Smaller Potentiometer / longer leads bourns or other
3329H-1-104LF part from bourns 100Kohm 10% 0.5W
I need a smaller one or one with longer leads meeting the same specs or close.
any thoughts to use
Hello ltosches - welcome to the Forum Community. Unfortunately, lead length is not a searchable parameter for us, but these are the options I found that are similar to 3329H-1-104LF, but have longer lead lengths. You’ll need to consult the datasheets for lead length. You can use this link, selecting the size/dimension parameter to select different physical sizes.
