103AT-2 from Semitec Is a thermistor that we do not carry, BC2907-ND Is a thermistor we carry with similar specks.
| BC2907-ND | 954-103AT-2 | |
| Packaging | Bulk | Bulk |
| Resistance in Ohms @ 25°C | 10KOhm | 10KOhm |
| Resistance Tolerance | +/-1% | +/-1% |
| B Value Test Range | 25-85C | B25/85C |
| B Value | 4013K | 3435K |
| B Value Tolerance | +/-1% | +/-1% |
| Mounting Type | Through Hole | Through Hole |
| Package Case | Radial | Radial |
| Length | 17mm | 17mm |
| Operating Temperature | -40C - 125C | -50C - 110C |
For more information on BC2907-ND, check out the datasheet.
