For the Toshiba transistor 2SC2229Y, the following are the nearest I could find, but the specs are not the same, and the body is physically different, so no guarantees that they would work as a replacement in the same circuit:
1S2461 (diode) → BAV19TR (onsemi), DigiKey part BAV19TRCT-ND, DO-35, 120V/200mA – close match on voltage and package.
05Z6.2Y (6.2V zener) → 1N5234C (onsemi), DigiKey part 1N5234C-ND, DO-35, 6.2V ±2%, 500mW – closest match available.
2SC2229Y (NPN transistor) → 2SC2705 (EVVO), DigiKey part 5272-2SC2705-ND, TO-92, 150V/50mA/800mW – close match, collector-base voltage rating is a bit lower (150V vs. 200V).
Please review the datasheets for each of these prior to purchase to confirm they’ll work for your specific application
