Where to find the wire diagram of this ventilator. The spec gives only 4 wire definitions, but there are 8 wires with different colors
BR,
Piet
There will be two sets of wires. One for each fan.
That’s correct, but what are the colors for the second set! first set
black: -
red: +
yellow: 3rd wire
blue: PWM
orange: ?
green: ?
brown: ?
grey: ?
BR,
Piet
PF40561BX-000U-S99_Spec.pdf (590.1 KB)
bleu: PWM
I will check this for you and get back to you with the answer.
Sorry for the delay, here is the spec sheet for the fan. Page 8 has the wiring diagram.
PF40561BX-1000U-S9H.pdf (1.1 MB)
Dear Steven,
Thanks, it works
BR,
Piet
