RT33K (TE/Schrack) current capacity
I am looking at the data sheet of the high inrush current relay RT33K024. Does this relay have an inrush current of 80A, or is it only the RT33L version that has this capacity?
I would also like to have the relay sealed. Are there other specifications for RTD3L024? The data sheet for this particular part on the DigiKey site does not mention it.
BR
Based on what TE Connectivity’s website is saying for this part it is looking like the current specifications would be the same as RT33L
Greetings,
Regarding the sealed rating this is defined in the part number scheme. This option called out being flux proof for the seal rating.
Version
3 16A, pinning 5mm, flux proof
D 16A, pinning 5mm, sealed
