What is the shelf life for SCS static shielding bags?
Per SCS:
“SCS Static Control Bags do not have a set life span. For best results, bag inventory should be
continually replenished. We recommended that bags be stored in their original packaging. The
user must determine the suitability of a static control bag for use in his particular application.
Bags should be stored in a dry, well ventilated room with a reasonably consistent temperature
of 68°F (20°C) and be protected from exposure to direct sunlight. Bags should not be stored
in ultraviolet sunlight, moisture, or heat because the aluminum shielding layer could oxidize if
exposed to these conditions. Mishandling or improper storage may render a static control bag
unable to perform its function. Static control bags that are ripped, torn, or scratched should be
discarded. SCS, Desco Industries Inc., recommends those who are tracking the useful life of
product use the shipping/invoice date as a reference.”
SCS_Bag_Storage.pdf (157.6 KB)
SCS Bag Part Numbers
| Description | Digikey Part Number | Manufacturer Part Number |
| 6.5X10 STATIC SHIELD BAG 1=1EA | 1006.51-ND | 1006.51 |
| BAG 10X12 SHIELDED ZIPLOCK | SCP170-ND | 1911012 |
| BAG 10X12" MOIST BARRIER 1=1EA | SCP363-ND | D271012 |
| BAG 10X12" MOIST BARRIER 1=1EA | SCP513-ND | D341012 |
| BAG 10X12" STATIC SHIELD 1=1EA | SCP399-ND | 1001012 |
| BAG 10X14 SHIELDED ZIPLOCK | 1911014-ND | 1911014 |
| BAG 10X14" STATIC SHIELD 1=1EA | SCP365-ND | 1001014 |
| BAG 10X16" STATIC SHIELD 1=1EA | SCP410-ND | 1001016 |
| BAG 10X18" STATIC SHIELD 1=1EA | SCP361-ND | 1001018 |
| BAG 10X20" MOIST BARRIER 1=1EA | SCP385-ND | 7001020 |
| BAG 10X20" MOIST BARRIER 1=1EA | SCP376-ND | D271020 |
| BAG 10X24" MOIST BARRIER 1=1EA | SCP418-ND | 7001024 |
| BAG 10X24" STATIC SHIELD 1=1EA | SCP346-ND | 1001024 |
| BAG 10X30" STATIC SHIELD 1=1EA | SCP378-ND | 1001030 |
| BAG 11X14" STATIC SHIELD 1=1EA | SCP367-ND | 1001114 |
| BAG 11X15" STATIC SHIELD 1=1EA | SCP375-ND | 1001115 |
| BAG 11X15" ZIP STATIC SHLD 1=1EA | SCP389-ND | 3001115 |
| BAG 12X12" STATIC SHIELD 1=1EA | SCP391-ND | 1001212 |
| BAG 12X12" ZIP STATIC SLD 1=1EA | SCP370-ND | 3001212 |
| BAG 12X14" STATIC SHIELD 1=1EA | SCP377-ND | 1001214 |
| BAG 12X16 SHIELDED ZIPLOCK 1=1EA | SCP171-ND | 1911216 |
| BAG 12X16" MOIST BARRIER 1=1EA | SCP514-ND | D341216 |
| BAG 12X16" STATIC SHIELD 1=1EA | SCP396-ND | 1001216 |
| BAG 12X16" ZIP STATIC SHLD 1=1EA | SCP388-ND | 3001216 |
| BAG 12X18" MOIST BARRIER 1=1EA | SCP351-ND | 7001218 |
| BAG 12X24" STATIC SHIELD 1=1EA | SCP406-ND | 1001224 |
| BAG 12X30" STATIC SHIELD 1=1EA | SCP366-ND | 1001230 |
| BAG 14X16" STATIC SHIELD 1=1EA | SCP381-ND | 1001416 |
| BAG 14X18" ZIP STATIC SHLD 1=1EA | SCP423-ND | 3001418 |
| BAG 15X18" STATIC SHIELD 1=1EA | SCP411-ND | 1001518 |
| BAG 16X18" STATIC SHIELD 1=1EA | SCP353-ND | 1001618 |
| BAG 16X20" STATIC SHIELD 1=1EA | SCP395-ND | 1001620 |
| BAG 16X24" STATIC SHIELD 1=1EA | SCP354-ND | 1001624 |
| BAG 17X19" MOIST BARRIER 1=1EA | SCP364-ND | 7001719 |
| BAG 18X18" MOIST BARRIER 1=1EA | SCP415-ND | 7001818 |
| BAG 18X18" STATIC SHIELD 1=1EA | SCP380-ND | 1001818 |
| BAG 18X20" STATIC SHIELD 1=1EA | SCP420-ND | 1001820 |
| BAG 18X24" STATIC SHIELD 1=1EA | SCP371-ND | 1001824 |
| BAG 18X30" STATIC SHIELD 1=1EA | SCP373-ND | 1001830 |
| BAG 20X20" MOIST BARRIER 1=1EA | SCP515-ND | D342020 |
| BAG 24X24" STATIC SHIELD 1=1EA | SCP425-ND | 1002424 |
| BAG 24X24" ZIP STATIC SHLD 1=1EA | SCP422-ND | 3002424 |
| BAG 24X30" STATIC SHIELD 1=1EA | SCP386-ND | 1002430 |
| BAG 24X36" STATIC SHIELD 1=1EA | SCP407-ND | 1002436 |
| BAG 2X3" STATIC SHIELD 1=1EA | SCP379-ND | 10023 |
| BAG 2X3" ZIP STATIC SHIELD 1=1EA | SCP403-ND | 30023 |
| BAG 2X6" STATIC SHIELD 1=1EA | SCP362-ND | 10026 |
| BAG 3"X5" STATIC SHIELD 1=100 PC | SCP193-ND | 21035 |
| BAG 30X24" STATIC SHIELD 1=1EA | SCP374-ND | 1003024 |
| BAG 3X3" ZIP STATIC SHIELD 1=1EA | SCP404-ND | 30033 |
| BAG 3X5 SHIELDED ZIP LOCK | SCP165-ND | 19135 |
| BAG 3X5" MOISTURE BARRIER 1=1EA | SCP402-ND | 70035 |
| BAG 3X5" ZIP STATIC SHIELD 1=1EA | SCP417-ND | 30035 |
| BAG 4"X6" STATIC SHIELD 1=100 PC | SCP194-ND | 21046 |
| BAG 4X12" MOISTURE BARRIER 1=1EA | SCP506-ND | D34412 |
| BAG 4X24" MOISTURE BARRIER 1=1EA | SCP401-ND | 700424 |
| BAG 4X30" STATIC SHIELD 1=1EA | SCP350-ND | 100430 |
| BAG 4X4" STATIC SHIELD 1=1EA | SCP413-ND | 10044 |
| BAG 4X4" ZIP STATIC SHIELD 1=1EA | SCP347-ND | 30044 |
| BAG 4X6 SHIELDED ZIP LOCK 1=1EA | SCP166-ND | 19146 |
| BAG 4X6" MOISTURE BARRIER 1=1EA | SCP414-ND | 70046 |
| BAG 4X6" MOISTURE BARRIER 1=1EA | SCP504-ND | D3446 |
| BAG 4X6" MOISTURE BARRIER 1=1EA | SCP505-ND | D3446A9623 |
| BAG 4X8" STATIC SHIELD 1=1EA | SCP352-ND | 10048 |
| BAG 5"X8" STATIC SHIELD 1=100 PC | SCP195-ND | 21058 |
| BAG 5X10" STATIC SHIELD 1=1EA | SCP424-ND | 100510 |
| BAG 5X30" MOISTURE BARRIER 1=1EA | SCP419-ND | 700530 |
| BAG 5X6" STATIC SHIELD 1=1EA | SCP383-ND | 10056 |
| BAG 5X7" STATIC SHIELD 1=1EA | SCP390-ND | 10057 |
| BAG 5X8 SHIELDED ZIP LOCK | SCP167-ND | 19158 |
| BAG 5X8" MOISTURE BARRIER 1=1EA | SCP509-ND | D3458 |
| BAG 6"X10" STATIC SHIELD 1=100 | SCP196-ND | 210610 |
| BAG 6X10 SHIELDED ZIP LOCK 1=1EA | SCP168-ND | 191610 |
| BAG 6X12" STATIC SHIELD 1=1EA | SCP400-ND | 100612 |
| BAG 6X14" STATIC SHIELD 1=1EA | SCP393-ND | 100614 |
| BAG 6X16" STATIC SHIELD 1=1EA | SCP368-ND | 100616 |
| BAG 6X18" STATIC SHIELD 1=1EA | SCP349-ND | 100618 |
| BAG 6X24" MOISTURE BARRIER 1=1EA | SCP359-ND | 700624 |
| BAG 6X24" STATIC SHIELD 1=1EA | SCP360-ND | 100624 |
| BAG 6X30" MOISTURE BARRIER 1=1EA | SCP397-ND | 700630 |
| BAG 6X30" MOISTURE BARRIER 1=1EA | SCP511-ND | D34630 |
| BAG 6X30" STATIC SHIELD 1=1EA | SCP409-ND | 100630 |
| BAG 6X8" MOISTURE BARRIER 1=1EA | SCP412-ND | 70068 |
| BAG 6X8" STATIC SHIELD 1=1EA | SCP369-ND | 10068 |
| BAG 6X8" ZIP STATIC SHIELD 1=1EA | SCP356-ND | 30068 |
| BAG 7" X 15" STATIC SHIELD 1=1EA | SCP200-ND | 210715 |
| BAG 7X10" STATIC SHIELD 1=1EA | SCP348-ND | 100710 |
| BAG 7X11" STATIC SHIELD 1=1EA | SCP387-ND | 100711 |
| BAG 7X15" STATIC SHIELD 1=1EA | SCP394-ND | 100715 |
| BAG 7X15" ZIP STATIC SHLD 1=1EA | SCP421-ND | 300715 |
| BAG 7X8" STATIC SHIELD 1=1EA | SCP355-ND | 10078 |
| BAG 81705 SHLD METAL-IN 2.25X20 | 1569-8172.252-ND | 8172.252 |
| BAG 8X10 SHIELDED ZIP LOCK | SCP169-ND | 191810 |
| BAG 8X10" MOISTURE BARRIER 1=1EA | SCP372-ND | 700810 |
| BAG 8X10" MOISTURE BARRIER 1=1EA | SCP512-ND | D34810 |
| BAG 8X10" STATIC SHIELDING | SCP201-ND | 210810 |
| BAG 8X12" MOISTURE BARRIER 1=1EA | SCP384-ND | 700812 |
| BAG 8X18" STATIC SHIELD 1=1EA | SCP405-ND | 100818 |
| BAG 8X24" STATIC SHIELD 1=1EA | SCP398-ND | 100824 |
| BAG 8X30" STATIC SHIELD 1=1EA | SCP358-ND | 100830 |
| BAG 8X8" STATIC SHIELD 1=1EA | SCP392-ND | 10088 |
| BAG 8X8" ZIP STATIC SHIELD 1=1EA | SCP357-ND | 30088 |
| BAG 9X12" STATIC SHIELD 1=1EA | SCP408-ND | 100912 |
| BAG 9X12" ZIP STATIC SHLD 1=1EA | SCP416-ND | 300912 |
| BAG MOIST BAR DUAL LAYER 27.5X7" | 700727.5-ND | 700727.5 |
| BAG MOIST BARR DUAL 18X12 1=1EA | SCP631-ND | D271218 |
| BAG MOIST BARR DUAL LAYER 10X10" | 7001010-ND | 7001010 |
| BAG MOIST BARR DUAL LAYER 18X19" | 7001918-ND | 7001918 |
| BAG MOIST BARR DUAL LAYER 20X18" | 7001820-ND | 7001820 |
| BAG MOIST BARR DUAL LAYER 24X10" | SCP602-ND | D271024 |
| BAG MOIST BARR DUAL LAYER 24X19" | SCP605-ND | D271924 |
| BAG MOIST BARR DUAL LAYER 24X20" | D272024-ND | D272024 |
| BAG MOIST BARR DUAL LAYER 26"X6" | 700626-ND | 700626 |
| BAG MOIST BARR DUAL LAYER 27X23" | 7002327-ND | 7002327 |
| BAG MOIST BARR DUAL LAYER 28"X8" | 700828-ND | 700828 |
| BAG MOIST BARR DUAL LAYER 28X20" | 7002028-ND | 7002028 |
| BAG MOIST BARR DUAL LAYER 30X12" | 7001230-ND | 7001230 |
| BAG MOIST BARR DUAL LAYER 30X12" | D271230-ND | D271230 |
| BAG MOIST BARR DUAL LAYER 30X18" | 7001830-ND | 7001830 |
| BAG MOIST BARR DUAL LAYER 30X21" | 7002130-ND | 7002130 |
| BAG MOIST BARR DUAL LAYER 30X24" | SCP607-ND | D272430 |
| BAG MOIST BARR DUAL LAYER 32X32" | SCP608-ND | D273232 |
| BAG MOIST BARR DUAL LAYER 36X14" | D271436-ND | D271436 |
| BAG MOIST BARR MTL IN 15.125X12" | D301215.125-ND | D301215.125 |
| BAG MOIST BARR MTL IN 17.5X16.5" | D3716.517.5-ND | D3716.517.5 |
| BAG MOIST BARR MTL IN 20.5X15.5" | D3015.520.5-ND | D3015.520.5 |
| BAG MOIST BARR MTLIN 10X8 1=1EA | SCP636-ND | D30810 |
| BAG MOIST BARR MTLIN 12X10 1=1EA | SCP634-ND | D301012 |
| BAG MOIST BARR MTLIN 20X18 1=1EA | SCP637-ND | D341820 |
| BAG MOISTUR BARRIER 12X16" 100PK | 3371216-ND | 3371216 |
| BAG MOISTUR BARRIER 16X18" 100PK | 3371618-ND | 3371618 |
| BAG MOISTURE BAR DUAL LAYER 20X8 | SCP609-ND | D27820 |
| BAG MOISTURE BAR DUAL LAYER 26X6 | D27626-ND | D27626 |
| BAG MOISTURE BAR DUAL LAYER 9X7" | 70079-ND | 70079 |
| BAG MOISTURE BAR MTL IN 18.75X23 | D372318.75-ND | D372318.75 |
| BAG MOISTURE BAR MTL IN 24"X24" | D372424-ND | D372424 |
| BAG MOISTURE BAR MTL IN 30"X24" | D372430-ND | D372430 |
| BAG MOISTURE BARR 10"X20" 1=1EA | SCP501-ND | D341020 |
| BAG MOISTURE BARR 10"X30" 1=1EA | SCP502-ND | D341030 |
| BAG MOISTURE BARR 10X8 1=1EA | SCP633-ND | D27810 |
| BAG MOISTURE BARR 12"X16" 1=1EA | D271216-ND | D271216 |
| BAG MOISTURE BARR 14.25"X10.25" | D3410.2514.25-ND | D3410.2514.25 |
| BAG MOISTURE BARR 15"X18" 1=1EA | SCP603-ND | D271518 |
| BAG MOISTURE BARR 16"X18" 1=1EA | SCP503-ND | D341618 |
| BAG MOISTURE BARR 18X18 1=1EA | SCP632-ND | D271818 |
| BAG MOISTURE BARR MTL IN 10"X9" | D30910-ND | D30910 |
| BAG MOISTURE BARR MTL IN 12"X9" | SCP624-ND | D34912 |
| BAG MOISTURE BARR MTL IN 14"X9" | D30914-ND | D30914 |
| BAG MOISTURE BARR MTL IN 15"X10" | D371015-ND | D371015 |
| BAG MOISTURE BARR MTL IN 15"X11" | D301115-ND | D301115 |
| BAG MOISTURE BARR MTL IN 15"X11" | D371115-ND | D371115 |
| BAG MOISTURE BARR MTL IN 15"X13" | SCP619-ND | D341315 |
| BAG MOISTURE BARR MTL IN 16"X10" | SCP618-ND | D341016 |
| BAG MOISTURE BARR MTL IN 16"X12" | D371216-ND | D371216 |
| BAG MOISTURE BARR MTL IN 18"X11" | D301118-ND | D301118 |
| BAG MOISTURE BARR MTL IN 18"X15" | SCP626-ND | D371518 |
| BAG MOISTURE BARR MTL IN 18"X16" | SCP627-ND | D371618 |
| BAG MOISTURE BARR MTL IN 18"X18" | SCP612-ND | D301818 |
| BAG MOISTURE BARR MTL IN 18"X18" | D34Z1818-ND | D34Z1818 |
| BAG MOISTURE BARR MTL IN 18X8.5" | D308.518-ND | D308.518 |
| BAG MOISTURE BARR MTL IN 19"X9" | D30919-ND | D30919 |
| BAG MOISTURE BARR MTL IN 20"X10" | D371020-ND | D371020 |
| BAG MOISTURE BARR MTL IN 20"X12" | SCP610-ND | D301220 |
| BAG MOISTURE BARR MTL IN 20"X22" | D302220-ND | D302220 |
| BAG MOISTURE BARR MTL IN 20"X7" | SCP630-ND | D37720 |
| BAG MOISTURE BARR MTL IN 21"X16" | SCP611-ND | D301621 |
| BAG MOISTURE BARR MTL IN 21"X8" | D30821-ND | D30821 |
| BAG MOISTURE BARR MTL IN 24"X12" | D301224-ND | D301224 |
| BAG MOISTURE BARR MTL IN 24"X16" | D371624-ND | D371624 |
| BAG MOISTURE BARR MTL IN 24"X18" | SCP620-ND | D341824 |
| BAG MOISTURE BARR MTL IN 24"X18" | SCP628-ND | D371824 |
| BAG MOISTURE BARR MTL IN 24"X20" | SCP613-ND | D302024 |
| BAG MOISTURE BARR MTL IN 24"X24" | SCP621-ND | D342424 |
| BAG MOISTURE BARR MTL IN 24"X6" | D34624-ND | D34624 |
| BAG MOISTURE BARR MTL IN 25"X6" | D30625-ND | D30625 |
| BAG MOISTURE BARR MTL IN 25"X6" | SCP629-ND | D37625 |
| BAG MOISTURE BARR MTL IN 26"X20" | D302026-ND | D302026 |
| BAG MOISTURE BARR MTL IN 26"X23" | D342326-ND | D342326 |
| BAG MOISTURE BARR MTL IN 28"X17" | D301728-ND | D301728 |
| BAG MOISTURE BARR MTL IN 29"X7" | SCP616-ND | D30729 |
| BAG MOISTURE BARR MTL IN 30"X15" | D341530-ND | D341530 |
| BAG MOISTURE BARR MTL IN 30"X21" | D302130-ND | D302130 |
| BAG MOISTURE BARR MTL IN 30"X26" | SCP614-ND | D302630 |
| BAG MOISTURE BARR MTL IN 30"X30" | D343030-ND | D343030 |
| BAG MOISTURE BARR MTL IN 30"X4" | D30430-ND | D30430 |
| BAG MOISTURE BARR MTL IN 30"X8" | SCP617-ND | D30830 |
| BAG MOISTURE BARR MTL IN 32"X20" | D302032-ND | D302032 |
| BAG MOISTURE BARR MTL IN 36"X16" | D301636-ND | D301636 |
| BAG MOISTURE BARR MTL IN 36"X24" | SCP622-ND | D342436 |
| BAG MOISTURE BARR MTL IN 7"X8.5" | SCP623-ND | D348.57 |
| BAG MOISTURE BARR MTL IN 8"X12" | D37128-ND | D37128 |
| BAG MOISTURE BARRIER 4X6" 1=1EA | 33746-ND | 33746 |
| BAG MOISTURE BARRIER 6X10" 1=1EA | 337610-ND | 337610 |
| BAG STAT SHD METALIN 4"X26"1=1EA | 100426-ND | 100426 |
| BAG STAT SHLD METALOUT 8X8"1=1EA | SCP558-ND | 15088 |
| BAG STAT SHLD MTLIN 12"X9" 1=1EA | SCP597-ND | 1300912 |
| BAG STAT SHLD MTLIN 14"X10"1=1EA | SCP600-ND | 13001014 |
| BAG STAT SHLD MTLIN 24"X10"1=1EA | SCP601-ND | 13001024 |
| BAG STAT SHLD MTLIN 8"X5" 1=1EA | SCP592-ND | 130058 |
| BAG STAT SHLD MTLOUT 10X28"1=1EA | SCP560-ND | 1501028 |
| BAG STAT SHLD MTLOUT 12X15"1=1EA | SCP566-ND | 150Z1215 |
| BAG STAT SHLD MTLOUT 18X18"1=1EA | SCP567-ND | 150Z1818 |
| BAG STAT SHLD MTLOUT 20X22"1=1EA | SCP557-ND | 150Z2022 |
| BAG STAT SHLD MTLOUT 20X30"1=1EA | SCP565-ND | 3002030 |
| BAG STAT SHLD MTLOUT 24X30"1=1EA | SCP562-ND | 1502430 |
| BAG STAT SHLD MTLOUT 24X36"1=1EA | SCP563-ND | 1502436 |
| BAG STAT SHLD MTLOUT 8X10" 1=1EA | SCP559-ND | 150810 |
| BAG STAT SHLD MTLOUT 8X12" 1=1EA | SCP568-ND | 150Z812 |
| BAG STATIC CUSH METAL 18"X12" | 2301218-ND | 2301218 |
| BAG STATIC CUSH METAL IN 11"X12" | SCP573-ND | 2301211 |
| BAG STATIC CUSH METAL IN 15"X14" | SCP574-ND | 2301415 |
| BAG STATIC CUSH METAL IN 7"X6" | SCP575-ND | 23067 |
| BAG STATIC CUSH METAL IN 7"X8" | SCP571-ND | 23087 |
| BAG STATIC METAL-IN 12X18" 1=1EA | SCP317-ND | 1001218 |
| BAG STATIC METAL-IN 14X18" 1=1EA | SCP472-ND | 1001418 |
| BAG STATIC METAL-IN 20X24" 1=1EA | SCP465-ND | 1002024 |
| BAG STATIC METAL-IN 2X4" 1=1EA | SCP467-ND | 10024 |
| BAG STATIC METAL-IN 3X5" 1=1EA | SCP310-ND | 10035 |
| BAG STATIC METAL-IN 4X24" 1=1EA | SCP473-ND | 100424 |
| BAG STATIC METAL-IN 4X6" 1=1EA | SCP313-ND | 10046 |
| BAG STATIC METAL-IN 5X8" 1=1EA | SCP312-ND | 10058 |
| BAG STATIC METAL-IN 6X10" 1=1EA | SCP316-ND | 100610 |
| BAG STATIC METAL-IN 8X12" 1=1EA | SCP307-ND | 100812 |
| BAG STATIC METL-IN 8X10" 1=1EA | SCP309-ND | 100810 |
| BAG STATIC SHIELD 10X26" 1=1EA | 2111026-ND | 2111026 |
| BAG STATIC SHIELD 10X30" 1=1EA | 2101030-ND | 2101030 |
| BAG STATIC SHIELD 12X15" 1=1EA | 2111215-ND | 2111215 |
| BAG STATIC SHIELD 14X14" 100PK | 1911414-ND | 1911414 |
| BAG STATIC SHIELD 14X16" 100PK | 1911416-ND | 1911416 |
| BAG STATIC SHIELD 18X24" 1=1EA | 2111824-ND | 2111824 |
| BAG STATIC SHIELD 20X30" 1=1EA | 1912030-ND | 1912030 |
| BAG STATIC SHIELD 24X24" 1=1EA | 2102424-ND | 2102424 |
| BAG STATIC SHIELD 24X30" 1=1EA | 2102430-ND | 2102430 |
| BAG STATIC SHIELD 24X34" 1=1EA | 2102434-ND | 2102434 |
| BAG STATIC SHIELD 24X36" 1=1EA | 2102436-ND | 2102436 |
| BAG STATIC SHIELD 2X6" 100PK | 21026SCS-ND | 21026 |
| BAG STATIC SHLD MTL IN 1"X3.25" | 1003.251-ND | 1003.251 |
| BAG STATIC SHLD MTL IN 1"X6.5" | 1006.510-ND | 1006.51 |
| BAG STATIC SHLD MTL IN 11"X3" | 100311SCS-ND | 100311 |
| BAG STATIC SHLD MTL IN 11"X6" | 300611-ND | 300611 |
| BAG STATIC SHLD MTL IN 13"X8" | 100813-ND | 100813 |
| BAG STATIC SHLD MTL IN 14"X11" | 3001114-ND | 3001114 |
| BAG STATIC SHLD MTL IN 15"X27" | 1002715-ND | 1002715 |
| BAG STATIC SHLD MTL IN 15.5"X15" | 3001515.5-ND | 3001515.5 |
| BAG STATIC SHLD MTL IN 16"X11" | 1301116-ND | 1301116 |
| BAG STATIC SHLD MTL IN 16"X4" | 300416-ND | 300416 |
| BAG STATIC SHLD MTL IN 17"X30" | 1003017-ND | 1003017 |
| BAG STATIC SHLD MTL IN 18"X14" | 1911418-ND | 1911418 |
| BAG STATIC SHLD MTL IN 18"X39" | 1003918-ND | 1003918 |
| BAG STATIC SHLD MTL IN 18"X5" | 300518-ND | 300518 |
| BAG STATIC SHLD MTL IN 18"X7" | 100718-ND | 100718 |
| BAG STATIC SHLD MTL IN 2"X12" | 300122SCS-ND | 300122 |
| BAG STATIC SHLD MTL IN 20"X17" | 1001720-ND | 1001720 |
| BAG STATIC SHLD MTL IN 20"X24" | 1002420-ND | 1002420 |
| BAG STATIC SHLD MTL IN 20"X8" | 300820-ND | 300820 |
| BAG STATIC SHLD MTL IN 22"X16" | 3001622-ND | 3001622 |
| BAG STATIC SHLD MTL IN 24"X10" | 1301024-ND | 1301024 |
| BAG STATIC SHLD MTL IN 24"X14" | 1001424-ND | 1001424 |
| BAG STATIC SHLD MTL IN 24"X21" | 1002124-ND | 1002124 |
| BAG STATIC SHLD MTL IN 24"X36" | 1003624-ND | 1003624 |
| BAG STATIC SHLD MTL IN 25"X24" | 1002425-ND | 1002425 |
| BAG STATIC SHLD MTL IN 26"X26" | 3002626-ND | 3002626 |
| BAG STATIC SHLD MTL IN 26"X32" | 1003226-ND | 1003226 |
| BAG STATIC SHLD MTL IN 26"X4.5" | 1004.526-ND | 1004.526 |
| BAG STATIC SHLD MTL IN 26"X8" | 100826-ND | 100826 |
| BAG STATIC SHLD MTL IN 27"X25" | 1002527-ND | 1002527 |
| BAG STATIC SHLD MTL IN 28X20.25" | 10020.2528-ND | 10020.2528 |
| BAG STATIC SHLD MTL IN 29"X29" | 3002929-ND | 3002929 |
| BAG STATIC SHLD MTL IN 30"X15" | 3001530-ND | 3001530 |
| BAG STATIC SHLD MTL IN 30"X18" | 3001830-ND | 3001830 |
| BAG STATIC SHLD MTL IN 30"X8" | 300830-ND | 300830 |
| BAG STATIC SHLD MTL IN 33"X24" | 3002433-ND | 3002433 |
| BAG STATIC SHLD MTL IN 34"X8" | 100834-ND | 100834 |
| BAG STATIC SHLD MTL IN 35"X6" | 100635-ND | 100635 |
| BAG STATIC SHLD MTL IN 36"X6" | 100636-ND | 100636 |
| BAG STATIC SHLD MTL IN 5"X2" | 10025-ND | 10025 |
| BAG STATIC SHLD MTL IN 5"X4" | 30045SCS-ND | 30045 |
| BAG STATIC SHLD MTL IN 6"X5" | 30056SCS-ND | 30056 |
| BAG STATIC SHLD MTL IN 7"X2.25" | 1002.257-ND | 1002.257 |
| BAG STATIC SHLD MTL IN 7"X3" | 10037SCS-ND | 10037 |
| BAG STATIC SHLD MTL IN 7"X6" | 10067-ND | 10067 |
| BAG STATIC SHLD MTL IN 7.5"X5.5" | 3005.57.5-ND | 3005.57.5 |
| BAG STATIC SHLD MTL IN 8"X2.5" | 1002.58-ND | 1002.58 |
| BAG STATIC SHLD MTL IN 8"X9" | 10098-ND | 10098 |
| BAG STATIC SHLD MTL IN 9"X12" | 100129-ND | 100129 |
| BAG STATIC SHLD MTL IN 9"X3.25" | 1003.259-ND | 1003.259 |
| BAG STATIC SHLD MTL OUT 11"X8" | 230811-ND | 230811 |
| BAG STATIC SHLD MTL OUT 15"X18" | 2301815-ND | 2301815 |
| BAG STATIC SHLD MTL OUT 16"X10" | 1501016-ND | 1501016 |
| BAG STATIC SHLD MTL OUT 17X21.5" | 15021.517-ND | 15021.517 |
| BAG STATIC SHLD MTL OUT 18"X7" | 150718-ND | 150718 |
| BAG STATIC SHLD MTL OUT 2"X9.5" | 1509.520-ND | 1509.52 |
| BAG STATIC SHLD MTL OUT 20"X10" | 1501020-ND | 1501020 |
| BAG STATIC SHLD MTL OUT 20"X18" | 1501820-ND | 1501820 |
| BAG STATIC SHLD MTL OUT 20"X2.5" | 1502.520-ND | 1502.52 |
| BAG STATIC SHLD MTL OUT 20"X20" | 1502020-ND | 1502020 |
| BAG STATIC SHLD MTL OUT 22"X4" | 150422-ND | 150422 |
| BAG STATIC SHLD MTL OUT 23"X18" | 2301823-ND | 2301823 |
| BAG STATIC SHLD MTL OUT 28"X19" | 1501928-ND | 1501928 |
| BAG STATIC SHLD MTL OUT 33"X32" | 1503233-ND | 1503233 |
| BAG STATIC SHLD MTLIN 8"X6"1=1EA | SCP593-ND | 130068 |
| BAG STATIC ZIP-TOP 10X12" 1=1EA | SCP308-ND | 3001012 |
| BAG STATIC ZIP-TOP 10X14" 1=1EA | SCP299-ND | 3001014 |
| BAG STATIC ZIP-TOP 12X18" 1=1EA | SCP468-ND | 3001218 |
| BAG STATIC ZIP-TOP 15X18" 1=1EA | SCP469-ND | 3001518 |
| BAG STATIC ZIP-TOP 18X18" 1=1EA | SCP433-ND | 3001818 |
| BAG STATIC ZIP-TOP 18X24" 1=1EA | SCP470-ND | 3001824 |
| BAG STATIC ZIP-TOP 4X24" 1=1EA | SCP462-ND | 300424 |
| BAG STATIC ZIP-TOP 4X6" 1=1EA | SCP314-ND | 30046 |
| BAG STATIC ZIP-TOP 5X8" 1=1EA | SCP311-ND | 30058 |
| BAG STATIC ZIP-TOP 6X10" 1=1EA | SCP474-ND | 300610 |
| BAG STATIC ZIP-TOP 8X10" 1=1EA | SCP315-ND | 300810 |
| BAG STATIC ZIP-TOP 8X12" 1=1EA | SCP475-ND | 300812 |
| BAG STATIC/MOISTURE 10X12" 1=1EA | SCP340-ND | 7001012 |
| BAG STATIC/MOISTURE 10X20" 1=1EA | SCP471-ND | D301020 |
| BAG STATIC/MOISTURE 10X30" 1=1EA | SCP344-ND | 7001030 |
| BAG STATIC/MOISTURE 10X30" 1=1EA | SCP464-ND | D301030 |
| BAG STATIC/MOISTURE 12X16" 1=1EA | SCP341-ND | 7001216 |
| BAG STATIC/MOISTURE 15X18" 1=1EA | SCP342-ND | 7001518 |
| BAG STATIC/MOISTURE 16X18" 1=1EA | SCP343-ND | 7001618 |
| BAG STATIC/MOISTURE 16X18" 1=1EA | SCP466-ND | D301618 |
| BAG STATIC/MOISTURE 18X24" 1=1EA | SCP345-ND | 7001824 |
| BAG STATIC/MOISTURE 6X10" 1=1EA | SCP339-ND | 700610 |
| BAG TONER CARTRIDGE MTL IN 18X11 | 5001118-ND | 5001118 |
| CONDUCTIVE BAG NONE 6"X4" | 20044X6-ND | 2004 4X6 |
| ESD SHIELD BAG 11X12" CUSH 1=1EA | SCP268-ND | 2121211 |
| ESD SHIELD BAG 14X15" CUSH 1=1EA | SCP269-ND | 2121415 |
| ESD SHIELD BAG 6X7" CUSH 1=1EA | SCP270-ND | 21267 |
| ESD SHIELD BAG 8X11" CUSH 1=1EA | SCP271-ND | 212811 |
| ESD SHIELD BAG 8X7" CUSH 1=1EA | SCP272-ND | 21287 |
| FILM COND 4 MIL 3’ X 150’ | SCP429-ND | 1704 36X150 |
| FILM COND 4 MIL 3’ X 1500’ | 176436X1500-ND | 1764 36X1500 |
| FILM COND 4 MIL 4.5’ X 150’ | 170454X150-ND | 1704 54X150 |
| FILM COND 4 MIL 6’ X 150’ | 170472X150-ND | 1704 72X150 |
| FILM COND 6 MIL 3’ X 150’ | 170636X150-ND | 1706 36X150 |
| FILM COND 6 MIL 6’ X 150’ | 170672X150-ND | 1706 72X150 |
| FILM COND 8 MIL 3’ X 150’ | 170836X150-ND | 1708 36X150 |
| FILM COND 8 MIL 4.5’ X 150’ | 170854X150-ND | 1708 54X150 |
| FILM COND 8 MIL 6’ X 150’ | 170872X150-ND | 1708 72X150 |
| FILM STATIC SHIELD 48"X50’ | SCP780-ND | 817R 48X50 |
| FILM STATIC SHIELD PCL100 CLEAN | 16-PCL100R36X100-ND | PCL100R 36X100 |
| FILM STATIC SHIELD PCL100 CLEAN | 16-PCL100R36X500-ND | PCL100R 36X500 |
| MOISTURE BARR BAG 16 X 18" 1=1EA | SCP463-ND | D271618 |
| MOISTURE BARRIER BAG 1=100 | 1569-817I0507-ND | 817I0507 |
| MOISTURE BARRIER BAG, 81705 SERI | 1569-817I0305-ND | 817I0305 |
| SHIELD BAG 10X12" METAL-IN | SCP460-ND | 1901012 |
| SHIELD BAG 10X12" MTL-OUT 1=1EA | SCP477-ND | 2101012 |
| SHIELD BAG 10X12" MTL-OUT 100PK | 2111012-ND | 2111012 |
| SHIELD BAG 10X14" MTL-OUT 100PK | 2101014-ND | 2101014 |
| SHIELD BAG 10X14" MTL-OUT 100PK | 2111014-ND | 2111014 |
| SHIELD BAG 10X24" METAL-IN 100PK | 1901024-ND | 1901024 |
| SHIELD BAG 10X24" MTL-OUT 1=1EA | 2101024-ND | 2101024 |
| SHIELD BAG 10X26" METAL-IN 1=1EA | 1901026-ND | 1901026 |
| SHIELD BAG 10X30" METAL-IN 1=1EA | 1901030-ND | 1901030 |
| SHIELD BAG 11X15" METAL-IN 1=1EA | SCP454-ND | 1901115 |
| SHIELD BAG 11X15" METAL-IN 100PK | 1911115-ND | 1911115 |
| SHIELD BAG 11X15" MTL-OUT 100PK | 2101115-ND | 2101115 |
| SHIELD BAG 11X15" MTL-OUT 100PK | 2111115-ND | 2111115 |
| SHIELD BAG 12X12" METAL-IN 100PK | 1911212-ND | 1911212 |
| SHIELD BAG 12X16" MTL-OUT 100PK | 2101216-ND | 2101216 |
| SHIELD BAG 12X18" METAL-IN 1=1EA | SCP459-ND | 1901218 |
| SHIELD BAG 12X18" METAL-IN 100PK | 1911218-ND | 1911218 |
| SHIELD BAG 12X18" MTL-OUT 100PK | 2101218-ND | 2101218 |
| SHIELD BAG 14X18" METAL-IN 100PK | 1901418-ND | 1901418 |
| SHIELD BAG 14X18" MTL-OUT 100PK | 2101418-ND | 2101418 |
| SHIELD BAG 15X18" METAL-IN 1=1EA | SCP455-ND | 1901518 |
| SHIELD BAG 15X18" MTL-OUT 100PK | 2101518-ND | 2101518 |
| SHIELD BAG 16X24" METAL-IN 100PK | 1901624-ND | 1901624 |
| SHIELD BAG 16X24" MTL-OUT 100PK | 2101624-ND | 2101624 |
| SHIELD BAG 18X18" METAL-IN | SCP453-ND | 1901818 |
| SHIELD BAG 18X18" METAL-IN 100PK | 1911818-ND | 1911818 |
| SHIELD BAG 18X18" MTL-OUT 100PK | 2101818-ND | 2101818 |
| SHIELD BAG 18X24" METAL-IN 100PK | 1901824-ND | 1901824 |
| SHIELD BAG 18X24" MTL-OUT 100PK | 2101824-ND | 2101824 |
| SHIELD BAG 3X5" METAL-OUT 100PK | 21135-ND | 21135 |
| SHIELD BAG 4X26" METAL IN 1=1EA | 190426-ND | 190426 |
| SHIELD BAG 4X26" METAL-OUT 1=1EA | 210426-ND | 210426 |
| SHIELD BAG 4X30" METAL-OUT 1=1EA | 210430-ND | 210430 |
| SHIELD BAG 4X4" METAL-IN 1=1EA | SCP672-ND | 19144 |
| SHIELD BAG 4X4" METAL-IN 100PK | 19044-ND | 19044 |
| SHIELD BAG 4X4" METAL-OUT 100PK | 21044-ND | 21044 |
| SHIELD BAG 4X4" METAL-OUT 100PK | 21144-ND | 21144 |
| SHIELD BAG 4X6" METAL-OUT | SCP457-ND | 21146 |
| SHIELD BAG 5X10" METAL-IN 100PK | 190510-ND | 190510 |
| SHIELD BAG 5X8" METAL-OUT 100PK | 21158-ND | 21158 |
| SHIELD BAG 6X10" MTL-OUT 100PK | 211610-ND | 211610 |
| SHIELD BAG 6X8" METAL-IN | SCP458-ND | 19068 |
| SHIELD BAG 6X8" METAL-IN 100PK | 19168-ND | 19168 |
| SHIELD BAG 6X8" METAL-OUT 100PK | 21068-ND | 21068 |
| SHIELD BAG 6X8" METAL-OUT 100PK | 21168-ND | 21168 |
| SHIELD BAG 7X15" METAL-IN 100PK | 190715-ND | 190715 |
| SHIELD BAG 8X10" MTL-OUT 1=1EA | SCP456-ND | 211810 |
| SHIELD BAG 8X12" METAL-IN 100PK | 191812-ND | 191812 |
| SHIELD BAG 8X12" METAL-OUT 100PK | 210812-ND | 210812 |
| SHIELD BAG 8X12" MTL-OUT 100PK | 211812-ND | 211812 |
| SHIELD BAG 8X8" METAL-IN 100PK | 19088-ND | 19088 |
| SHIELD BAG 8X8" METAL-OUT 100PK | 21088-ND | 21088 |
| SHIELDING BAG 10X14 METAL-IN | SCP161-ND | 1901014 |
| SHIELDING BAG 12X16 METAL-IN | SCP162-ND | 1901216 |
| SHIELDING BAG 3X5 METAL-IN | SCP153-ND | 19035 |
| SHIELDING BAG 4X24 METALIN 1=1EA | SCP155-ND | 190424 |
| SHIELDING BAG 4X30 METALIN 1=1EA | SCP156-ND | 190430 |
| SHIELDING BAG 4X6 METAL-IN | SCP154-ND | 19046 |
| SHIELDING BAG 5X8 METALIN 1=1EA | SCP157-ND | 19058 |
| SHIELDING BAG 6X10 METALIN 1=1EA | SCP158-ND | 190610 |
| SHIELDING BAG 8X10 METALIN 1=1EA | SCP159-ND | 190810 |
| SHIELDING BAG 8X12 METALIN 1=1EA | SCP160-ND | 190812 |
| STAT BAG MET-IN 10"X10"ZIP 1=1EA | SCP536-ND | 3001010 |
| STAT BAG MET-IN 10"X24"ZIP 1=1EA | SCP756-ND | 3001024 |
| STAT BAG MET-IN 10"X26"OPN 1=1EA | 1001026-ND | 1001026 |
| STAT BAG MET-IN 14"X20"OPN 1=1EA | 1001420-ND | 1001420 |
| STAT BAG MET-IN 20"X20"OPN 1=1EA | 1002020-ND | 1002020 |
| STAT BAG MET-IN 20"X24"ZIP 1=1EA | 3002024-ND | 3002024 |
| STAT BAG MET-IN 22"X24"OPN 1=1EA | 1002224-ND | 1002224 |
| STAT BAG MET-IN 6"X9" OPEN 1=1EA | 10069-ND | 10069 |
| STAT BAG MET-IN 7"X16" OPN 1=1EA | 100716-ND | 100716 |
| STAT BAG MET-IN 8"X14"OPEN 1=1EA | 100814-ND | 100814 |
| STAT BAG MET-OUT 4"X6" ZIP 1=1EA | 150Z46-ND | 150Z46 |
| STAT BAG MET-OUT 8"X10"ZIP 1=1EA | 150Z810-ND | 150Z810 |
| STAT SHIELD WRAP MTL IN 36"X250’ | SCP710-ND | 817R 36X250 |
| STAT SHIELD WRAP MTL IN 36"X50’ | SCP711-ND | 817R 36X50 |
| STAT SHIELD WRAP MTL IN 48"X250’ | SCP712-ND | 817R 48X250 |
| STAT SHLD BAG 1000 SERIES 1=1EA | SCP572-ND | 100310 |
| STAT SHLD BAG MTL IN 10X8 1=1EA | SCP698-ND | 817810 |
| STAT SHLD BAG MTL IN 12X12 1=1EA | SCP702-ND | 8171212 |
| STAT SHLD BAG MTL IN 12X18 1=1EA | SCP704-ND | 8171218 |
| STAT SHLD BAG MTL IN 15X18 1=1EA | SCP705-ND | 8171518 |
| STAT SHLD BAG MTL IN 18X20 1=1EA | SCP707-ND | 8171820 |
| STAT SHLD BAG MTL IN 18X24 1=1EA | SCP708-ND | 8171824 |
| STAT SHLD BAG MTL IN 24X30 1=1EA | SCP709-ND | 8172430 |
| STAT SHLD BAG MTL IN 3X5 1=1EA | SCP693-ND | 81735 |
| STAT SHLD BAG MTL IN 3X5 1=1EA | SCP713-ND | 817Z35 |
| STAT SHLD BAG MTL IN 4X6 1=1EA | SCP714-ND | 817Z46 |
| STAT SHLD BAG MTL IN 5X8 1=1EA | SCP695-ND | 81758 |
| STAT SHLD BAG MTL IN 6X8 1=1EA | SCP696-ND | 81768 |
| STAT SHLD BAG MTL IN 8 X10 1=1EA | SCP715-ND | 817Z810 |
| STAT SHLD BAG MTL IN 8X12 1=1EA | SCP699-ND | 817812 |
| STAT SHLD BAG MTL IN 8X8 1=1EA | SCP697-ND | 81788 |
| STAT SHLD BAG MTL IN 9X12 1=1EA | SCP700-ND | 817912 |
| STATC BAG MET-IN 4"X8" ZIP 1=1EA | 30048-ND | 30048 |
| STATC BAG MET-OUT 6"X8"ZIP 1=1EA | 150Z68-ND | 150Z68 |
| STATIC BAG MET-OUT 10"X12" 1=1EA | SCP478-ND | 1501012 |
| STATIC BAG MET-OUT 11"X15" 1=1EA | 1501115-ND | 1501115 |
| STATIC BAG MET-OUT 12"X18" 1=1EA | 1501218-ND | 1501218 |
| STATIC BAG MET-OUT 15"X18" 1=1EA | 1501518-ND | 1501518 |
| STATIC BAG MET-OUT 16"X24" 1=1EA | 1501624-ND | 1501624 |
| STATIC BAG MET-OUT 18"X24" 1=1EA | 1501824-ND | 1501824 |
| STATIC BAG MET-OUT 3"X5" 1=1EA | 15035-ND | 15035 |
| STATIC BAG MET-OUT 4"X6" 1=1EA | 15046-ND | 15046 |
| STATIC BAG MET-OUT 6"X10" 1=1EA | SCP476-ND | 150610 |
| STATIC BAG MET-OUT 8"X12 1=1EA | 150812-ND | 150812 |
| STATIC SHIEL BAG ZIP 10X12 1=1EA | SCP808-ND | 817Z1012 |
| STATIC SHIEL BAG ZIP 10X18 1=1EA | SCP810-ND | 817Z1018 |
| STATIC SHIEL BAG ZIP 12X12 1=1EA | SCP811-ND | 817Z1212 |
| STATIC SHIELD BAG | 230614-ND | 230614 |
| STATIC SHIELD BAG 10X14 1=1EA | SCP782-ND | 8171014 |
| STATIC SHIELD BAG 10X15 1=1EA | SCP783-ND | 8171015 |
| STATIC SHIELD BAG 10X24 1=1EA | SCP784-ND | 8171024 |
| STATIC SHIELD BAG 10X26 1=1EA | SCP785-ND | 8171026 |
| STATIC SHIELD BAG 12X10 1=1EA | SCP786-ND | 8171210 |
| STATIC SHIELD BAG 12X14 1=1EA | SCP787-ND | 8171214 |
| STATIC SHIELD BAG 12X24 1=1EA | SCP788-ND | 8171224 |
| STATIC SHIELD BAG 14X18 1=1EA | SCP789-ND | 8171418 |
| STATIC SHIELD BAG 16X12 1=1EA | SCP781-ND | 8171612 |
| STATIC SHIELD BAG 18X14 | SCP790-ND | 8171814 |
| STATIC SHIELD BAG 18X18 1=1EA | SCP791-ND | 8171818 |
| STATIC SHIELD BAG 18X26 1=1EA | SCP792-ND | 8171826 |
| STATIC SHIELD BAG 20X24 1=1EA | SCP793-ND | 8172024 |
| STATIC SHIELD BAG 2110R SERIES M | 1569-2111218-ND | 2111218 |
| STATIC SHIELD BAG 4X14 1=1EA | SCP795-ND | 817414 |
| STATIC SHIELD BAG 4X26 | SCP796-ND | 817426 |
| STATIC SHIELD BAG 4X30 1=1EA | SCP797-ND | 817430 |
| STATIC SHIELD BAG 4X4 1=1EA | SCP798-ND | 81744 |
| STATIC SHIELD BAG 4X6 1=1EA | SCP799-ND | 81746 |
| STATIC SHIELD BAG 5X28 1=1EA | SCP800-ND | 817528 |
| STATIC SHIELD BAG 5X5 1=1EA | SCP801-ND | 81755 |
| STATIC SHIELD BAG 5X7 1=1EA | SCP802-ND | 81757 |
| STATIC SHIELD BAG 6X10 1=1EA | SCP803-ND | 817610 |
| STATIC SHIELD BAG 6X21 | SCP804-ND | 817621 |
| STATIC SHIELD BAG 6X26 1=1EA | SCP805-ND | 817626 |
| STATIC SHIELD BAG 8X18 1=1EA | SCP806-ND | 817818 |
| STATIC SHIELD BAG 8X5 1=1EA | SCP807-ND | 81785 |
| STATIC SHIELD BAG MTL IN 10"X12" | SCP701-ND | 8171012 |
| STATIC SHIELD BAG MTL IN 12"X16" | SCP703-ND | 8171216 |
| STATIC SHIELD BAG MTL IN 16"X24" | SCP706-ND | 8171624 |
| STATIC SHIELD BAG MTL IN 4"X8" | SCP694-ND | 81748 |
| STATIC SHIELD BAG ZIP 10X14 | SCP809-ND | 817Z1014 |
| STATIC SHIELD BAG ZIP 2X3 1=1EA | SCP814-ND | 817Z23 |
| STATIC SHIELD BAG ZIP 3X3 1=1EA | SCP815-ND | 817Z33 |
| STATIC SHIELD BAG ZIP 6X4 1=1EA | SCP818-ND | 817Z64 |
| STATIC SHIELD BAG ZIP 6X8 1=1EA | SCP819-ND | 817Z68 |
| STATIC SHIELD BAG, 1910 SERIES M | 1569-19123-ND | 19123 |
| STATIC SHIELD BAG, 1910 SERIES M | 1569-19133-ND | 19133 |
| STATIC SHIELD BAG, PCL100 CLEAN | 16-PCL1001012-ND | PCL1001012 |
| STATIC SHIELD BAG, PCL100 CLEAN | 16-PCL1001115-ND | PCL1001115 |
| STATIC SHIELD BAG, PCL100 CLEAN | 16-PCL1001218-ND | PCL1001218 |
| STATIC SHIELD BAG, PCL100 CLEAN | 16-PCL1001818-ND | PCL1001818 |
| STATIC SHIELD BAG, PCL100 CLEAN | 16-PCL1002024-ND | PCL1002024 |
| STATIC SHIELD BAG, PCL100 CLEAN | 16-PCL10035-ND | PCL10035 |
| STATIC SHIELD BAG, PCL100 CLEAN | 16-PCL10046-ND | PCL10046 |
| STATIC SHIELD BAG, PCL100 CLEAN | 16-PCL100610-ND | PCL100610 |
| STATIC SHIELD BAG, PCL100 CLEAN | 16-PCL100810-ND | PCL100810 |
| STATIC SHIELD BAG, PCL100 CLEAN | 16-PCL100812-ND | PCL100812 |
| STATIC SHIELD BAG,81705 SERIES M | 1569-8172.2520-ND | 8172.252 |
| STATIC SHIELDING BAG IN 11"X16" | 13001116-ND | 13001116 |
| STATIC SHIELDING BAG IN 2"X6" | 130026-ND | 130026 |
| STATIC SHIELDING BAG IN 3"X11" | 1300311-ND | 1300311 |
| STATIC SHIELDING BAG IN 3"X12" | 100312-ND | 100312 |
| STATIC SHIELDING BAG IN 3"X3" | 10033-ND | 10033 |
| STATIC SHIELDING BAG IN 4"X12" | 300412-ND | 300412 |
| STATIC SHIELDING BAG IN 6"X6" | 10066-ND | 10066 |
| STATIC SHIELDING BAG IN 8"X16" | 100816-ND | 100816 |
| TUBING COND 4 MIL 1’ X 500’ | 172412X500-ND | 1724 12X500 |
| TUBING COND 4 MIL 5’ X 500’ | 17245X500-ND | 1724 5X500 |
| VELOSTAT CONDUCT BAG 10X12"1=1EA | 200410X12-ND | 2004 10X12 |
| VELOSTAT CONDUCT BAG 12X16" 100P | 200412X16-ND | 2004 12X16 |
| VELOSTAT CONDUCT BAG 15X18"1=1EA | 200415X18-ND | 2004 15X18 |
| VELOSTAT CONDUCT BAG 5X8" 1=1EA | 20045X8-ND | 2004 5X8 |
| VELOSTAT CONDUCT BAG 6X10" 1=1EA | 20046X10-ND | 2004 6X10 |
| VELOSTAT CONDUCT BAG 8X12" 1=1EA | 20048X12-ND | 2004 8X12 |
| WRAP SHIELD CUSHIONED 2X125 FT | SCP432-ND | 2126R 24X125 |
| WRAP SHIELD CUSHIONED 4X125 FT | 2126R48X125-ND | 2126R 48X125 |
| WRAP STATI SHLD MTL OUT 125’X24" | 2300R24X125-ND | 2300R 24X125 |
| WRAP STATI SHLD MTL OUT 125’X48" | 2300R48X125-ND | 2300R 48X125 |
