1ROC-M00-ND 15S-19M1-8192NV1ROC-M00
2239-15S-19M8-8192NV1ROC-M00-ND 15S-19M8-8192NV1ROC-M00
2239-15S-20M8-8192NV1ROC-M00-ND 15S-20M8-8192NV1ROC-M00
2239-15S-19M1-10000NV1ROC-M00-ND 15S-19M1-10000NV1ROC-M00
2239-15S-20M6-8192NV1ROC-M00-ND 15S-20M6-8192NV1ROC-M00
2239-15T-14SA-10000NV1RHV-M00-ND 15T-14SA-10000NV1RHV-M00
2239-15T-04SA-8192NV1RHV-M00-ND 15T-04SA-8192NV1RHV-M00
2239-15T-14SA-8192NV1ROC-M00-ND 15T-14SA-8192NV1ROC-M00
2239-260-N-T-02-H-1024-R-HV-1-S-SF-2-N-ND 260-N-T-02-H-1024-R-HV-1-S-SF-2-N
2239-260-N-T-02-H-1000-R-HV-1-S-SF-2-N-ND 260-N-T-02-H-1000-R-HV-1-S-SF-2-N
2239-260-N-T-10-H-0600-R-HV-1-S-SF-2-N-ND 260-N-T-10-H-0600-R-HV-1-S-SF-2-N
2239-260-N-T-02-H-0600-R-OC-1-S-SF-2-N-ND 260-N-T-02-H-0600-R-OC-1-S-SF-2-N
2239-260-N-T-10-H-1000-R-HV-1-S-SF-2-N-ND 260-N-T-10-H-1000-R-HV-1-S-SF-2-N
2239-260-N-T-10-H-1000-R-OC-1-S-SF-2-N-ND 260-N-T-10-H-1000-R-OC-1-S-SF-2-N
2239-260-N-T-02-H-1024-R-OC-1-S-SF-2-N-ND 260-N-T-02-H-1024-R-OC-1-S-SF-2-N
2239-260-N-T-10-H-0600-R-OC-1-S-SF-2-N-ND 260-N-T-10-H-0600-R-OC-1-S-SF-2-N
2239-260-N-T-02-H-1000-R-OC-1-S-SF-2-N-ND 260-N-T-02-H-1000-R-OC-1-S-SF-2-N
2239-260-N-T-10-H-1024-R-OC-1-S-SF-2-N-ND 260-N-T-10-H-1024-R-OC-1-S-SF-2-N
2239-260-N-T-10-H-1024-R-HV-1-S-SF-2-N-ND 260-N-T-10-H-1024-R-HV-1-S-SF-2-N
2239-260-N-T-02-H-0600-R-HV-1-S-SF-2-N-ND 260-N-T-02-H-0600-R-HV-1-S-SF-2-N
2239-260-N-T-10-H-2048-R-OC-1-S-SF-2-N-ND 260-N-T-10-H-2048-R-OC-1-S-SF-2-N
2239-260-N-T-02-H-4096-R-HV-1-S-SF-2-N-ND 260-N-T-02-H-4096-R-HV-1-S-SF-2-N
2239-260-N-T-10-H-2500-R-HV-1-S-SF-2-N-ND 260-N-T-10-H-2500-R-HV-1-S-SF-2-N
2239-260-N-T-02-H-2500-R-OC-1-S-SF-2-N-ND 260-N-T-02-H-2500-R-OC-1-S-SF-2-N
2239-260-N-T-02-H-2500-R-HV-1-S-SF-2-N-ND 260-N-T-02-H-2500-R-HV-1-S-SF-2-N
2239-260-N-T-10-H-2048-R-HV-1-S-SF-2-N-ND 260-N-T-10-H-2048-R-HV-1-S-SF-2-N
2239-260-N-T-02-H-4096-R-OC-1-S-SF-2-N-ND 260-N-T-02-H-4096-R-OC-1-S-SF-2-N
2239-260-N-T-10-H-2500-R-OC-1-S-SF-2-N-ND 260-N-T-10-H-2500-R-OC-1-S-SF-2-N
2239-260-N-T-02-H-2048-R-HV-1-S-SF-2-N-ND 260-N-T-02-H-2048-R-HV-1-S-SF-2-N
2239-260-N-T-10-H-4096-R-HV-1-S-SF-2-N-ND 260-N-T-10-H-4096-R-HV-1-S-SF-2-N
2239-260-N-T-02-H-2048-R-OC-1-S-SF-2-N-ND 260-N-T-02-H-2048-R-OC-1-S-SF-2-N
2239-260-N-T-10-H-4096-R-OC-1-S-SF-2-N-ND 260-N-T-10-H-4096-R-OC-1-S-SF-2-N
1882-1071432-ND 1071432
2046-RSI58O-02YK1R61T-01024-ND RSI58O-02YK1R61T-01024
2239-770-B-S-1024-R-HV-A-P-N-N-N-ND 770-B-S-1024-R-HV-A-P-N-N-N
2239-770-B-S-1024-R-HV-D-P-N-N-N-ND 770-B-S-1024-R-HV-D-P-N-N-N
2239-770-B-S-1024-R-HV-C-P-N-N-N-ND 770-B-S-1024-R-HV-C-P-N-N-N
2239-770-B-S-2048-R-HV-D-P-N-N-N-ND 770-B-S-2048-R-HV-D-P-N-N-N
2239-770-B-S-2048-R-HV-A-P-N-N-N-ND 770-B-S-2048-R-HV-A-P-N-N-N
2239-770-B-S-2048-R-HV-C-P-N-N-N-ND 770-B-S-2048-R-HV-C-P-N-N-N
2239-770-B-S-4096-R-HV-D-P-N-N-N-ND 770-B-S-4096-R-HV-D-P-N-N-N
2239-770-B-S-4096-R-HV-A-P-N-N-N-ND 770-B-S-4096-R-HV-A-P-N-N-N
2239-770-B-S-4096-R-HV-C-P-N-N-N-ND 770-B-S-4096-R-HV-C-P-N-N-N
3130-512-14020000002-ND 512-14020000002
3130-488-1121101B101-ND 488-1121101B101
3130-488-1112101B101-ND 488-1112101B101
3542-GE-T-ND GE-T
3542-GE-A-ND GE-A
2371-E30S4-200-3-T-24-ND E30S4-200-3-T-24
2371-E30S4-200-3-V-5-ND E30S4-200-3-V-5
2371-E30S4-360-3-N-24-C-ND E30S4-360-3-N-24-C
2371-E18S2.5-200-1-N-5-S-ND E18S2.5-200-1-N-5-S
2371-E40S6-250-3-T-24-ND E40S6-250-3-T-24
2371-E50S8-100-3-N-24-ND E50S8-100-3-N-24
2371-E50S8-400-3-T-24-ND E50S8-400-3-T-24
2371-E50S8-1-2-T-24-ND E50S8-1-2-T-24
2371-E50S8-250-3-T-5-ND E50S8-250-3-T-5
2371-E40S6-1200-3-N-24-ND E40S6-1200-3-N-24
2371-E40H8-60-3-T-24-ND E40H8-60-3-T-24
2371-E40S6-1024-3-N-24-ND E40S6-1024-3-N-24
2371-E40S6-600-3-T-24-ND E40S6-600-3-T-24
2371-E40H8-200-3-N-24-ND E40H8-200-3-N-24
2371-E40S6-100-6-L-5-ND E40S6-100-6-L-5
2. Absolute Rotary Encoder:
Absolute rotary encoders can directly read the exact position of a rotating part without any need to calculate the position from a starting point or number of rotations.
An absolute encoder has multiple code rings with various binary weightings which provide a data word representing the absolute position of the encoder within one revolution. This type of encoder is often referred to as a parallel absolute encoder.
They can accurately provide the position of a rotating shaft relative to its initial state, acting as precise angle sensors. This means that even after a system restart, the exact position is retained, preventing any drift or loss of position data.
Advantages:
They offer higher accuracy and reliability.
Application:
Absolute rotary encoders are highly suitable for applications requiring precise and real-time position information, such as robotic control, precision instruments, and industrial automation.
Absolute Rotary Encoder from Digikey
516-AEAT-9955-102TR-ND,516-AEAT-9955-102CT-ND,516-AEAT-9955-102DKR-ND AEAT-9955-102
516-AEAT-9955-100TR-ND,516-AEAT-9955-100CT-ND,516-AEAT-9955-100DKR-ND AEAT-9955-100
102-5052-ND AMT203S-V
516-AEAT-9012-S06-ND AEAT-9012-S06
P17179-ND EVQ-V9C00116E
118-PAC18R1-43D19F-ND PAC18R1-43D19F
118-PAC18R1-33D19F-ND PAC18R1-33D19F
987-EN16ABVM22B0F20-ND EN16ABVM22B0F20
987-EN16ABHB11AF23-ND EN16ABHB11AF23
516-AEAT-9955-Q32-ND AEAT-9955-Q32
516-AR25-AS02-ND AR25-AS02
987-EN18ABHB11A0F26-ND EN18ABHB11A0F26
118-PAC18R1-31D19F-ND PAC18R1-31D19F
516-AR25-AB01-ND AR25-AB01
516-AR25-AS01-ND AR25-AS01
516-AR25-AB02-ND AR25-AB02
118-PAC18R1-33D28F-ND PAC18R1-33D28F
118-PAC18R1-31D28F-ND PAC18R1-31D28F
118-PAC18R1-41D28F-ND PAC18R1-41D28F
4809-EC18AGB20401-ND EC18AGB20401
4809-EC18AGB20407-ND EC18AGB20407
4809-EC18AGA20402-ND EC18AGA20402
2371-EPM50S8-1013-B-PN-24-ND EPM50S8-1013-B-PN-24
2371-EPM50S8-1013-B-PN-24-S-ND EPM50S8-1013-B-PN-24-S
118-PAC18R1-43D28F-ND PAC18R1-43D28F
118-PAC18R1-41D19F-ND PAC18R1-41D19F
1882-1037095-ND 1037095
1882-1061028-ND 1061028
2371-EP50S8-256-3F-N-24-ND EP50S8-256-3F-N-24
2371-EP50S8-256-3F-P-24-ND EP50S8-256-3F-P-24
1882-1098235-ND 1098235
2371-EP50S8-256-3F-P-5-ND EP50S8-256-3F-P-5
Z9421-ND E6C3-AB5B 8P/R 2M
2371-ENP-111R-012-P-ND ENP-111R-012-P
1882-1052162-ND 1052162
1882-1061044-ND 1061044
2371-EP58SC10-360-3F-P-24-ND EP58SC10-360-3F-P-24
2371-EP58HB8-360-3F-P-24-ND EP58HB8-360-3F-P-24
2371-ENP-101F-012-N-ND ENP-101F-012-N
2371-ENP-110F-360-P-ND ENP-110F-360-P
Based on different sensing technology:
1. Magnetic Rotary Encoders:
Magnetic encoders are a type of rotary encoder that use sensors to identify changes in magnetic fields from a rotating magnetized wheel or ring.
Sensing Circuit: a rotating wheel or ring and a series of magnetic poles around the circumference of the wheel are three major components in a magnetic encoder.
As the wheel or ring spins past the magnetic sensor, the magnetic poles create a response in the sensor depending on the strength of the magnetic field. This response is processed by an electrical circuit and then sent as a digital signal to the device controlling the system.
Advantages:
  • Magnetic rotary encoders have excellent immunity to interference, they ae not affected by light or electromagnetic interference.
  • They are durable can withstand harsh conditions like dust, dirt, moisture, and vibration.
  • Magnetic rotary encoders offer high precision and can provide position information accurate to micrometers or smaller units.
Application:
Magnetic encoders provide precise output for Industrial Automation and are employed in medical devices, Wind turbines and solar tracking systems.
Magnetic Rotary Sensor from Digikey
4991-AS5047D-ATSMTSSOP14LFT&RDPTR-ND,4991-AS5047D-ATSMTSSOP14LFT&RDPCT-ND,4991-AS5047D-ATSMTSSOP14LFT&RDPDKR-ND AS5047D-ATSM TSSOP14 LF T&RDP
AS5147-HTSMTR-ND,AS5147-HTSMCT-ND,AS5147-HTSMDKR-ND AS5147-HTSM
4991-AS5047P-ATSMTSSOP14LFT&RDPTR-ND,4991-AS5047P-ATSMTSSOP14LFT&RDPCT-ND,4991-AS5047P-ATSMTSSOP14LFT&RDPDKR-ND AS5047P-ATSM TSSOP14 LF T&RDP
AS5147P-HTSMTR-ND,AS5147P-HTSMCT-ND,AS5147P-HTSMDKR-ND AS5147P-HTSM
516-3787-ND AEAT-8800-Q24
516-AEAT-8800-Q24TR-ND,516-AEAT-8800-Q24CT-ND,516-AEAT-8800-Q24DKR-ND AEAT-8800-Q24TR
4991-AS5040-ASSTSSOP16LFT&RDPTR-ND,4991-AS5040-ASSTSSOP16LFT&RDPCT-ND,4991-AS5040-ASSTSSOP16LFT&RDPDKR-ND AS5040-ASST SSOP16 LF T&RDP
AS5311-ATST-500TR-ND,AS5311-ATST-500CT-ND,AS5311-ATST-500DKR-ND AS5311-ATST-500
AS5145B-HSSTTR-ND,AS5145B-HSSTCT-ND,AS5145B-HSSTDKR-ND AS5145B-HSST SSOP16 LF T&RDP
516-2636-ND AEAT-6600-T16
AS5045-ASSTTR-ND,AS5045-ASSTCT-ND,AS5045-ASSTDKR-ND AS5045-ASST
516-AEAT-9922-Q24-ND AEAT-9922-Q24
EMS22A50-B28-LS6-ND EMS22A50-B28-LS6
AS5245-HMFMTR-ND,AS5245-HMFMCT-ND,AS5245-HMFMDKR-ND AS5245-HMFM MLF32 LF T&RDP
516-2635-ND AEAT-6010-A06
4991-AS5047D-ATSTTSSOP14LFT&RDPTR-ND,4991-AS5047D-ATSTTSSOP14LFT&RDPCT-ND,4991-AS5047D-ATSTTSSOP14LFT&RDPDKR-ND AS5047D-ATST TSSOP14 LF T&RDP
EMS22Q31-B28-LS4-ND EMS22Q31-B28-LS4
EMS22A30-C28-LS6-ND EMS22A30-C28-LS6
EMS22A50-D28-LT6-ND EMS22A50-D28-LT6
AS5030-ATSTTR-ND,AS5030-ATSTCT-ND,AS5030-ATSTDKR-ND AS5030-ATST TSSOP16 LF T&RDP
AS5134-ZSSTTR-ND,AS5134-ZSSTCT-ND,AS5134-ZSSTDKR-ND AS5134-ZSST
516-AEAT-8811-Q24-ND AEAT-8811-Q24
AS5247-HMFMTR-ND,AS5247-HMFMCT-ND,AS5247-HMFMDKR-ND AS5247-HMFM
EMS22Q33-D28-LT4-ND EMS22Q33-D28-LT4
AS5134-ZSSMTR-ND,AS5134-ZSSMCT-ND,AS5134-ZSSMDKR-ND AS5134-ZSSM
516-AS20-M42M-P11-ND AS20-M42M-P11
516-AS20-M42M-K11-ND AS20-M42M-K11
516-AS20-M42M-S11-ND AS20-M42M-S11
516-AS20-M42M-B11-ND AS20-M42M-B11
2183-3499-ND 3499
2183-3081-ND 3081
2353-19-676768-ND 19-676768
5640-101778778-ND 101778778
5640-101778718-ND 101778718
5640-101778729-ND 101778729
5640-101778797-ND 101778797
5640-101778668-ND 101778668
5640-101778738-ND 101778738
5640-101778766-ND 101778766
5640-101778765-ND 101778765
5640-101778688-ND 101778688
5640-101778802-ND 101778802
5640-101778707-ND 101778707
5640-101778754-ND 101778754
5640-190047527-ND 190047527
5640-101778711-ND 101778711
5640-101778786-ND 101778786
5640-101778648-ND 101778648
5640-101778770-ND 101778770
5640-101778805-ND 101778805
5640-101778734-ND 101778734
5640-101778647-ND 101778647
5640-101778777-ND 101778777
5640-101778730-ND 101778730
5640-101778762-ND 101778762
5640-101778769-ND 101778769
5640-101778656-ND 101778656
5640-101778672-ND 101778672
5640-101778753-ND 101778753
5640-101778727-ND 101778727
5640-101778808-ND 101778808
5640-101778683-ND 101778683
5640-101778806-ND 101778806
5640-101778781-ND 101778781
5640-101778655-ND 101778655
5640-101778702-ND 101778702
5640-101778750-ND 101778750
5640-101778719-ND 101778719
5640-101778790-ND 101778790
5640-101778652-ND 101778652
5640-101778742-ND 101778742
5640-101778798-ND 101778798
5640-101778659-ND 101778659
5640-101778758-ND 101778758
5640-101778793-ND 101778793
5640-101778675-ND 101778675
5640-101778726-ND 101778726
5640-101778663-ND 101778663
5640-101778703-ND 101778703
5640-101778699-ND 101778699
5640-101778695-ND 101778695
5640-101778692-ND 101778692
5640-101778774-ND 101778774
5640-101778706-ND 101778706
5640-101778749-ND 101778749
5640-101778757-ND 101778757
5640-101778696-ND 101778696
5640-101778723-ND 101778723
5640-101778715-ND 101778715
5640-101778809-ND 101778809
5640-101778782-ND 101778782
5640-101778745-ND 101778745
5640-101778737-ND 101778737
5640-101778691-ND 101778691
5640-101778789-ND 101778789
5640-101778664-ND 101778664
5640-101778785-ND 101778785
5640-101778679-ND 101778679
5640-101778741-ND 101778741
5640-101778714-ND 101778714
5640-101778710-ND 101778710
5640-101778801-ND 101778801
5640-101778667-ND 101778667
5640-101778687-ND 101778687
5640-101778722-ND 101778722
5640-101778761-ND 101778761
5640-101778676-ND 101778676
5640-101778684-ND 101778684
5640-101778794-ND 101778794
5640-101778651-ND 101778651
5640-101778660-ND 101778660
5640-101778773-ND 101778773
5640-101778680-ND 101778680
5640-101778746-ND 101778746
5640-101778671-ND 101778671
5640-101778733-ND 101778733
5640-101778779-ND 101778779
5640-101778811-ND 101778811
5640-101778661-ND 101778661
5640-101778731-ND 101778731
5640-101778756-ND 101778756
5640-101778713-ND 101778713
5640-101778716-ND 101778716
5640-101778803-ND 101778803
5640-101778764-ND 101778764
5640-101778666-ND 101778666
5640-101778787-ND 101778787
5640-101778747-ND 101778747
5640-101778712-ND 101778712
5640-101778791-ND 101778791
5640-101778669-ND 101778669
5640-101778701-ND 101778701
5640-101778665-ND 101778665
5640-101778763-ND 101778763
5640-101778780-ND 101778780
5640-101778681-ND 101778681
5640-190046015-ND 190046015
5640-101778689-ND 101778689
5640-101778732-ND 101778732
5640-101778708-ND 101778708
5640-101778804-ND 101778804
5640-101778772-ND 101778772
5640-101778799-ND 101778799
5640-101778697-ND 101778697
5640-101778694-ND 101778694
5640-101778653-ND 101778653
5640-101778704-ND 101778704
5640-101778698-ND 101778698
5640-101778759-ND 101778759
5640-101778755-ND 101778755
5640-101778700-ND 101778700
5640-101778650-ND 101778650
5640-101778776-ND 101778776
5640-101778728-ND 101778728
5640-101778760-ND 101778760
5640-101778724-ND 101778724
5640-101778721-ND 101778721
5640-101778649-ND 101778649
5640-101778717-ND 101778717
5640-101778740-ND 101778740
5640-190044507-ND 190044507
5640-101778767-ND 101778767
5640-190047523-ND 190047523
5640-101778748-ND 101778748
5640-101778784-ND 101778784
5640-101778686-ND 101778686
5640-101778674-ND 101778674
5640-101778678-ND 101778678
5640-101778795-ND 101778795
5640-101778673-ND 101778673
5640-101778792-ND 101778792
5640-101778690-ND 101778690
5640-101778725-ND 101778725
5640-101778693-ND 101778693
5640-101778768-ND 101778768
5640-101778720-ND 101778720
5640-101778657-ND 101778657
5640-101778662-ND 101778662
5640-101778735-ND 101778735
5640-101778783-ND 101778783
5640-101778654-ND 101778654
5640-101778744-ND 101778744
5640-101778736-ND 101778736
5640-101778752-ND 101778752
5640-190037031-ND 190037031
5640-101778788-ND 101778788
5640-101778705-ND 101778705
5640-101778775-ND 101778775
5640-101778658-ND 101778658
5640-101778751-ND 101778751
5640-101778743-ND 101778743
5640-101778682-ND 101778682
5640-101778800-ND 101778800
5640-101778670-ND 101778670
5640-101778796-ND 101778796
5640-101778677-ND 101778677
5640-101778771-ND 101778771
5640-101778685-ND 101778685
5640-101778810-ND 101778810
5640-101778709-ND 101778709
5606-RM44UD0012B10F2E10TB-ND RM44UD0012B10F2E10
5606-MR040G030A064L00TB-ND MR040G030A064L00
5606-MRA049BC025DSE00TB-ND MRA049BC025DSE00
5606-RM44IA0012B10F2F96TB-ND RM44IA0012B10F2F96
5606-MB049DCC19BDNT00TB-ND MB049DCC19BDNT00
5606-LM10IC001AA10A00TB-ND LM10IC001AA10A00
EMS22Q51-B28-LS4-ND EMS22Q51-B28-LS4
EMS22Q31-B28-LS3-ND EMS22Q31-B28-LS3
EMS22Q51-B28-LS3-ND EMS22Q51-B28-LS3
EMS22D51-B28-LS5-ND EMS22D51-B28-LS5
EMS22P50-B28-LS6-ND EMS22P50-B28-LS6
516-AEAT-9922-102TR-ND,516-AEAT-9922-102CT-ND,516-AEAT-9922-102DKR-ND AEAT-9922-102
118-EMS22A50-M25-LD6-ND EMS22A50-M25-LD6
118-EMS22A50-C20-LS6-ND EMS22A50-C20-LS6
451-1130-ND 505Q-0256-S010
716-RAMK060M11319LB-ND RAMK060M11319LB
1882-1038033-ND 1038033
1882-1037434-ND 1037434
4638-UTD-IPH00-03600-02M0-2TW-ND UTD-IPH00-03600-02M0-2TW
2602-ST50512LC04PVCCTB-ND ST50512LC04PVCC
2602-ST51024LC06PVCCTB-ND ST51024LC06PVCC
2602-ST51024LC04CVCCTB-ND ST51024LC04CVCC
2602-ST51024LC04DVTTTB-ND ST51024LC04DVTT
2602-ST51024LC04CHCCTB-ND ST51024LC04CHCC
2602-ST51024LC04CHEETB-ND ST51024LC04CHEE
5606-RMM44A3A00TB-ND RMM44A3A00
5606-RMH06A3A00TB-ND RMH06A3A00
5606-RMA05A3A00TB-ND RMA05A3A00
5606-RMB28AC01SS96TB-ND RMB28AC01SS96
4638-UTD-IPH00-01024-02M0-2TW-ND UTD-IPH00-01024-02M0-2TW
4638-UTD-IPH00-01024-03M0-2TW-ND UTD-IPH00-01024-03M0-2TW
4638-UTD-IPH00-02048-03M0-2TW-ND UTD-IPH00-02048-03M0-2TW
4638-UTD-IPH00-02048-02M0-2TW-ND UTD-IPH00-02048-02M0-2TW
4638-UTD-IPH00-00500-03M0-2TW-ND UTD-IPH00-00500-03M0-2TW
4638-UTD-IPH00-02540-02M0-2TW-ND UTD-IPH00-02540-02M0-2TW
4638-UTD-IPH00-10000-02M0-2TW-ND UTD-IPH00-10000-02M0-2TW
4638-UTD-IPH00-01000-02M0-2TW-ND UTD-IPH00-01000-02M0-2TW
4638-UTD-IPH00-00500-02M0-2TW-ND UTD-IPH00-00500-02M0-2TW
4638-UTD-IPH00-02540-03M0-2TW-ND UTD-IPH00-02540-03M0-2TW
4638-UTD-IPH00-02500-03M0-2TW-ND UTD-IPH00-02500-03M0-2TW
4638-UTD-IPH00-00600-02M0-2TW-ND UTD-IPH00-00600-02M0-2TW
4638-UTD-IPH00-02500-02M0-2TW-ND UTD-IPH00-02500-02M0-2TW
4638-UTD-IPH00-00120-02M0-2TW-ND UTD-IPH00-00120-02M0-2TW
4638-UTD-IPH00-02000-02M0-2TW-ND UTD-IPH00-02000-02M0-2TW
4638-UTD-IPH00-02000-03M0-2TW-ND UTD-IPH00-02000-03M0-2TW
4638-UTD-IPH00-00120-03M0-2TW-ND UTD-IPH00-00120-03M0-2TW
4638-UTD-IPH00-01000-03M0-2TW-ND UTD-IPH00-01000-03M0-2TW
4638-UTD-IPH00-00600-03M0-2TW-ND UTD-IPH00-00600-03M0-2TW
4638-UTD-IPH00-10000-03M0-2TW-ND UTD-IPH00-10000-03M0-2TW
4638-UTD-IPH00-03600-03M0-2TW-ND UTD-IPH00-03600-03M0-2TW
4638-UTD-IPH00-01024-R060-2TW-ND UTD-IPH00-01024-R060-2TW
4638-UTD-IPH00-02048-R060-2TW-ND UTD-IPH00-02048-R060-2TW
4638-UTD-IPH00-03600-R060-2TW-ND UTD-IPH00-03600-R060-2TW
4638-UTD-IPH00-01000-R060-2TW-ND UTD-IPH00-01000-R060-2TW
4638-UTD-IPH00-02000-R060-2TW-ND UTD-IPH00-02000-R060-2TW
4638-UTD-IPH00-00120-R060-2TW-ND UTD-IPH00-00120-R060-2TW
4638-UTD-IPH00-02540-R060-2TW-ND UTD-IPH00-02540-R060-2TW
4638-UTD-IPH00-00500-R060-2TW-ND UTD-IPH00-00500-R060-2TW
4638-UTD-IPH00-10000-R060-2TW-ND UTD-IPH00-10000-R060-2TW
4638-UTD-IPH00-02500-R060-2TW-ND UTD-IPH00-02500-R060-2TW
4638-UTD-IPH00-00600-R060-2TW-ND UTD-IPH00-00600-R060-2TW
4638-UTD-IPH00-01024-3A70-2TW-ND UTD-IPH00-01024-3A70-2TW
4638-UTD-IPH00-02048-3A70-2TW-ND UTD-IPH00-02048-3A70-2TW
4638-UTD-IPH00-10000-3A70-2TW-ND UTD-IPH00-10000-3A70-2TW
4638-UTD-IPH00-00600-3A70-2TW-ND UTD-IPH00-00600-3A70-2TW
4638-UTD-IPH00-03600-3A70-2TW-ND UTD-IPH00-03600-3A70-2TW
4638-UTD-IPH00-02000-3A70-2TW-ND UTD-IPH00-02000-3A70-2TW
4638-UTD-IPH00-00500-3A70-2TW-ND UTD-IPH00-00500-3A70-2TW
4638-UTD-IPH00-02540-3A70-2TW-ND UTD-IPH00-02540-3A70-2TW
4638-UTD-IPH00-00120-3A70-2TW-ND UTD-IPH00-00120-3A70-2TW
4638-UTD-IPH00-01000-3A70-2TW-ND UTD-IPH00-01000-3A70-2TW
4638-UTD-IPH00-02500-3A70-2TW-ND UTD-IPH00-02500-3A70-2TW
4638-UTD-IPH00-01024-3C40-2TW-ND UTD-IPH00-01024-3C40-2TW
4638-UTD-IPH00-02048-3C40-2TW-ND UTD-IPH00-02048-3C40-2TW
4638-UTD-IPH00-00500-3C40-2TW-ND UTD-IPH00-00500-3C40-2TW
4638-UTD-IPH00-03600-3C40-2TW-ND UTD-IPH00-03600-3C40-2TW
4638-UTD-IPH00-01000-3C40-2TW-ND UTD-IPH00-01000-3C40-2TW
4638-UTD-IPH00-02000-3C40-2TW-ND UTD-IPH00-02000-3C40-2TW
4638-UTD-IPH00-00120-3C40-2TW-ND UTD-IPH00-00120-3C40-2TW
4638-UTD-IPH00-00600-3C40-2TW-ND UTD-IPH00-00600-3C40-2TW
4638-UTD-IPH00-02500-3C40-2TW-ND UTD-IPH00-02500-3C40-2TW
4638-UTD-IPH00-02540-3C40-2TW-ND UTD-IPH00-02540-3C40-2TW
4638-UTD-IPH00-10000-3C40-2TW-ND UTD-IPH00-10000-3C40-2TW
4638-UTD-IPH00-01024-V6S0-2TW-ND UTD-IPH00-01024-V6S0-2TW
4638-UTD-IPH00-02048-V6S0-2TW-ND UTD-IPH00-02048-V6S0-2TW
4638-UTD-IPH00-00600-V6S0-2TW-ND UTD-IPH00-00600-V6S0-2TW
4638-UTD-IPH00-02000-V6S0-2TW-ND UTD-IPH00-02000-V6S0-2TW
4638-UTD-IPH00-01000-V6S0-2TW-ND UTD-IPH00-01000-V6S0-2TW
4638-UTD-IPH00-00120-V6S0-2TW-ND UTD-IPH00-00120-V6S0-2TW
4638-UTD-IPH00-02500-V6S0-2TW-ND UTD-IPH00-02500-V6S0-2TW
4638-UTD-IPH00-03600-V6S0-2TW-ND UTD-IPH00-03600-V6S0-2TW
4638-UTD-IPH00-02540-V6S0-2TW-ND UTD-IPH00-02540-V6S0-2TW
4638-UTD-IPH00-00500-V6S0-2TW-ND UTD-IPH00-00500-V6S0-2TW
4638-UTD-IPH00-10000-V6S0-2TW-ND UTD-IPH00-10000-V6S0-2TW
4638-UTD-IPH00-01024-VRS0-2TW-ND UTD-IPH00-01024-VRS0-2TW
4638-UTD-IPH00-02048-VRS0-2TW-ND UTD-IPH00-02048-VRS0-2TW
4638-UTD-IPH00-03600-VRS0-2TW-ND UTD-IPH00-03600-VRS0-2TW
4638-UTD-IPH00-02540-VRS0-2TW-ND UTD-IPH00-02540-VRS0-2TW
4638-UTD-IPH00-00120-VRS0-2TW-ND UTD-IPH00-00120-VRS0-2TW
4638-UTD-IPH00-02500-VRS0-2TW-ND UTD-IPH00-02500-VRS0-2TW
4638-UTD-IPH00-01000-VRS0-2TW-ND UTD-IPH00-01000-VRS0-2TW
4638-UTD-IPH00-00500-VRS0-2TW-ND UTD-IPH00-00500-VRS0-2TW
4638-UTD-IPH00-02000-VRS0-2TW-ND UTD-IPH00-02000-VRS0-2TW
4638-UTD-IPH00-10000-VRS0-2TW-ND UTD-IPH00-10000-VRS0-2TW
4638-UTD-IPH00-00600-VRS0-2TW-ND UTD-IPH00-00600-VRS0-2TW
4638-UTD-IPH00-01024-4A70-2TW-ND UTD-IPH00-01024-4A70-2TW
4638-UTD-IPH00-02048-4A70-2TW-ND UTD-IPH00-02048-4A70-2TW
4638-UTD-IPH00-01000-4A70-2TW-ND UTD-IPH00-01000-4A70-2TW
4638-UTD-IPH00-00120-4A70-2TW-ND UTD-IPH00-00120-4A70-2TW
4638-UTD-IPH00-03600-4A70-2TW-ND UTD-IPH00-03600-4A70-2TW
4638-UTD-IPH00-02000-4A70-2TW-ND UTD-IPH00-02000-4A70-2TW
4638-UTD-IPH00-00600-4A70-2TW-ND UTD-IPH00-00600-4A70-2TW
4638-UTD-IPH00-00500-4A70-2TW-ND UTD-IPH00-00500-4A70-2TW
4638-UTD-IPH00-02540-4A70-2TW-ND UTD-IPH00-02540-4A70-2TW
4638-UTD-IPH00-02500-4A70-2TW-ND UTD-IPH00-02500-4A70-2TW
4638-UTD-IPH00-10000-4A70-2TW-ND UTD-IPH00-10000-4A70-2TW
4638-UTD-IPH00-01024-VSS0-2TW-ND UTD-IPH00-01024-VSS0-2TW
4638-UTD-IPH00-02048-VSS0-2TW-ND UTD-IPH00-02048-VSS0-2TW
4638-UTD-IPH00-03600-VSS0-2TW-ND UTD-IPH00-03600-VSS0-2TW
4638-UTD-IPH00-02000-VSS0-2TW-ND UTD-IPH00-02000-VSS0-2TW
4638-UTD-IPH00-00500-VSS0-2TW-ND UTD-IPH00-00500-VSS0-2TW
4638-UTD-IPH00-01000-VSS0-2TW-ND UTD-IPH00-01000-VSS0-2TW
4638-UTD-IPH00-00120-VSS0-2TW-ND UTD-IPH00-00120-VSS0-2TW
4638-UTD-IPH00-00600-VSS0-2TW-ND UTD-IPH00-00600-VSS0-2TW
4638-UTD-IPH00-10000-VSS0-2TW-ND UTD-IPH00-10000-VSS0-2TW
4638-UTD-IPH00-02500-VSS0-2TW-ND UTD-IPH00-02500-VSS0-2TW
4638-UTD-IPH00-02540-VSS0-2TW-ND UTD-IPH00-02540-VSS0-2TW
4638-UTD-IPH00-01024-VAS0-2TW-ND UTD-IPH00-01024-VAS0-2TW
4638-UTD-IPH00-02048-VAS0-2TW-ND UTD-IPH00-02048-VAS0-2TW
4638-UTD-IPH00-02000-VAS0-2TW-ND UTD-IPH00-02000-VAS0-2TW
4638-UTD-IPH00-02540-VAS0-2TW-ND UTD-IPH00-02540-VAS0-2TW
4638-UTD-IPH00-00500-VAS0-2TW-ND UTD-IPH00-00500-VAS0-2TW
4638-UTD-IPH00-03600-VAS0-2TW-ND UTD-IPH00-03600-VAS0-2TW
4638-UTD-IPH00-01000-VAS0-2TW-ND UTD-IPH00-01000-VAS0-2TW
4638-UTD-IPH00-00120-VAS0-2TW-ND UTD-IPH00-00120-VAS0-2TW
4638-UTD-IPH00-02500-VAS0-2TW-ND UTD-IPH00-02500-VAS0-2TW
4638-UTD-IPH00-00600-VAS0-2TW-ND UTD-IPH00-00600-VAS0-2TW
4638-UTD-IPH00-10000-VAS0-2TW-ND UTD-IPH00-10000-VAS0-2TW
4638-UTD-IPH00-01024-L10S-PRQ-ND UTD-IPH00-01024-L10S-PRQ
4638-UTD-IPH00-02048-L10S-PRQ-ND UTD-IPH00-02048-L10S-PRQ
4638-UTD-IPH00-02500-L10S-PRQ-ND UTD-IPH00-02500-L10S-PRQ
4638-UTD-IPH00-02540-L10S-PRQ-ND UTD-IPH00-02540-L10S-PRQ
4638-UTD-IPH00-02000-L10S-PRQ-ND UTD-IPH00-02000-L10S-PRQ
4638-UTD-IPH00-03600-L10S-PRQ-ND UTD-IPH00-03600-L10S-PRQ
4638-UTD-IPH00-00120-L10S-PRQ-ND UTD-IPH00-00120-L10S-PRQ
4638-UTD-IPH00-01000-L10S-PRQ-ND UTD-IPH00-01000-L10S-PRQ
4638-UTD-IPH00-10000-L10S-PRQ-ND UTD-IPH00-10000-L10S-PRQ
4638-UTD-IPH00-00500-L10S-PRQ-ND UTD-IPH00-00500-L10S-PRQ
4638-UTD-IPH00-00600-L10S-PRQ-ND UTD-IPH00-00600-L10S-PRQ
4638-UTD-IPH00-01024-L10S-PAQ-ND UTD-IPH00-01024-L10S-PAQ
4638-UTD-IPH00-02048-L10S-PAQ-ND UTD-IPH00-02048-L10S-PAQ
4638-UTD-IPH00-10000-L10S-PAQ-ND UTD-IPH00-10000-L10S-PAQ
4638-UTD-IPH00-01000-L10S-PAQ-ND UTD-IPH00-01000-L10S-PAQ
4638-UTD-IPH00-02500-L10S-PAQ-ND UTD-IPH00-02500-L10S-PAQ
4638-UTD-IPH00-03600-L10S-PAQ-ND UTD-IPH00-03600-L10S-PAQ
4638-UTD-IPH00-00500-L10S-PAQ-ND UTD-IPH00-00500-L10S-PAQ
4638-UTD-IPH00-00120-L10S-PAQ-ND UTD-IPH00-00120-L10S-PAQ
4638-UTD-IPH00-00600-L10S-PAQ-ND UTD-IPH00-00600-L10S-PAQ
4638-UTD-IPH00-02540-L10S-PAQ-ND UTD-IPH00-02540-L10S-PAQ
4638-UTD-IPH00-02000-L10S-PAQ-ND UTD-IPH00-02000-L10S-PAQ
4638-UTD-IPH00-01024-Y10S-PRQ-ND UTD-IPH00-01024-Y10S-PRQ
4638-UTD-IPH00-02048-Y10S-PRQ-ND UTD-IPH00-02048-Y10S-PRQ
4638-UTD-IPH00-01000-Y10S-PRQ-ND UTD-IPH00-01000-Y10S-PRQ
4638-UTD-IPH00-00500-Y10S-PRQ-ND UTD-IPH00-00500-Y10S-PRQ
4638-UTD-IPH00-00120-Y10S-PRQ-ND UTD-IPH00-00120-Y10S-PRQ
4638-UTD-IPH00-03600-Y10S-PRQ-ND UTD-IPH00-03600-Y10S-PRQ
4638-UTD-IPH00-02500-Y10S-PRQ-ND UTD-IPH00-02500-Y10S-PRQ
4638-UTD-IPH00-02000-Y10S-PRQ-ND UTD-IPH00-02000-Y10S-PRQ
4638-UTD-IPH00-10000-Y10S-PRQ-ND UTD-IPH00-10000-Y10S-PRQ
4638-UTD-IPH00-00600-Y10S-PRQ-ND UTD-IPH00-00600-Y10S-PRQ
4638-UTD-IPH00-02540-Y10S-PRQ-ND UTD-IPH00-02540-Y10S-PRQ
4638-UTD-IPH00-01024-Y10S-PAQ-ND UTD-IPH00-01024-Y10S-PAQ
4638-UTD-IPH00-02048-Y10S-PAQ-ND UTD-IPH00-02048-Y10S-PAQ
4638-UTD-IPH00-01000-Y10S-PAQ-ND UTD-IPH00-01000-Y10S-PAQ
4638-UTD-IPH00-10000-Y10S-PAQ-ND UTD-IPH00-10000-Y10S-PAQ
4638-UTD-IPH00-02540-Y10S-PAQ-ND UTD-IPH00-02540-Y10S-PAQ
4638-UTD-IPH00-03600-Y10S-PAQ-ND UTD-IPH00-03600-Y10S-PAQ
4638-UTD-IPH00-00120-Y10S-PAQ-ND UTD-IPH00-00120-Y10S-PAQ
4638-UTD-IPH00-02000-Y10S-PAQ-ND UTD-IPH00-02000-Y10S-PAQ
4638-UTD-IPH00-02500-Y10S-PAQ-ND UTD-IPH00-02500-Y10S-PAQ
4638-UTD-IPH00-00600-Y10S-PAQ-ND UTD-IPH00-00600-Y10S-PAQ
4638-UTD-IPH00-00500-Y10S-PAQ-ND UTD-IPH00-00500-Y10S-PAQ
4638-UTD-IPH00-01024-Y06S-PRQ-ND UTD-IPH00-01024-Y06S-PRQ
4638-UTD-IPH00-02048-Y06S-PRQ-ND UTD-IPH00-02048-Y06S-PRQ
4638-UTD-IPH00-00120-Y06S-PRQ-ND UTD-IPH00-00120-Y06S-PRQ
4638-UTD-IPH00-02000-Y06S-PRQ-ND UTD-IPH00-02000-Y06S-PRQ
4638-UTD-IPH00-03600-Y06S-PRQ-ND UTD-IPH00-03600-Y06S-PRQ
4638-UTD-IPH00-00600-Y06S-PRQ-ND UTD-IPH00-00600-Y06S-PRQ
4638-UTD-IPH00-01000-Y06S-PRQ-ND UTD-IPH00-01000-Y06S-PRQ
4638-UTD-IPH00-10000-Y06S-PRQ-ND UTD-IPH00-10000-Y06S-PRQ
4638-UTD-IPH00-02500-Y06S-PRQ-ND UTD-IPH00-02500-Y06S-PRQ
4638-UTD-IPH00-00500-Y06S-PRQ-ND UTD-IPH00-00500-Y06S-PRQ
4638-UTD-IPH00-02540-Y06S-PRQ-ND UTD-IPH00-02540-Y06S-PRQ
4638-UTD-IPH00-01024-Y06S-PAQ-ND UTD-IPH00-01024-Y06S-PAQ
4638-UTD-IPH00-02048-Y06S-PAQ-ND UTD-IPH00-02048-Y06S-PAQ
4638-UTD-IPH00-00120-Y06S-PAQ-ND UTD-IPH00-00120-Y06S-PAQ
4638-UTD-IPH00-03600-Y06S-PAQ-ND UTD-IPH00-03600-Y06S-PAQ
4638-UTD-IPH00-00600-Y06S-PAQ-ND UTD-IPH00-00600-Y06S-PAQ
4638-UTD-IPH00-10000-Y06S-PAQ-ND UTD-IPH00-10000-Y06S-PAQ
4638-UTD-IPH00-02000-Y06S-PAQ-ND UTD-IPH00-02000-Y06S-PAQ
4638-UTD-IPH00-02540-Y06S-PAQ-ND UTD-IPH00-02540-Y06S-PAQ
4638-UTD-IPH00-01000-Y06S-PAQ-ND UTD-IPH00-01000-Y06S-PAQ
4638-UTD-IPH00-00500-Y06S-PAQ-ND UTD-IPH00-00500-Y06S-PAQ
4638-UTD-IPH00-02500-Y06S-PAQ-ND UTD-IPH00-02500-Y06S-PAQ
4638-UTD-IPH00-01024-L06S-PRQ-ND UTD-IPH00-01024-L06S-PRQ
4638-UTD-IPH00-02048-L06S-PRQ-ND UTD-IPH00-02048-L06S-PRQ
4638-UTD-IPH00-00600-L06S-PRQ-ND UTD-IPH00-00600-L06S-PRQ
4638-UTD-IPH00-03600-L06S-PRQ-ND UTD-IPH00-03600-L06S-PRQ
4638-UTD-IPH00-01000-L06S-PRQ-ND UTD-IPH00-01000-L06S-PRQ
4638-UTD-IPH00-02540-L06S-PRQ-ND UTD-IPH00-02540-L06S-PRQ
4638-UTD-IPH00-02000-L06S-PRQ-ND UTD-IPH00-02000-L06S-PRQ
4638-UTD-IPH00-00500-L06S-PRQ-ND UTD-IPH00-00500-L06S-PRQ
4638-UTD-IPH00-02500-L06S-PRQ-ND UTD-IPH00-02500-L06S-PRQ
4638-UTD-IPH00-00120-L06S-PRQ-ND UTD-IPH00-00120-L06S-PRQ
4638-UTD-IPH00-10000-L06S-PRQ-ND UTD-IPH00-10000-L06S-PRQ
4638-UTD-IPH00-01024-L06S-PAQ-ND UTD-IPH00-01024-L06S-PAQ
4638-UTD-IPH00-02048-L06S-PAQ-ND UTD-IPH00-02048-L06S-PAQ
4638-UTD-IPH00-01000-L06S-PAQ-ND UTD-IPH00-01000-L06S-PAQ
4638-UTD-IPH00-10000-L06S-PAQ-ND UTD-IPH00-10000-L06S-PAQ
4638-UTD-IPH00-00500-L06S-PAQ-ND UTD-IPH00-00500-L06S-PAQ
4638-UTD-IPH00-00120-L06S-PAQ-ND UTD-IPH00-00120-L06S-PAQ
4638-UTD-IPH00-02000-L06S-PAQ-ND UTD-IPH00-02000-L06S-PAQ
4638-UTD-IPH00-02500-L06S-PAQ-ND UTD-IPH00-02500-L06S-PAQ
4638-UTD-IPH00-03600-L06S-PAQ-ND UTD-IPH00-03600-L06S-PAQ
4638-UTD-IPH00-00600-L06S-PAQ-ND UTD-IPH00-00600-L06S-PAQ
4638-UTD-IPH00-02540-L06S-PAQ-ND UTD-IPH00-02540-L06S-PAQ
4638-UTD-IPH00-01024-L10S-PAL-ND UTD-IPH00-01024-L10S-PAL
4638-UTD-IPH00-01024-L10S-PRL-ND UTD-IPH00-01024-L10S-PRL
4638-UTD-IPH00-02048-L10S-PAL-ND UTD-IPH00-02048-L10S-PAL
4638-UTD-IPH00-02048-L10S-PRL-ND UTD-IPH00-02048-L10S-PRL
4638-UTD-IPH00-03600-L10S-PAL-ND UTD-IPH00-03600-L10S-PAL
4638-UTD-IPH00-10000-L10S-PAL-ND UTD-IPH00-10000-L10S-PAL
4638-UTD-IPH00-00600-L10S-PAL-ND UTD-IPH00-00600-L10S-PAL
4638-UTD-IPH00-03600-L10S-PRL-ND UTD-IPH00-03600-L10S-PRL
4638-UTD-IPH00-00500-L10S-PRL-ND UTD-IPH00-00500-L10S-PRL
4638-UTD-IPH00-00120-L10S-PRL-ND UTD-IPH00-00120-L10S-PRL
4638-UTD-IPH00-10000-L10S-PRL-ND UTD-IPH00-10000-L10S-PRL
4638-UTD-IPH00-02000-L10S-PRL-ND UTD-IPH00-02000-L10S-PRL
4638-UTD-IPH00-01000-L10S-PRL-ND UTD-IPH00-01000-L10S-PRL
4638-UTD-IPH00-00600-L10S-PRL-ND UTD-IPH00-00600-L10S-PRL
4638-UTD-IPH00-02000-L10S-PAL-ND UTD-IPH00-02000-L10S-PAL
4638-UTD-IPH00-01000-L10S-PAL-ND UTD-IPH00-01000-L10S-PAL
4638-UTD-IPH00-00120-L10S-PAL-ND UTD-IPH00-00120-L10S-PAL
4638-UTD-IPH00-02540-L10S-PAL-ND UTD-IPH00-02540-L10S-PAL
4638-UTD-IPH00-02500-L10S-PRL-ND UTD-IPH00-02500-L10S-PRL
4638-UTD-IPH00-00500-L10S-PAL-ND UTD-IPH00-00500-L10S-PAL
4638-UTD-IPH00-02540-L10S-PRL-ND UTD-IPH00-02540-L10S-PRL
4638-UTD-IPH00-02500-L10S-PAL-ND UTD-IPH00-02500-L10S-PAL
4638-UTD-IPH00-01024-HFSS-PRQ-ND UTD-IPH00-01024-HFSS-PRQ
4638-UTD-IPH00-02048-HFSS-PRQ-ND UTD-IPH00-02048-HFSS-PRQ
4638-UTD-IPH00-02540-HFSS-PRQ-ND UTD-IPH00-02540-HFSS-PRQ
4638-UTD-IPH00-02500-HFSS-PRQ-ND UTD-IPH00-02500-HFSS-PRQ
4638-UTD-IPH00-00120-HFSS-PRQ-ND UTD-IPH00-00120-HFSS-PRQ
4638-UTD-IPH00-02000-HFSS-PRQ-ND UTD-IPH00-02000-HFSS-PRQ
4638-UTD-IPH00-00600-HFSS-PRQ-ND UTD-IPH00-00600-HFSS-PRQ
4638-UTD-IPH00-00500-HFSS-PRQ-ND UTD-IPH00-00500-HFSS-PRQ
4638-UTD-IPH00-01000-HFSS-PRQ-ND UTD-IPH00-01000-HFSS-PRQ
4638-UTD-IPH00-03600-HFSS-PRQ-ND UTD-IPH00-03600-HFSS-PRQ
4638-UTD-IPH00-10000-HFSS-PRQ-ND UTD-IPH00-10000-HFSS-PRQ
4638-UTD-IPH00-01024-HFSS-PAQ-ND UTD-IPH00-01024-HFSS-PAQ
4638-UTD-IPH00-02048-HFSS-PAQ-ND UTD-IPH00-02048-HFSS-PAQ
4638-UTD-IPH00-02000-HFSS-PAQ-ND UTD-IPH00-02000-HFSS-PAQ
4638-UTD-IPH00-01000-HFSS-PAQ-ND UTD-IPH00-01000-HFSS-PAQ
4638-UTD-IPH00-02500-HFSS-PAQ-ND UTD-IPH00-02500-HFSS-PAQ
4638-UTD-IPH00-00600-HFSS-PAQ-ND UTD-IPH00-00600-HFSS-PAQ
4638-UTD-IPH00-03600-HFSS-PAQ-ND UTD-IPH00-03600-HFSS-PAQ
4638-UTD-IPH00-00120-HFSS-PAQ-ND UTD-IPH00-00120-HFSS-PAQ
4638-UTD-IPH00-02540-HFSS-PAQ-ND UTD-IPH00-02540-HFSS-PAQ
4638-UTD-IPH00-10000-HFSS-PAQ-ND UTD-IPH00-10000-HFSS-PAQ
4638-UTD-IPH00-00500-HFSS-PAQ-ND UTD-IPH00-00500-HFSS-PAQ
4638-UTD-IPH00-01024-HCSS-PRQ-ND UTD-IPH00-01024-HCSS-PRQ
4638-UTD-IPH00-02048-HCSS-PRQ-ND UTD-IPH00-02048-HCSS-PRQ
4638-UTD-IPH00-01000-HCSS-PRQ-ND UTD-IPH00-01000-HCSS-PRQ
4638-UTD-IPH00-02000-HCSS-PRQ-ND UTD-IPH00-02000-HCSS-PRQ
4638-UTD-IPH00-02500-HCSS-PRQ-ND UTD-IPH00-02500-HCSS-PRQ
4638-UTD-IPH00-00500-HCSS-PRQ-ND UTD-IPH00-00500-HCSS-PRQ
4638-UTD-IPH00-00120-HCSS-PRQ-ND UTD-IPH00-00120-HCSS-PRQ
4638-UTD-IPH00-02540-HCSS-PRQ-ND UTD-IPH00-02540-HCSS-PRQ
4638-UTD-IPH00-00600-HCSS-PRQ-ND UTD-IPH00-00600-HCSS-PRQ
4638-UTD-IPH00-03600-HCSS-PRQ-ND UTD-IPH00-03600-HCSS-PRQ
4638-UTD-IPH00-10000-HCSS-PRQ-ND UTD-IPH00-10000-HCSS-PRQ
4638-UTD-IPH00-01024-HCSS-PAQ-ND UTD-IPH00-01024-HCSS-PAQ
4638-UTD-IPH00-01024-Y10S-PAL-ND UTD-IPH00-01024-Y10S-PAL
4638-UTD-IPH00-01024-Y10S-PRL-ND UTD-IPH00-01024-Y10S-PRL
4638-UTD-IPH00-02048-Y10S-PRL-ND UTD-IPH00-02048-Y10S-PRL
4638-UTD-IPH00-02048-Y10S-PAL-ND UTD-IPH00-02048-Y10S-PAL
4638-UTD-IPH00-02048-HCSS-PAQ-ND UTD-IPH00-02048-HCSS-PAQ
4638-UTD-IPH00-01000-HCSS-PAQ-ND UTD-IPH00-01000-HCSS-PAQ
4638-UTD-IPH00-02000-Y10S-PAL-ND UTD-IPH00-02000-Y10S-PAL
4638-UTD-IPH00-10000-HCSS-PAQ-ND UTD-IPH00-10000-HCSS-PAQ
4638-UTD-IPH00-02540-Y10S-PAL-ND UTD-IPH00-02540-Y10S-PAL
4638-UTD-IPH00-02000-Y10S-PRL-ND UTD-IPH00-02000-Y10S-PRL
4638-UTD-IPH00-00120-HCSS-PAQ-ND UTD-IPH00-00120-HCSS-PAQ
4638-UTD-IPH00-01000-Y10S-PRL-ND UTD-IPH00-01000-Y10S-PRL
4638-UTD-IPH00-00500-Y10S-PRL-ND UTD-IPH00-00500-Y10S-PRL
4638-UTD-IPH00-02500-HCSS-PAQ-ND UTD-IPH00-02500-HCSS-PAQ
4638-UTD-IPH00-02500-Y10S-PRL-ND UTD-IPH00-02500-Y10S-PRL
4638-UTD-IPH00-10000-Y10S-PAL-ND UTD-IPH00-10000-Y10S-PAL
4638-UTD-IPH00-00120-Y10S-PRL-ND UTD-IPH00-00120-Y10S-PRL
4638-UTD-IPH00-01000-Y10S-PAL-ND UTD-IPH00-01000-Y10S-PAL
4638-UTD-IPH00-02540-Y10S-PRL-ND UTD-IPH00-02540-Y10S-PRL
4638-UTD-IPH00-00500-Y10S-PAL-ND UTD-IPH00-00500-Y10S-PAL
4638-UTD-IPH00-00600-Y10S-PAL-ND UTD-IPH00-00600-Y10S-PAL
4638-UTD-IPH00-02500-Y10S-PAL-ND UTD-IPH00-02500-Y10S-PAL
4638-UTD-IPH00-00600-HCSS-PAQ-ND UTD-IPH00-00600-HCSS-PAQ
4638-UTD-IPH00-00600-Y10S-PRL-ND UTD-IPH00-00600-Y10S-PRL
4638-UTD-IPH00-10000-Y10S-PRL-ND UTD-IPH00-10000-Y10S-PRL
4638-UTD-IPH00-03600-Y10S-PRL-ND UTD-IPH00-03600-Y10S-PRL
4638-UTD-IPH00-02000-HCSS-PAQ-ND UTD-IPH00-02000-HCSS-PAQ
4638-UTD-IPH00-00120-Y10S-PAL-ND UTD-IPH00-00120-Y10S-PAL
4638-UTD-IPH00-03600-Y10S-PAL-ND UTD-IPH00-03600-Y10S-PAL
4638-UTD-IPH00-03600-HCSS-PAQ-ND UTD-IPH00-03600-HCSS-PAQ
4638-UTD-IPH00-00500-HCSS-PAQ-ND UTD-IPH00-00500-HCSS-PAQ
4638-UTD-IPH00-02540-HCSS-PAQ-ND UTD-IPH00-02540-HCSS-PAQ
4638-UTD-IPH00-01024-HASS-PRQ-ND UTD-IPH00-01024-HASS-PRQ
4638-UTD-IPH00-02048-HASS-PRQ-ND UTD-IPH00-02048-HASS-PRQ
4638-UTD-IPH00-03600-HASS-PRQ-ND UTD-IPH00-03600-HASS-PRQ
4638-UTD-IPH00-02540-HASS-PRQ-ND UTD-IPH00-02540-HASS-PRQ
4638-UTD-IPH00-01000-HASS-PRQ-ND UTD-IPH00-01000-HASS-PRQ
4638-UTD-IPH00-00600-HASS-PRQ-ND UTD-IPH00-00600-HASS-PRQ
4638-UTD-IPH00-10000-HASS-PRQ-ND UTD-IPH00-10000-HASS-PRQ
4638-UTD-IPH00-02000-HASS-PRQ-ND UTD-IPH00-02000-HASS-PRQ
4638-UTD-IPH00-00120-HASS-PRQ-ND UTD-IPH00-00120-HASS-PRQ
4638-UTD-IPH00-02500-HASS-PRQ-ND UTD-IPH00-02500-HASS-PRQ
4638-UTD-IPH00-00500-HASS-PRQ-ND UTD-IPH00-00500-HASS-PRQ
4638-UTD-IPH00-01024-HASS-PAQ-ND UTD-IPH00-01024-HASS-PAQ
4638-UTD-IPH00-02048-HASS-PAQ-ND UTD-IPH00-02048-HASS-PAQ
4638-UTD-IPH00-03600-HASS-PAQ-ND UTD-IPH00-03600-HASS-PAQ
4638-UTD-IPH00-00500-HASS-PAQ-ND UTD-IPH00-00500-HASS-PAQ
4638-UTD-IPH00-01000-HASS-PAQ-ND UTD-IPH00-01000-HASS-PAQ
4638-UTD-IPH00-02500-HASS-PAQ-ND UTD-IPH00-02500-HASS-PAQ
4638-UTD-IPH00-02540-HASS-PAQ-ND UTD-IPH00-02540-HASS-PAQ
4638-UTD-IPH00-02000-HASS-PAQ-ND UTD-IPH00-02000-HASS-PAQ
4638-UTD-IPH00-00120-HASS-PAQ-ND UTD-IPH00-00120-HASS-PAQ
4638-UTD-IPH00-10000-HASS-PAQ-ND UTD-IPH00-10000-HASS-PAQ
4638-UTD-IPH00-00600-HASS-PAQ-ND UTD-IPH00-00600-HASS-PAQ
4638-UTD-IPH00-01024-Y06S-PRL-ND UTD-IPH00-01024-Y06S-PRL
4638-UTD-IPH00-01024-Y06S-PAL-ND UTD-IPH00-01024-Y06S-PAL
4638-UTD-IPH00-02048-Y06S-PAL-ND UTD-IPH00-02048-Y06S-PAL
4638-UTD-IPH00-02048-Y06S-PRL-ND UTD-IPH00-02048-Y06S-PRL
4638-UTD-IPH00-01000-Y06S-PRL-ND UTD-IPH00-01000-Y06S-PRL
4638-UTD-IPH00-02000-Y06S-PAL-ND UTD-IPH00-02000-Y06S-PAL
4638-UTD-IPH00-02540-Y06S-PAL-ND UTD-IPH00-02540-Y06S-PAL
4638-UTD-IPH00-00600-Y06S-PRL-ND UTD-IPH00-00600-Y06S-PRL
4638-UTD-IPH00-02500-Y06S-PRL-ND UTD-IPH00-02500-Y06S-PRL
4638-UTD-IPH00-00500-Y06S-PAL-ND UTD-IPH00-00500-Y06S-PAL
4638-UTD-IPH00-02540-Y06S-PRL-ND UTD-IPH00-02540-Y06S-PRL
4638-UTD-IPH00-03600-Y06S-PRL-ND UTD-IPH00-03600-Y06S-PRL
4638-UTD-IPH00-10000-Y06S-PRL-ND UTD-IPH00-10000-Y06S-PRL
4638-UTD-IPH00-10000-Y06S-PAL-ND UTD-IPH00-10000-Y06S-PAL
4638-UTD-IPH00-01000-Y06S-PAL-ND UTD-IPH00-01000-Y06S-PAL
4638-UTD-IPH00-00500-Y06S-PRL-ND UTD-IPH00-00500-Y06S-PRL
4638-UTD-IPH00-00120-Y06S-PRL-ND UTD-IPH00-00120-Y06S-PRL
4638-UTD-IPH00-00600-Y06S-PAL-ND UTD-IPH00-00600-Y06S-PAL
4638-UTD-IPH00-00120-Y06S-PAL-ND UTD-IPH00-00120-Y06S-PAL
4638-UTD-IPH00-02000-Y06S-PRL-ND UTD-IPH00-02000-Y06S-PRL
4638-UTD-IPH00-03600-Y06S-PAL-ND UTD-IPH00-03600-Y06S-PAL
4638-UTD-IPH00-02500-Y06S-PAL-ND UTD-IPH00-02500-Y06S-PAL
4638-UTD-IPH00-01024-HSSS-PRQ-ND UTD-IPH00-01024-HSSS-PRQ
4638-UTD-IPH00-02048-HSSS-PRQ-ND UTD-IPH00-02048-HSSS-PRQ
4638-UTD-IPH00-01000-HSSS-PRQ-ND UTD-IPH00-01000-HSSS-PRQ
4638-UTD-IPH00-00600-HSSS-PRQ-ND UTD-IPH00-00600-HSSS-PRQ
4638-UTD-IPH00-02500-HSSS-PRQ-ND UTD-IPH00-02500-HSSS-PRQ
4638-UTD-IPH00-02000-HSSS-PRQ-ND UTD-IPH00-02000-HSSS-PRQ
4638-UTD-IPH00-00120-HSSS-PRQ-ND UTD-IPH00-00120-HSSS-PRQ
4638-UTD-IPH00-10000-HSSS-PRQ-ND UTD-IPH00-10000-HSSS-PRQ
4638-UTD-IPH00-03600-HSSS-PRQ-ND UTD-IPH00-03600-HSSS-PRQ
4638-UTD-IPH00-02540-HSSS-PRQ-ND UTD-IPH00-02540-HSSS-PRQ
4638-UTD-IPH00-00500-HSSS-PRQ-ND UTD-IPH00-00500-HSSS-PRQ
4638-UTD-IPH00-01024-HSSS-PAQ-ND UTD-IPH00-01024-HSSS-PAQ
4638-UTD-IPH00-02048-HSSS-PAQ-ND UTD-IPH00-02048-HSSS-PAQ
4638-UTD-IPH00-03600-HSSS-PAQ-ND UTD-IPH00-03600-HSSS-PAQ
4638-UTD-IPH00-02540-HSSS-PAQ-ND UTD-IPH00-02540-HSSS-PAQ
4638-UTD-IPH00-01000-HSSS-PAQ-ND UTD-IPH00-01000-HSSS-PAQ
4638-UTD-IPH00-10000-HSSS-PAQ-ND UTD-IPH00-10000-HSSS-PAQ
4638-UTD-IPH00-02000-HSSS-PAQ-ND UTD-IPH00-02000-HSSS-PAQ
4638-UTD-IPH00-00500-HSSS-PAQ-ND UTD-IPH00-00500-HSSS-PAQ
4638-UTD-IPH00-00120-HSSS-PAQ-ND UTD-IPH00-00120-HSSS-PAQ
4638-UTD-IPH00-00600-HSSS-PAQ-ND UTD-IPH00-00600-HSSS-PAQ
4638-UTD-IPH00-02500-HSSS-PAQ-ND UTD-IPH00-02500-HSSS-PAQ
4638-UTD-IPT00-01024-HUSS-PRQ-ND UTD-IPT00-01024-HUSS-PRQ
4638-UTD-IPT00-02048-HUSS-PRQ-ND UTD-IPT00-02048-HUSS-PRQ
4638-UTD-IPT00-00500-HUSS-PRQ-ND UTD-IPT00-00500-HUSS-PRQ
4638-UTD-IPT00-02000-HUSS-PRQ-ND UTD-IPT00-02000-HUSS-PRQ
4638-UTD-IPT00-02540-HUSS-PRQ-ND UTD-IPT00-02540-HUSS-PRQ
4638-UTD-IPT00-00120-HUSS-PRQ-ND UTD-IPT00-00120-HUSS-PRQ
4638-UTD-IPT00-10000-HUSS-PRQ-ND UTD-IPT00-10000-HUSS-PRQ
4638-UTD-IPT00-01000-HUSS-PRQ-ND UTD-IPT00-01000-HUSS-PRQ
4638-UTD-IPT00-03600-HUSS-PRQ-ND UTD-IPT00-03600-HUSS-PRQ
4638-UTD-IPT00-02500-HUSS-PRQ-ND UTD-IPT00-02500-HUSS-PRQ
4638-UTD-IPT00-00600-HUSS-PRQ-ND UTD-IPT00-00600-HUSS-PRQ
4638-UTD-IPT00-01024-HUSS-PAQ-ND UTD-IPT00-01024-HUSS-PAQ
4638-UTD-IPT00-02048-HUSS-PAQ-ND UTD-IPT00-02048-HUSS-PAQ
4638-UTD-IPT00-03600-HUSS-PAQ-ND UTD-IPT00-03600-HUSS-PAQ
4638-UTD-IPT00-02000-HUSS-PAQ-ND UTD-IPT00-02000-HUSS-PAQ
4638-UTD-IPT00-10000-HUSS-PAQ-ND UTD-IPT00-10000-HUSS-PAQ
4638-UTD-IPT00-00500-HUSS-PAQ-ND UTD-IPT00-00500-HUSS-PAQ
4638-UTD-IPT00-02540-HUSS-PAQ-ND UTD-IPT00-02540-HUSS-PAQ
4638-UTD-IPT00-00120-HUSS-PAQ-ND UTD-IPT00-00120-HUSS-PAQ
4638-UTD-IPT00-02500-HUSS-PAQ-ND UTD-IPT00-02500-HUSS-PAQ
2. Mechanical Rotary Encoders:
Mechanical rotary encoders are electromechanical devices. They consist of a rotating disc, a fixed disc, and a reader. They’re used to detect the position and movement of rotating objects.
The rotating disc has slots, and the fixed disk positioned below it has matching slots.
The reader is mounted above or below the rotating disc and it detects changes in the slots.
When the disc rotates, the reader senses the slots and generate corresponding pulse signals.
The angle and position of the rotating part can be determined by analyzing the quantity and sequence of pulse signals and the accuracy and resolution of encoder depend on the density and arrangement of the slots on the disc.
Advantages:
  • Mechanical rotary encoders are simple and reliable due to absence of electronics devices.
  • Mechanical encoders are often more affordable than optical or magnetic encoders, making them suitable for budget-constrained applications.
  • They are suitable for applications where high precision and speed are not required.
Application:
  • Mechanical rotary encoders are widely used in applications where simplicity, durability, and low cost are important. i.e.: Home application, consumer electronics and simple industrial equipment
Mechanical Rotary Encoder from Digikey
PEC11R-4115F-S0018-ND PEC11R-4115F-S0018
PEC12R-4225F-S0024-ND PEC12R-4225F-S0024
PEC12R-4222F-S0024-ND PEC12R-4222F-S0024
PEC16-4220F-S0024-ND PEC16-4220F-S0024
987-1196-ND EN12-HS22AF30
PEC11R-4215F-S0024-ND PEC11R-4215F-S0024
PEC11R-4215K-S0024-ND PEC11R-4215K-S0024
PEC11R-4220F-S0024-ND PEC11R-4220F-S0024
PEC11S-929K-S0015-ND PEC11S-929K-S0015
987-1398-ND EN11-HSM1BF20
987-1188-ND EN11-HSM1AF15
PEC11L-4120F-S0020-ND PEC11L-4120F-S0020
PEC09-2320F-T0015-ND PEC09-2320F-T0015
CT3002-ND 288T232R161A2
PEL12T-4225S-S1024-ND PEL12T-4225S-S1024
GH3071-ND 25LB10-Q
GH3076-ND 26ASD22-01-1-AJS
GH3075-ND 26ASD45-01-1-AJS
GH7411-ND 26GSD45-01-1-AJS
GH7412-ND 26GSD22-01-1-AJS
4809-EC10E1220505-ND EC10E1220505
4809-EC10E1220503-ND EC10E1220503
4809-EC10E1220501-ND EC10E1220501
PEC12R-4025F-N0024-ND PEC12R-4025F-N0024
PEC12R-4217F-N0024-ND PEC12R-4217F-N0024
118-PEC16-2015F-N0024-ND PEC16-2015F-N0024
PEC12R-2220F-S0024-ND PEC12R-2220F-S0024
PEC16-4220F-N0024-ND PEC16-4220F-N0024
PEC16-4120F-N0012-ND PEC16-4120F-N0012
PEC16-4225F-N0024-ND PEC16-4225F-N0024
PEC16-4020F-N0024-ND PEC16-4020F-N0024
PEC16-4025F-N0024-ND PEC16-4025F-N0024
PEC12R-2120F-S0012-ND PEC12R-2120F-S0012
PEC12R-4017F-N0024-ND PEC12R-4017F-N0024
PEC11R-4215F-N0024-ND PEC11R-4215F-N0024
PEC12R-4220F-N0024-ND PEC12R-4220F-N0024
PEC12R-4230F-N0024-ND PEC12R-4230F-N0024
PEC12R-4225F-N0024-ND PEC12R-4225F-N0024
PEC11R-4025F-N0024-ND PEC11R-4025F-N0024
PEC12R-4120F-N0012-ND PEC12R-4120F-N0012
PEC12R-4020F-N0024-ND PEC12R-4020F-N0024
PEC16-2215F-S0024-ND PEC16-2215F-S0024
PEC16-4215F-S0024-ND PEC16-4215F-S0024
PEC11R-4215K-S0012-ND PEC11R-4215K-S0012
PEC11R-4015F-S0024-ND PEC11R-4015F-S0024
PEC11R-4220F-S0012-ND PEC11R-4220F-S0012
PEC11R-4215K-N0024-ND PEC11R-4215K-N0024
PEC11R-4230F-N0024-ND PEC11R-4230F-N0024
PEC16-4215F-N0024-ND PEC16-4215F-N0024
PEC16-4015F-N0024-ND PEC16-4015F-N0024
PEC12R-4120F-S0012-ND PEC12R-4120F-S0012
PEC12R-3220F-S0024-ND PEC12R-3220F-S0024
PEC12R-4125F-S0012-ND PEC12R-4125F-S0012
PEC12R-3222F-S0024-ND PEC12R-3222F-S0024
PEC12R-3225F-S0024-ND PEC12R-3225F-S0024
PEC12R-4025F-S0024-ND PEC12R-4025F-S0024
118-PEC12R-4020F-S0012-ND PEC12R-4020F-S0012
PEC12R-4020F-S0024-ND PEC12R-4020F-S0024
PEC12R-4117F-S0012-ND PEC12R-4117F-S0012
PEC12R-4217F-S0024-ND PEC12R-4217F-S0024
PEC11L-4225F-S0015-ND PEC11L-4225F-S0015
987-1399-ND EN12-HN22AF25
PEC16-4015F-S0024-ND PEC16-4015F-S0024
P15965TR-ND,P15965CT-ND,P15965DKR-ND EVQ-VVD00203B
PEC11R-4015F-N0024-ND PEC11R-4015F-N0024
PEC11R-4230F-S0024-ND PEC11R-4230F-S0024
PEC11R-4120K-S0018-ND PEC11R-4120K-S0018
PEC11R-4315K-S0012-ND PEC11R-4315K-S0012
PEC11R-4315F-S0012-ND PEC11R-4315F-S0012
118-PEC11R-4225K-S0024-ND PEC11R-4225K-S0024
987-1185-ND EN11-HNM1AF15
PEC11R-4020F-S0012-ND PEC11R-4020F-S0012
PEC16-2220F-S0024-ND PEC16-2220F-S0024
PEC16-4120F-S0012-ND PEC16-4120F-S0012
987-1195-ND EN12-HS22AF20
987-1194-ND EN12-HS11AF25
987-1192-ND EN11-VSM1AF20
987-1186-ND EN11-HSB1AF15
118-PEC11L-4120K-S0020-ND PEC11L-4120K-S0020
PEC11L-4125F-S0020-ND PEC11L-4125F-S0020
118-PEC11L-4015F-S0020-ND PEC11L-4015F-S0020
118-PEC11L-4115K-S0020-ND PEC11L-4115K-S0020
PEC11R-4215F-S0012-ND PEC11R-4215F-S0012
PEC11R-4020F-S0024-ND PEC11R-4020F-S0024
118-PEC11H-4215F-S0024-ND PEC11H-4215F-S0024
PEC11R-4020F-N0024-ND PEC11R-4020F-N0024
PEC11R-4220F-N0024-ND PEC11R-4220F-N0024
PEC11L-4125K-N0020-ND PEC11L-4125K-N0020
PES12-40S-N0024-ND PES12-40S-N0024
PEC11S-9215K-H0015-ND PEC11S-9215K-H0015
PEC11L-4220F-S0015-ND PEC11L-4220F-S0015
118-PEC11R-4320F-S0012-ND PEC11R-4320F-S0012
PEC11R-4015K-S0024-ND PEC11R-4015K-S0024
PEC11R-4115K-S0018-ND PEC11R-4115K-S0018
PEC11R-4120F-S0018-ND PEC11R-4120F-S0018
PEC11R-4015F-S0018-ND PEC11R-4015F-S0018
PEC09-2320F-S0015-ND PEC09-2320F-S0015
PEC11S-9213K-S0015-ND PEC11S-9213K-S0015
118-PEC11S-929F-S0015-ND PEC11S-929F-S0015
PEC11S-9220F-S0015-ND PEC11S-9220F-S0015
987-1187-ND EN11-HSB1AQ20
PEC11L-4115F-S0020-ND PEC11L-4115F-S0020
PEC11L-4215F-S0015-ND PEC11L-4215F-S0015
118-PEC11H-4025F-S0016-ND PEC11H-4025F-S0016
118-PEC11H-4120F-S0020-ND PEC11H-4120F-S0020
118-PEC11H-4115F-S0020-ND PEC11H-4115F-S0020
118-PEC11H-4020F-S0016-ND PEC11H-4020F-S0016
CT3001-ND 288T232R161A1
CT3009-ND 290VAA5F201A2
PEC09-2120F-S0012-ND PEC09-2120F-S0012
PEC11S-9215F-S0015-ND PEC11S-9215F-S0015
ECW0J-B24-AC0006L-ND ECW0J-B24-AC0006L
ECW1J-C28-BC0024L-ND ECW1J-C28-BC0024L
732-13719-ND 4.82017E+11
732-13720-ND 4.82021E+11
732-13718-ND 4.8201E+11
PEL12D-4225S-S2024-ND PEL12D-4225S-S2024
CT3007-ND 290VAB0R201B2
CT3000-ND 288X232R161B2
4809-EC11E18244AU-ND EC11E18244AU
3315Y-025-016L-ND 3315Y-025-016L
4809-EC11E15244B2-ND EC11E15244B2
CT2999-ND 288V232R161B2
3315C-001-006L-ND 3315C-001-006L
ECW1J-C24-CC0024L-ND ECW1J-C24-CC0024L
ECW1J-B16-BC0024L-ND ECW1J-B16-BC0024L
ECW1J-B24-BC0024L-ND ECW1J-B24-BC0024L
ECW1D-C24-CC0024L-ND ECW1D-C24-CC0024L
ECW1J-C24-AC0024L-ND ECW1J-C24-AC0024L
ECW1J-C24-BC0024L-ND ECW1J-C24-BC0024L
ECW1J-B24-AC0024L-ND ECW1J-B24-AC0024L
118-PEC11D-4120F-S0015-ND PEC11D-4120F-S0015
118-PEC11D-4120F-H0015-ND PEC11D-4120F-H0015
EAW0J-B24-AE0128L-ND EAW0J-B24-AE0128L
EAW0J-C24-AE0128L-ND EAW0J-C24-AE0128L
EPS1D-F19-AD0024L-ND EPS1D-F19-AD0024L
GH3074-ND 25LB22-H
136-26GS22-01A16S-ND 26GS22-01A16S
PEC12R-4115F-N0012-ND PEC12R-4115F-N0012
PEC12R-4117F-N0012-ND PEC12R-4117F-N0012
PEC12R-4217F-S0012-ND PEC12R-4217F-S0012
PEC12R-2117F-S0012-ND PEC12R-2117F-S0012
PEC12R-2230F-S0024-ND PEC12R-2230F-S0024
PEC16-4115F-N0012-ND PEC16-4115F-N0012
PEC16-2215F-N0024-ND PEC16-2215F-N0024
PEC12R-4220F-S0012-ND PEC12R-4220F-S0012
987-1197-ND EN12-VN20AF20
PEC12R-2225F-N0024-ND PEC12R-2225F-N0024
PEC16-4220F-S0012-ND PEC16-4220F-S0012
PEC16-2015F-S0024-ND PEC16-2015F-S0024
PEC11R-4230F-S0012-ND PEC11R-4230F-S0012
118-PEC11L-4115K-N0020-ND PEC11L-4115K-N0020
PEC11R-4125F-N0018-ND PEC11R-4125F-N0018
PEC11R-4225F-N0024-ND PEC11R-4225F-N0024
PEC11R-4215F-N0012-ND PEC11R-4215F-N0012
PEC12R-2217F-S0024-ND PEC12R-2217F-S0024
PEC11R-4015F-S0012-ND PEC11R-4015F-S0012
PEC11R-4230K-S0024-ND PEC11R-4230K-S0024
PEC11R-4125F-S0018-ND PEC11R-4125F-S0018
PEC16-4115F-S0012-ND PEC16-4115F-S0012
987-1199-ND EN16-H20AF15
118-PEC11L-4120F-N0020-ND PEC11L-4120F-N0020
PEC11L-4020F-N0020-ND PEC11L-4020F-N0020
987-1829-ND EN12-HS22AF18
987-1198-ND EN12-VS11AF18
PEC11L-4020F-S0020-ND PEC11L-4020F-S0020
987-1183-ND EN11-HNB0AF20
118-PEC11L-4220K-S0015-ND PEC11L-4220K-S0015
987-1190-ND EN11-VNB1BQ15
118-PEC11R-4120F-N0018-ND PEC11R-4120F-N0018
PEC11R-4015K-N0024-ND PEC11R-4015K-N0024
PEC11R-4220K-N0024-ND PEC11R-4220K-N0024
PEC11R-4020F-N0012-ND PEC11R-4020F-N0012
PEC11R-4015F-N0012-ND PEC11R-4015F-N0012
PEC11R-4330F-S0012-ND PEC11R-4330F-S0012
PEC11R-4130F-S0018-ND PEC11R-4130F-S0018
118-PEC11R-4325F-S0012-ND PEC11R-4325F-S0012
CT3010-ND 290VAA5F201B1
CT3006-ND 290VAB0R201B1
987-1191-ND EN11-VSM0AF20
118-PEC09-2315F-N0015-ND PEC09-2315F-N0015
3315C-001-016L-ND 3315C-001-016L
PEC09-2220F-S0012-ND PEC09-2220F-S0012
PEC11S-9220K-S0015-ND PEC11S-9220K-S0015
ECW0J-B16-BE0024L-ND ECW0J-B16-BE0024L
119-11CEH20F122B-ND 11CEH20F122B
ECW0D-B24-AE0024L-ND ECW0D-B24-AE0024L
ECW0D-B24-BC0006L-ND ECW0D-B24-BC0006L
PES12-42S-N0024-ND PES12-42S-N0024
PEC11S-9215K-S0015-ND PEC11S-9215K-S0015
3315Y-001-016L-ND 3315Y-001-016L
3315C-111-016L-ND 3315C-111-016L
PEL12D-2225S-S1024-ND PEL12D-2225S-S1024
118-PEC09-2120K-T0012-ND PEC09-2120K-T0012
732-482024764004-ND 4.82025E+11
ECW1D-B24-BC0024L-ND ECW1D-B24-BC0024L
3315Y-001-006L-ND 3315Y-001-006L
732-482016564002-ND 4.82017E+11
ECW1J-B24-AB0012L-ND ECW1J-B24-AB0012L
ECW0J-B24-BC0006L-ND ECW0J-B24-BC0006L
ECW1J-R19-CC0024L-ND ECW1J-R19-CC0024L
ECW1J-R19-BC0024L-ND ECW1J-R19-BC0024L
ECW1D-C24-BC0024L-ND ECW1D-C24-BC0024L
ECW1J-R24-BC0024L-ND ECW1J-R24-BC0024L
ECW0J-B24-BD0009L-ND ECW0J-B24-BD0009L
ECW1J-R19-AC0024L-ND ECW1J-R19-AC0024L
PEL12T-4226F-S1024-ND PEL12T-4226F-S1024
ESD0D-S00-GC0006L-ND ESD0D-S00-GC0006L
EAW0J-B24-CE0128L-ND EAW0J-B24-CE0128L
EPS1D-F19-AE0024L-ND EPS1D-F19-AE0024L
EPS1D-F19-BD0024L-ND EPS1D-F19-BD0024L
GH3072-ND 25LB15-Q
987-1200-ND EN16-V22AF15
PEC11R-4115F-N0018-ND PEC11R-4115F-N0018
PEC16-2220F-N0024-ND PEC16-2220F-N0024
118-PEC11L-4125F-N0020-ND PEC11L-4125F-N0020
PEC11R-4220F-N0012-ND PEC11R-4220F-N0012
PEC11S-929K-N0015-ND PEC11S-929K-N0015
3315R-101-016L-ND 3315R-101-016L
CT3005-ND 290VAB0R201A2
118-3315P-001-016L-ND 3315P-001-016L
3315R-102-016L-ND 3315R-102-016L
118-ECW0J-B24-HC0006L-ND ECW0J-B24-HC0006L
ECW0J-B24-CC0006L-ND ECW0J-B24-CC0006L
ECW1J-B28-AC0024L-ND ECW1J-B28-AC0024L
ESD1D-S00-GC0024L-ND ESD1D-S00-GC0024L
3746-MERP11-15125BM7-ND MERP11-15125BM7
4809-EC10E1260502-ND EC10E1260502
4809-EC10E1260507-ND EC10E1260507
118-PEC11R-4115K-N0018-ND PEC11R-4115K-N0018
4809-EC05E1220203TR-ND,4809-EC05E1220203CT-ND,4809-EC05E1220203DKR-ND EC05E1220203
3746-MER1045-24TR-ND,3746-MER1045-24CT-ND,3746-MER1045-24DKR-ND MER1045-24
118-PEC11H-4220K-S0024-ND PEC11H-4220K-S0024
118-PEC11H-4225F-S0024-ND PEC11H-4225F-S0024
118-PEL12S-2024S-N3024-ND PEL12S-2024S-N3024
3746-MERPS11-15295TTR-ND,3746-MERPS11-15295TCT-ND,3746-MERPS11-15295TDKR-ND MERPS11-15295T
3746-MERPS11-15110TTR-ND,3746-MERPS11-15110TCT-ND,3746-MERPS11-15110TDKR-ND MERPS11-15110T
3746-MERPS11-15515-1.5-ND MERPS11-15515-1.5
4809-EC21A1540401-ND EC21A1540401
4809-EC21A1520401-ND EC21A1520401
4809-EC21A0920401-ND EC21A0920401
119-290VAB0F201B2-ND 290VAB0F201B2
4809-EC21A0950402-ND EC21A0950402
4809-EC21A1520407-ND EC21A1520407
4809-EC35A1520402-ND EC35A1520402
4809-EC35A0930401-ND EC35A0930401
4809-EC35A1550502-ND EC35A1550502
4809-EC21C1520402-ND EC21C1520402
4809-EC40A1520403-ND EC40A1520403
4809-EC40A1520405-ND EC40A1520405
118-PEL12T-4226G-S1024-ND PEL12T-4226G-S1024
4809-EC50A0920404-ND EC50A0920404
2234-ENC-01-ND ENC-01
2266-25LB15-Q-Z-ND,25LB15-Q-Z-ND 25LB15-Q-Z
CT3011-ND 290VAA5F201B2
2266-513385-ND,GH7648-ND 513385
PEC12R-4125F-N0012-ND PEC12R-4125F-N0012
PEC12R-2125F-N0012-ND PEC12R-2125F-N0012
PEC16-2120F-S0012-ND PEC16-2120F-S0012
PEC11R-4315F-N0012-ND PEC11R-4315F-N0012
PEL12S-4224S-N1024-ND PEL12S-4224S-N1024
119-11CEK25F243B-ND 11CEK25F243B
119-11CEY25F243B-ND 11CEY25F243B
119-12CE1H25F12224-ND 12CE1H25F12224
119-12CE1H24B12224-ND 12CE1H24B12224
PEL12D-4225S-S1024-ND PEL12D-4225S-S1024
ECW0J-R19-BE0024L-ND ECW0J-R19-BE0024L
ECW1J-R24-CC0024L-ND ECW1J-R24-CC0024L
EAW0J-B24-BE0128L-ND EAW0J-B24-BE0128L
3315C-102-016L-ND 3315C-102-016L
ECW1J-R24-AC0024L-ND ECW1J-R24-AC0024L
GH7409-ND 25LB30-Q
2266-25LB45-Q-ND,GH7410-ND 25LB45-Q
2266-25LB18-Q-ND,GH7408-ND 25LB18-Q
2266-25LB11-Q-ND,GH7407-ND 25LB11-Q
118-PEC12R-4017F-S0024-ND PEC12R-4017F-S0024
3746-MER12-24120-ND MER12-24120
3746-MER12-24N125M9-ND MER12-24N125M9
3746-MERS11-15120-ND MERS11-15120
3746-MERS11-15220-ND MERS11-15220
3746-MERS11-15115-ND MERS11-15115
118-PEC11R-4025F-S0024-ND PEC11R-4025F-S0024
3746-MER11-20120B-ND MER11-20120B
3746-MERP12-24120-ND MERP12-24120
3746-MERP12-24126GR-ND MERP12-24126GR
3746-MERP12-24N220-ND MERP12-24N220
3746-MERP12-24117.5-ND MERP12-24117.5
3746-MERP12-24126M-ND MERP12-24126M
3746-MERP11-20120B-ND MERP11-20120B
3746-MERPS11-15120-ND MERPS11-15120
3746-MERPS11-15213-1.5-ND MERPS11-15213-1.5
3746-MERPS11-15295-1.5-ND MERPS11-15295-1.5
3746-MERPS11-15213-ND MERPS11-15213
3746-MERP11-15115AM7-ND MERP11-15115AM7
3746-MERP11-20120BM7-ND MERP11-20120BM7
3746-MERPS11-15115-ND MERPS11-15115
3746-MERP11-20325B-ND MERP11-20325B
3746-MERP11-15115AR-ND MERP11-15115AR
3746-MERP11-20125B-ND MERP11-20125B
3746-MERP11-20215A-ND MERP11-20215A
3746-MERP11-15120B-ND MERP11-15120B
3746-MERPS11-15215-ND MERPS11-15215
3746-MERP12-12120S-ND MERP12-12120S
3746-MER12-24N224RE-ND MER12-24N224RE
3746-MERP12-12P126M9GR-ND MERP12-12P126M9GR
3746-MERP11-15120BM7-ND MERP11-15120BM7
3746-MERP12-12P125-ND MERP12-12P125
3746-MERP12-12P126GR-ND MERP12-12P126GR
3746-MERP12-24126M9GR-ND MERP12-24126M9GR
3746-MERP11-15520A-ND MERP11-15520A
3746-MER12-24N224WHR-ND MER12-24N224WHR
3746-MERP12-24225M9GR-ND MERP12-24225M9GR
3746-MERP12-24N225M-ND MERP12-24N225M
3746-MERP12-24118.5M-ND MERP12-24118.5M
3746-MERP12-24126M9BG-ND MERP12-24126M9BG
3746-MERP12-24125-ND MERP12-24125
3746-MERP11-15420BM7-ND MERP11-15420BM7
3746-MERP12-24225M-ND MERP12-24225M
3746-MERP11-15225A-ND MERP11-15225A
3746-MERP11-15125B-ND MERP11-15125B
3746-MERP12-24225OB-ND MERP12-24225OB
3746-MERP11-20415A-ND MERP11-20415A
3746-MERP11-15325B-ND MERP11-15325B
118-PEL12T-4225T-S1024-ND PEL12T-4225T-S1024
26AS22-01-1-08S-ND 26AS22-01-1-08S
513374-12-C-ND 513374-12-C
1882-6028626-ND 6028626
2266-PEC12R-2120F-N0012-ND,PEC12R-2120F-N0012-ND PEC12R-2120F-N0012
2266-PEC12R-2130F-S0012-ND,PEC12R-2130F-S0012-ND PEC12R-2130F-S0012
25BSR22-G-1-16C-ND 25BSR22-G-1-16C
2266-513360-10-ND,513360-10-ND 513360-10
2266-25BSP22-G-1-08-ND,25BSP22-G-1-08-ND 25BSP22-G-1-08
2266-25BP45-Q-2-08C-ND,25BP45-Q-2-08C-ND 25BP45-Q-2-08C
GH7299-ND 25LB22-G
PEC12R-4230F-S0024-ND PEC12R-4230F-S0024
1528-5454-ND 5454
732-482012714003-ND 4.82013E+11
119-12CE3H26F12T24-ND 12CE3H26F12T24
GH7647-ND 513384
119-11CEK25F243A-ND 11CEK25F243A
119-11CEY25F243A-ND 11CEY25F243A
ECW1D-R24-BC0024L-ND ECW1D-R24-BC0024L
1528-5735-ND 5735
1528-5734-ND 5734
5010600-ND 5010600
3. Optical Rotary Encoders:
An optical encoder is a motion sensing device that utilizes light to convert mechanical motion into electrical pulse signals. They detect rotational positions using optical principles and typically consist of an optical encoding disc, optical sensor devices, and reading circuits.
The circular optical encoding disk is mounted on the rotating component, with optical patterns or lines engraved on it.
As the rotating component moves, the optical signals on the optical encoding disc change. Sensors detect these signal changes. The signals are then processed by a reading circuit, which convert them into angle or position information. The circuit decodes this data to give the precise position of the rotating component.
Advantages:
  • Optical Rotary Encoders offers high accuracy and high resolution
  • They provide good immunity to magnetic and electromagnetic interference.
  • Optical Rotary Encoders consume less power, offer high reliability and have a long lifespan.
Application:
  • Optical Rotary Encoders are suitable for systems that require high-precision, accuracy, and reliability such as,
    Aerospace and Defense System: aircraft control systems, missile guidance systems, and satellite positioning systems require precise feedback for position, speed, and orientation control
    Industrial Automation & Control Systems: accurate position feedback for Robotics, motion control relay, process control, and material handling equipment.
    CNC Machines and Machine Tools: accurate feedback for position, speed, and direction control.
Optical Rotary Encoders from Digikey
Applicable Part Numbers
DigiKey Part Number Manufacturer Part Number
CT3042-ND 291V1022F624AB
CT3044-ND 291V1022F832AB
119-292V1X24B-ND 292V1X24B
516-3036-ND HEDS-9720#P50
516-3034-ND HEDS-9700#H50
GH6101-ND 61C22-01-04-02
516-3187-2-ND,516-3187-1-ND,516-3187-6-ND AEDR-8710-102
516-3953-2-ND,516-3953-1-ND,516-3953-6-ND AEDR-8711-102
EM14A1D-C24-L032S-ND EM14A1D-C24-L032S
516-2028-ND HEDS-9040#B00
516-AEDR-9830-100TR-ND,516-AEDR-9830-100CT-ND,516-AEDR-9830-100DKR-ND AEDR-9830-100
516-AEDR-9920-102TR-ND,516-AEDR-9920-102CT-ND,516-AEDR-9920-102DKR-ND AEDR-9920-102
516-3186-2-ND,516-3186-1-ND,516-3186-6-ND AEDR-8723-102
GH7392-ND 62A22-02-P
GH7384-ND 62A11-02-P
GH7396-ND 62S11-M5-P
GH6102-ND 61C11-01-08-02
ENA1J-B28-L00128L-ND ENA1J-B28-L00128L
516-3030-ND HEDS-9040#T00
ENS1J-B28-L00256L-ND ENS1J-B28-L00256L
516-2115-ND HRPG-ASCA#14R
516-HRPG-ASCA#16R-ND HRPG-ASCA#16R
516-2019-ND HEDS-5500#A06
516-3647-ND HEDS-5600#A13
516-2400-ND HEDS-5500#E06
516-2022-ND HEDS-5540#A06
516-1887-ND HEDS-5600#C06
516-3024-ND HEDS-5500#A14
516-2764-ND HEDS-5600#E06
GH3065-ND 61K128
GH7696-ND 62C2222-02-P
GH7382-ND 63R64
119-292V1X24A-ND 292V1X24A
516-3651-ND HEDS-9730#Q50
119-292V1X00B-ND 292V1X00B
102-1923-ND C14D32P-A3
102-1918-ND C14N32P-C3
516-3508-ND HEDR-5420-ES214
EM14A1D-C24-L032N-ND EM14A1D-C24-L032N
516-AEDR-9820-102TR-ND,516-AEDR-9820-102CT-ND,516-AEDR-9820-102DKR-ND AEDR-9820-102
516-3954-2-ND,516-3954-1-ND,516-3954-6-ND AEDR-8712-102
516-2029-ND HEDS-9100#A00
ENA1D-B28-L00128L-ND ENA1D-B28-L00128L
516-2405-ND HEDS-9100#C00
516-2769-ND HEDS-9100#F00
GH7404-ND 62S22-M5-P
GH7400-ND 62S15-M5-P
118-ENC1J-D28-L00256L-ND ENC1J-D28-L00256L
GH7843-ND 62S15-M0-PH
516-4151-ND AEDB-9340-B13C
516-2025-ND HEDS-5640#A06
516-2402-ND HEDS-5540#A11
516-2021-ND HEDS-5505#A06
516-2434-ND HRPG-AD32#16F
516-3639-ND HEDM-5500#B12
516-2763-ND HEDS-5540#H14
GH3070-ND 63R256
GH3067-ND 61R64
GH7381-ND 61R256
GH7836-ND 62H2222-H9-P
516-3520-ND HEDS-9700#E50
516-HEDS-9700-C54-ND HEDS-9700-C54
516-HEDS-9701-E50-ND HEDS-9701-E50
516-3522-ND HEDS-9731#B50
516-3519-ND HEDS-9700#D50
516-3650-ND HEDS-9730#A50
EM14A0D-C24-L032N-ND EM14A0D-C24-L032N
102-1911-ND C14N32N-A3
CT3041-ND 291C6022F624AB
118-EM14R1D-R20-L032N-ND EM14R1D-R20-L032N
EM14A1D-C24-L008S-ND EM14A1D-C24-L008S
516-2406-ND HEDS-9100#E00
102-1908-ND C14D16P-C3
102-2032-ND C14D32P-A3A
EM14A0D-C24-L032S-ND EM14A0D-C24-L032S
118-EM14R0B-M25-L064N-ND EM14R0B-M25-L064N
118-EM14A1B-C24-L032S-ND EM14A1B-C24-L032S
516-2770-ND HEDS-9100#G00
GH7812-ND 61C11-01-08-01
516-3509-ND HEDR-5421-EP111
516-2407-ND HEDS-9100#I00
516-2767-ND HEDS-9000#B00
516-2030-ND HEDS-9100#B00
516-3457-ND AEDT-9810-W00
516-2756-ND HEDS-5500#A13
516-2771-ND HEDS-9140#G00
516-2768-ND HEDS-9040#J00
516-3032-ND HEDS-9140#H00
ENA1P-B28-L00128L-ND ENA1P-B28-L00128L
516-2401-ND HEDS-5500#I06
516-2018-ND HEDM-5500#B06
516-3944-ND HRPG-ASCA#54F
GH3069-ND 63R128
ENS1J-B28-L00064L-ND ENS1J-B28-L00064L
ENS1J-B28-L00128L-ND ENS1J-B28-L00128L
ENT1J-D28-L00100L-ND ENT1J-D28-L00100L
516-2020-ND HEDS-5500#A11
516-2593-ND HEDS-5500#A05
516-2024-ND HEDS-5605#A06
516-3646-ND HEDS-5540#A02
516-3653-ND HRPG-AD32#56R
516-2817-ND HRPG-AD32#13R
516-3277-ND AEDL-5810-Z12
ENT1D-D28-L00100L-ND ENT1D-D28-L00100L
516-3253-ND AEDM-5810-Z12
ENS1J-B20-L00256L-ND ENS1J-B20-L00256L
GH3068-ND 61R128
516-3649-ND HEDS-9701#F54
516-AEDR-8600-100TR-ND,516-AEDR-8600-100CT-ND,516-AEDR-8600-100DKR-ND AEDR-8600-100
2223-C14D32P-A2P-ND C14D32P-A2P
516-AEDR-8600-102TR-ND,516-AEDR-8600-102CT-ND,516-AEDR-8600-102DKR-ND AEDR-8600-102
EM14C0D-E24-L064S-ND EM14C0D-E24-L064S
2223-C14D16N-C3P-ND C14D16N-C3P
EM14R0B-M25-L064S-ND EM14R0B-M25-L064S
516-3514-ND HEDS-5505#A14
ES14A0D-E28-L064N-ND ES14A0D-E28-L064N
516-3250-ND AEDM-5810-T06
ENT1J-D28-L00128L-ND ENT1J-D28-L00128L
GH7694-ND 61B15-01-02
GH7846-ND 63K128
516-3652-ND HEDS-9731#A50
516-3035-ND HEDS-9701#C54
118-EM14R1A-R20-L008N-ND EM14R1A-R20-L008N
516-HEDS-9101#A00-ND HEDS-9101#A00
516-2589-ND HEDS-9140#F00
516-3517-ND HEDS-9140#I00
516-HRPG-ASCA#54R-ND HRPG-ASCA#54R
516-HRPG-ASCA#19F-ND HRPG-ASCA#19F
516-3940-ND HEDS-5500#G05
516-2591-ND HEDS-5500#F06
516-2762-ND HEDS-5540#C06
516-2765-ND HEDS-5645#H06
516-2758-ND HEDS-5500#C06
516-2307-ND HEDS-5540#I12
516-2753-ND HEDS-5500#A02
516-HRPG-AD32#16R-ND HRPG-AD32#16R
516-2751-ND HEDM-5500#B13
516-HEDS-5500#H14-ND HEDS-5500#H14
516-2761-ND HEDS-5540#A14
516-HEDS-5500#H05-ND HEDS-5500#H05
516-AR25-AS1P-A18T-ND AR25-AS1P-A18T
516-AEAT-84AD-LBSF0-ND AEAT-84AD-LBSF0
2266-61C00-01-04-02-ND,61C00-01-04-02-ND 61C00-01-04-02
2266-61B11-01-02-ND,61B11-01-02-ND 61B11-01-02
516-AR25-AB1B-A15T-ND AR25-AB1B-A15T
516-AR25-AS1B-A20T-ND AR25-AS1B-A20T
516-AR25-AS1B-A12T-ND AR25-AS1B-A12T
516-AR25-AS1B-A13T-ND AR25-AS1B-A13T
516-AR25-AS1B-A15T-ND AR25-AS1B-A15T
516-AR25-AB1B-A12T-ND AR25-AB1B-A12T
516-AR25-AB1B-A13T-ND AR25-AB1B-A13T
516-AR25-AB1B-A20T-ND AR25-AB1B-A20T
516-AR25-AB1B-A30T-ND AR25-AB1B-A30T
516-AR25-AS1B-A18T-ND AR25-AS1B-A18T
516-AR25-AS1P-A15T-ND AR25-AS1P-A15T
516-AR25-AS1P-A13T-ND AR25-AS1P-A13T
516-AR25-AB1P-A18T-ND AR25-AB1P-A18T
516-AR25-AS1P-A20T-ND AR25-AS1P-A20T
516-AR25-AB1P-A20T-ND AR25-AB1P-A20T
516-AR25-AS1P-A30T-ND AR25-AS1P-A30T
516-AR25-AB1P-A13T-ND AR25-AB1P-A13T
516-AR25-AB1P-A12T-ND AR25-AB1P-A12T
EM14R0D-R20-L064S-ND EM14R0D-R20-L064S
GH7838-ND 62H3030-H9-P
516-3633-ND AEAT-84AD-LBSC0
119-292V1X00A-ND 292V1X00A
102-1904-ND C14D16P-A3
GH7544-ND 62AG22-L5-P
EM14A0D-C24-L064N-ND EM14A0D-C24-L064N
62V11-02-P-ND 62V11-02-P
GH7698-ND 62V15-02-P
516-3634-ND AEDB-9140-A13
ENA1J-B28-L00100L-ND ENA1J-B28-L00100L
505-TMCS-40-10K-KIT-ND TMCS-40-10K-KIT
505-TMCS-28-10K-KIT-ND TMCS-28-10K-KIT
GH7765-ND GH65C11-N-SO
GH7555-ND 62AG11-L0-P
EM14R0D-R20-L032N-ND EM14R0D-R20-L032N
563-1952-ND REC16M25-201
563-1953-ND REC16K25-201
2223-C14D32P-A3P-ND C14D32P-A3P
EM14A0D-B28-L064N-ND EM14A0D-B28-L064N
EM14R0D-M20-L064S-ND EM14R0D-M20-L064S
EM14R0D-R20-L032S-ND EM14R0D-R20-L032S
EM14R1D-M20-L032S-ND EM14R1D-M20-L032S
EM14R1B-M20-L032S-ND EM14R1B-M20-L032S
ENC1J-D20-L00128L-ND ENC1J-D20-L00128L
516-3515-ND HEDS-5540#A13
516-2755-ND HEDS-5500#A12
516-2760-ND HEDS-5540#A12
GH7697-ND 62S11-M5-PH
ENA1J-B28-L00064L-ND ENA1J-B28-L00064L
ENA1J-B20-L00128L-ND ENA1J-B20-L00128L
GH7383-ND 62A11-01-P
118-ENS1J-B28-L00100L-ND ENS1J-B28-L00100L
516-3939-ND HEDM-5600#B13
516-3507-ND HEDM-5600#J06
505-TMCS-20-8K-KIT-ND TMCS-20-8K-KIT
GH7543-ND 62AG22-L0-P
118-EM14R0A-M25-L064S-ND EM14R0A-M25-L064S
118-EM14C1D-E24-L032S-ND EM14C1D-E24-L032S
EM14A1D-B24-L032S-ND EM14A1D-B24-L032S
365-FS210-ND FS210
365-FS310-ND FS310
118-EM14C0D-E28-L064N-ND EM14C0D-E28-L064N
EM14A0D-B28-L008S-ND EM14A0D-B28-L008S
ENA1J-B20-L00064L-ND ENA1J-B20-L00064L
516-3251-ND AEDM-5810-T12
516-3256-ND AEDT-9810-Z00
ENC1J-D28-L00064L-ND ENC1J-D28-L00064L
516-2403-ND HEDS-5540#I06
ENA1J-B20-L00100L-ND ENA1J-B20-L00100L
ENC1J-D28-L00100L-ND ENC1J-D28-L00100L
GH7388-ND 62A15-02-P
516-2759-ND HEDS-5540#A05
GH3064-ND 61K64
GH7848-ND 63R32
GH7850-ND 63RS64
563-1954-ND REC16K25-205-B
563-1955-ND REC16L25-205-B
563-2068-ND RES20-50-200
563-2071-ND RES20-100-200-Z
3746-MEOP19VGP24CM2F20.8PF3F-ND MEOP19VGP24CM2F20.8PF3F
3746-MEOP19VGP24CM2F22PF3F-ND MEOP19VGP24CM2F22PF3F
3746-MEOP19VGP24CM2F14.2PF3F-ND MEOP19VGP24CM2F14.2PF3F
516-3031-ND HEDS-9100#J00
516-2537-ND HEDS-9200#300
61C00-01-08-02-ND 61C00-01-08-02
62S45-H9-P-ND 62S45-H9-P
63KS256-ND 63KS256
516-AR25-AS1P-A12T-ND AR25-AS1P-A12T
2266-EM14C0D-E28-L016N-ND,EM14C0D-E28-L016N-ND EM14C0D-E28-L016N
2266-C14D32N-A3A-ND,102-2033-ND C14D32N-A3A
2266-61B22-01-01-ND,61B22-01-01-ND 61B22-01-01
2266-61B22-01-02-ND,61B22-01-02-ND 61B22-01-02
2266-61KS256-ND,61KS256-ND 61KS256
62F22-01-P-L-ND 62F22-01-P-L
2266-62R15-02-P-ND,GH7842-ND 62R15-02-P
516-AR25-AB1P-A15T-ND AR25-AB1P-A15T
2602-HS35R102483P2-ND HS35R102483P2
2602-HS35R10248172-ND HS35R10248172
2602-HS35R00601000-ND HS35R00601000
2602-HS35R10247172-ND HS35R10247172
2602-HS35R010081J5-ND HS35R010081J5
2602-AI25001221W2RTB-ND AI25001221W2R
2602-HS35R10004346-ND HS35R10004346
2602-HS35R03608005-ND HS35R03608005
2602-HS35R0600H110-ND HS35R0600H110
2602-HS35R10248347-ND HS35R10248347
2602-HS35R10248177-ND HS35R10248177
2602-HS35R102483P7-ND HS35R102483P7
2602-HS35R102481P7-ND HS35R102481P7
2602-AI2500122BW2RTB-ND AI2500122BW2R
2602-HS35R1024839401-ND HS35R1024839401
2602-HS35R0120D341-ND HS35R0120D341
2602-HS35R0500H37201-ND HS35R0500H37201
2602-HS35R1024K072-ND HS35R1024K072
2602-HS35R102484P2-ND HS35R102484P2
2602-HS35R10248442-ND HS35R10248442
2602-HS35R012073A1PS-ND HS35R012073A1PS
2602-HS35R1024F3P7-ND HS35R1024F3P7
2602-HS35R1024H3P7-ND HS35R1024H3P7
2602-HS35R50007156-ND HS35R50007156
2602-HS35R102484P7-ND HS35R102484P7
2602-HS35R10248577-ND HS35R10248577
2602-HS35R10007567-ND HS35R10007567
2602-HS35R102485P7-ND HS35R102485P7
2602-HS35R1024P141PS-ND HS35R1024P141PS
2602-HS35R20005362PS-ND HS35R20005362PS
2602-HS35R250084P2-ND HS35R250084P2
2602-HS35R5000H362-ND HS35R5000H362
2602-HS35R10248497-ND HS35R10248497
2602-HS35R2400A177-ND HS35R2400A177
2602-HS35R2048D357-ND HS35R2048D357
2602-HS35R1024H4P7-ND HS35R1024H4P7
2602-HS35R1024H5P7-ND HS35R1024H5P7
2602-HS35R5000H38201-ND HS35R5000H38201
2602-HS35R20486A7F-ND HS35R20486A7F
2602-HS35R2000E187-ND HS35R2000E187
2602-HS35R2000H367PS-ND HS35R2000H367PS
2602-HS35R1024H3E225-ND HS35R1024H3E225
2602-HS35R0060H1E2-ND HS35R0060H1E2
2602-HS35R1024K3E2-ND HS35R1024K3E2
2602-HS35R1000H1FE-ND HS35R1000H1FE
2602-HS35R2000H3E225-ND HS35R2000H3E225
2602-AI25001211W2RTB-ND AI25001211W2R
2602-AI25001212W2RTB-ND AI25001212W2R
2602-AI2500122CW2RTB-ND AI2500122CW2R
2602-AI2500121CW2RTB-ND AI2500121CW2R
2602-AI2500121BW2RTB-ND AI2500121BW2R
2602-AI25001233W2RTB-ND AI25001233W2R
2602-AI25001234W2RTB-ND AI25001234W2R
2602-AI25001821W2RTB-ND AI25001821W2R
2602-AI2500182BW2RTB-ND AI2500182BW2R
2602-AI2500162CW2RTB-ND AI2500162CW2R
2602-AI2500162BW2RTB-ND AI2500162BW2R
2602-AI25001835W2RTB-ND AI25001835W2R
2602-AI2500183EW2RTB-ND AI2500183EW2R
2602-AI25121200W2RTB-ND AI25121200W2R
2602-AI25121221W2RTB-ND AI25121221W2R
2602-AI2512121CW2RTB-ND AI2512121CW2R
2602-AI2512121BW2RTB-ND AI2512121BW2R
2602-AI2512122BW2RTB-ND AI2512122BW2R
2602-AI2512122CW2RTB-ND AI2512122CW2R
2602-AI25121235W2RTB-ND AI25121235W2R
2602-AI25121233W2RTB-ND AI25121233W2R
2602-AI25121812W2RTB-ND AI25121812W2R
2602-AI25121621W2RTB-ND AI25121621W2R
2602-AI25121421W2RTB-ND AI25121421W2R
2602-AI25121811W2RTB-ND AI25121811W2R
2602-AI25121821W2RTB-ND AI25121821W2R
2602-AI2512123EW2RTB-ND AI2512123EW2R
2602-AI2500202BW2RTB-ND AI2500202BW2R
2602-AI2512162BW2RTB-ND AI2512162BW2R
2602-AI2512131CW2RTB-ND AI2512131CW2R
2602-AI2512181CW2RTB-ND AI2512181CW2R
2602-AI2512181BW2RTB-ND AI2512181BW2R
2602-AI25002033W2RTB-ND AI25002033W2R
2602-AI25121835W2RTB-ND AI25121835W2R
2602-AI25121635W2RTB-ND AI25121635W2R
2602-AI2512183EW2RTB-ND AI2512183EW2R
2602-AI2500122BW2RSSTB-ND AI2500122BW2RSS
2602-AI2512220AW2RTB-ND AI2512220AW2R
2602-AI2512122BW2RSSTB-ND AI2512122BW2RSS
2602-AI2512182CW2RSSTB-ND AI2512182CW2RSS
2602-AI2512222CW2RSSTB-ND AI2512222CW2RSS
516-1888-ND HEDS-9140#A00
ENC1J-D28-L00128L-ND ENC1J-D28-L00128L
GH7387-ND 62A15-01-P
GH7403-ND 62S22-M0-P
62D11-02-P-ND 62D11-02-P
4. Capacitive Rotary Encoders:
Capacitive rotary encoders are sensors that detect rotational positions by measuring changes in capacitance. They typically consist of a fixed capacitance array, a rotating capacitance disc, and reading circuits.
The fixed capacitance array is a group of capacitances, attached on stationary part, and the rotating disc is a capacitor mounted on the rotating component. Its capacitance changes with rotation. As the rotating capacitance disc turns, the capacitance value between the fixed capacitance array changes with the rotation position. The reading circuit measures the changes in capacitance value to determine the angle or position information of the rotating component.
Advantages:
  • Capacitive rotary encoders can detect very small rotational movements, making them perfect for precision tasks.
  • They are resistant to magnetic and electromagnetic interference.
  • These encoders use less power and are smaller, so they can fit easily into compact devices and systems.
  • Some capacitive encoders can be programmed to adjust to different tasks through settings and calibration.
Applications:
  • For precise control of rotation, these encoders can be used in various machines such as CNC machines, robots, and servo motors
  • Their high resolution and smooth operation make them great for high-end audio equipment.
  • In medical devices like CT scanners and MRI machines, these encoders provide the precision needed for accurate imaging.
Capacitive Rotary Encoders from Digikey
2223-AMT11A2Q-V-ND AMT11A2Q-V
2223-AMT11A2S-V-ND AMT11A2S-V
2223-AMT11A3S-V-ND AMT11A3S-V
2223-AMT11A3Q-V-ND AMT11A3Q-V
Consideration for selecting a rotary encoder:
Rotary encoders come in different types, so when selecting a sensor, consider the following factors: application requirements, environmental conditions, and budget and performance needs.
Start by determining the accuracy and speed required. Some encoders perform better for high-speed tasks, while others offer precise measurements at lower speeds.
You should think about the environment where the encoder will be used, then choose an encoder that can handle factors like temperature, humidity, and vibration and offers protection against interference if necessary. Make sure it can be installed easily by checking the available space and mounting options.
When making your decision, balance cost and performance. Consider not only the initial price but also ongoing maintenance expenses. Some advanced encoders come with communication features that allow them to connect with other devices, adding more functionality. Finally, choosing a well-known brand can provide better reliability, quality, and customer support.
Conclusion:
Rotary encoders can be used in many applications, from industrial automation to medical equipment.
They offer precision, reliability, and versatility, and enable accurate positioning, speed control, and motion tracking. when selecting rotary encoders, attention should be paid to factors such as accuracy, speed requirements, environmental factors, installation methods, communication interfaces, cost-effectiveness, brand reputation, and reliability. By understanding the different types of rotary encoders and their applications can help you choose the right encoder for your specific needs.
More related article:
Rotary Encoders Digitize Mechanical Position | DigiKey
Hello… I a looking for a digital rotary encoder. Not able to find it on the site. I can find mechanical encoders but not digital ones. The one I am looking for looks like the attached.
Thank you.
ramzi
Thank you for contacting DigiKey , sorry I am not seeing that we have any like that to offer .
Thanks Craig
What you have pictured is a mechanical quadrature encoder with built in switch installed on a circuit board with a few pull up resistors installed. I’m not seeing that we have any encoders with these resistors installed on a circuit board.
For what it’s worth Velleman didn’t do a great job designing that circuit, the optimal filter circuitry would look more like this suggested circuit from Bourns:
Absolutely invaluable advice/guidance. Thank you so much.
Perhaps I should have started with my purpose. I am trying to build a control console for a model train turntable. The digital board is by Walthers “Advanced Control Module” 933-2321. In their manual they describe the use of a digital rotary encoder to control the turntable (see below). Would you be able to guide me as to my best product option. I am willing to try and build it from individual parts you may suggest if that is my only option.
Building this with individual components wouldn’t be easy or convenient. Encoders typically do not drop into a perforated circuit board nicely.
If you are following those instructions the best thing would be to find that Velleman board or something similar, unfortunately we just do not have it.
I would suggest doing a Google Search for terms " KY-040 Rotary Encoder Module Knob" for an example of something similar to your Digital Rotary Encoder project
The “digital” term highlighted is a reference to a set of signals that wiggle in a quadrature format as described above.
“Mechanical” is a reference to one of numerous techniques for generating such signals. The two concepts are related, but very much different.
The control board in question couldn’t care less whether the quadrature signals are generated mechanically, optically, magnetically, or otherwise; quadrature signals from most any source will do. This might be a reasonable short list to select from.
Good morning…
Just found this on your website. EAW0J-B24-BE0128L. They also have it in 24PPR. Would that fit your comment about “optimal filter circuitry”
Thank you so much again.
Your example encoder is an Absolute Contacting Encoder.
It would need eight pull up resistors and take up 8 inputs on a microcontroller.
If you’re looking at using pre-programmed example code that was created for a quadrature encoder it’s not going to work with this.
Below is the schematic for EAW0J-B24-BE0128L
Thank you so much for this. I went back to the board manufacture that I am trying to connect to asking for more information on the digital rotary encoder specifications that would work with their board. Thank you again for all your guidance on this.
I want to know about the lifetime rotations of the AMT112Q-4096-5000-S encoder
Helli @npdelectronics,
The answer depends on the application.
Note that the AMT112Q-4096-5000-S encoder is designed for high-speed (4000 RPM) motor use. There is no internal contact between the rotating and fixed parts.
Dominant failure modes likely to include vibration, shock, stress in the connection wires, voltage surges, and failure of the motor bearings (e.g. shaft play).
This is implied in the datasheet as:
vibration: 10~500 Hz, 5 minute sweep, 2 hours on each XYZ 5 G
shock: 3 pulses, 6 ms, 3 on each XYZ 200 G
Best wishes,
