MPN#SM03B-GHS-TB from DigiKey goods , label not have suffix(LF)(SN),
pls provide me the document without suffix also ROHS3 compliant.
Hello keepy.huang,
SM03B-GHS-TB used to have the (LF)(SN) at the end of the part number.
If you check lower on the product page, it will have “Other Names” for this connector, and one of them is SM03B-GHS-TB(LF)(SN). Click here for the Suffix Document, which stated the (LF)(SN) is no longer required for the ordering part number. You can also Click Here for the datasheet.
