Samsung capacitors
I have a question about the “Mounting Type” listing for Samsung part number CL32Y226KAVVPNE. It states “Surface Mount, MLCC, Epoxy”. Does this mean the part needs to be installed using conductive epoxy or can it be soldered?
Greetings,
Devices listed as epoxy-mountable are adapted for an adhesive-based assembly process, and are not recommended for use in the more typical solder-based processes. This post has further information on the topic.
