SCAP,PBLS-1.0/27 supercapacitor
SCAP,PBLS-1.0/27 supercapacitor -
is there a connector/adaptor to connect these in series? it has 4 cables connected to a 4 pin connector.
Hello Pawor,
Thank you for your inquiry and welcome to the community.
The connector housing used on the SCAP,PBLS-1.0/27 supercap is Molex Part Number 874390400
The manufacturer’s mating connectors for this housing are intended to be mounted on a circuit board, They can be found by clicking here
Thank you. i have ordered Morlex 4 Rectangular Connectors - Housings Receptacle as suggested… if worst I can chop the cable and put in a connector block and join them.
I am sorry, there is not a direct way to connect 4 in series. No adapter made for that.
