S502M39Z5UN63L6R-ND Size Variance
MFR PART # S502M39Z5UN63L6R
DIGIKEY PART # S502M39Z5UN63L6R-ND
MANUFACTURER Vishay Beyschlag/Draloric/BC Components
DESCRIPTION 5000 pF ±20% 1000V (1kV) Ceramic Capacitor Z5U Radial, Disc
DATASHEET Click Here
Explanation of the Perceived Issue
A customer had reported that they received a disc that was larger than what they thought was typical for this kind of ceramic capacitor. The initial datasheet linked above does not cover sizing, so they wondered if they received the right part.
Variance in Sizes: Documentation Location
The data for the size code is located elsewhere. First, you have to visit Vishay’s “S-Series” Page:
S-Series Product Page
In the list of documents, you will want to click the PDF next to the column that says “General Information:” (you can click the image to follow the link)
This document contains information that implies that there is a range of diameters the part might have and that the voltage rating does not necessarily change in the main datasheet.
The main one does state that rated voltage is 1kV. Size variation should not impact performance.
