I’m looking for a zero bias Schottky detector diode similar to the Skyworks SMS7630-061, in a 0201 package, for operation at 915 MHz ISM band. The key parameters I need are: Cj < 1 pF, very low forward voltage, and weight under 0.5 mg. Could you recommend current alternatives available in stock?
Greetings,
Currently active RF diode listings in 0201 package can be found here. Those with lower reverse voltage figures seem likely to be of first interest.
