Can you help me find a replacement for this stepper motor please? See attachment
(Fits yamaha invertor/generator carburetor)
Thank you
Daniel DeSmet
Hello Daniel,
Unfortunately, I am unable to locate a direct substitute. The closest device is this Adafruit motor:
Note that this Adafruit motor has 11.25-degree-per-step while the motor you specified has 7.5-degree step. This is unlikely to work for a throttle control. Also, the shaft is also too long although this could be quickly solved with a Dremel.
Please let us know if you were able to source a replacement.
Best Wishes,
Aaron
Thank you for researching this. I agree with your comment, it is for a particular application.
Do you have any advice for another source?
Thank you
Daniel
You might have to go to the OEM as the source. Sometimes it does cost a little more money. Though you would get something that works.
