StrongIRFET™ MOSFET N-CH 200V 100A TO247AC from Infineon replacement options
Please double check for IRF200P223 as StrongIRFET™ MOSFET N-CH 200V 100A TO247AC from Infineon (IRF200 Infineon Technologies | Transistors), if you could use this alternative with very similar attributes from a different manufacturer:
SUG90090E-GE3 of Vishay SiliconixThunderFET® series. We could deliver requests from 1000 – 3000 pieces with approximately 46 weeks leadtime from HONG KONG, China as NCNR order.
If your board layout could be changed, then there’s another option available from stock:
SIR624DP-T1-GE3 as MOSFET N-CH 200V 18.6A PPAK PowerPAK® SO-8 from Vishay Siliconix.
Please review the datasheets to ensure the alternative will work for your application.
