I used the DigiKey provided footprint and symbol for the Diotec GBU6A bridge rectifier and found out after powering up the PCB that it has a serious flaw that will cause the part to catch on fire. The footprint and symbol show pins 3 & 4 as the inputs, however if you look into the datasheet it shows the inputs to be 2 & 3. I assumed the footprint and symbol had been vetted, so did not compare to the datasheet. It appears that footprint and symbol are also incorrect on the Diotech site.
erik.ingermann
Thank you for contacting DigiKey , I have sent this info to the product specialist to get the correct info from the manufacturer and get the web site updated .
Thanks Craig
