SL-B8R5C9H2AWW-ND
led grow light using
SL-B8R5C9H2AWW-ND LED Module
would like to use 10 or 12 of these modules
5 or 6 in series using 2 Mean Well HLG-320H-C1400B
is this driver suitable or sugestions
I would not advise using two driver in the same circuit, the driver’s datasheets usually warn not to do this.
Otherwise the current looks fine to the forward voltage set, you just may have to split the difference and use two circuits.
thank you so much for the response
2 independent circuits was the intent
Cheers
