Wakefield-Vette DS Series (Dual Tubeaxial) Fan Wiring
Wakefield-Vette DS series fans are typically a 4 wire connection as per datasheet, however we will discuss other similar wiring configurations from other fan manufacturers.
Dual tubeaxial fans may actually be an 8-wire fan in which the wiring may not always be listed in the datasheet, since these are less standard product which deploy the use of two single fans in a tandem arrangement to achieve increased static pressure.
By checking the datasheet for products that look suspiciously similar from other brand names, such as the GFB series from Delta Electronics, are able to find an 8-wire color code that may work. Once the fan is wired, assure both blades are spinning in the proper direction in correlation to the impeller design.
GFB series
An alternative 8-wire configuration is from Sanyo Denki San Ace 38 series per datasheet
Additional Resources
Click here for all DC Brushless Fans (BLDC)
Click here for all DigiKey Fans and Fan Accessories
Fan Bearings Basic Overview
Ribbed Vs. Ribless Fan?
CUI Devices omniCOOL™ C, CF, V Series Fan Comparison & Life Expectancy
Fan Bearings & Longevity
Standard Flow, Reverse Flow, & Reversible Air Flow Fans
How to select a Fan Type (Axial, Centrifugal and Blower)
Fan Selection & Application Guide
What makes a Fan noisy
Fan Types
Orion Fan Wire Color Codes and Special Functions
Fan Terminations
Electrical Interfacing, Monitoring, and Control
Fan Features
Suggested Resources for Fan Selection and Application
Fan & System Curves
Fan Noise, Guards, & Filters
Summary
345-DS0402812V2B-BT0-ND
345-DS0605612U2B-BT0-ND
345-DS0603812U2B-BT0-ND
345-DS0803812U2B-BT0-ND
345-DS1203812H2B-BT0-ND
345-DS0405612V2B-BT0-ND
345-DS0805612V2B-BT0-ND
345-DS0402812W2B-BT0-ND
DS0402812V2B-BT0
DS0605612U2B-BT0
DS0603812U2B-BT0
DS0803812U2B-BT0
DS1203812H2B-BT0
DS0405612V2B-BT0
DS0805612V2B-BT0
DS0402812W2B-BT0
red black yellow blue grey gray orange green white brown purple
outlet fan
inlet fan
pwm
f00
1pce
603-GFB0812ES-E-ND
603-GFB0612ES-E-ND
603-GFB0412ES-E-ND
603-GFB0912ES-E-ND
603-1445-ND
603-1617-ND
GFB0412EHS-DF00-ND
603-1019-ND
603-1020-ND
603-1616-ND
603-1042-ND
603-1444-ND
603-1846-ND
603-1062-ND
603-1447-ND
603-1093-ND
603-1175-ND
603-GFB0812DHU-F00-ND
GFB1212VHW-F00-ND
603-1091-ND
603-1092-ND
603-1171-ND
603-1448-ND
603-1194-ND
603-1446-ND
603-1615-ND
603-GFB0912DHU-ND
603-GFB0412EHS-C-ND
603-GFB0912SHG-SP00-ND
603-GFB0412SHS-C-ND
603-GFB0412GHS-C-ND
603-GFB0412EHS-D-ND
603-GFB0912DHU-F00-ND
603-GFB0412VHF-R00-ND
GFB0812ES-E
GFB0612ES-E
GFB0412ES-E
GFB0912ES-E
GFB0412SHS-AF00
GFB0412VHF-F00
GFB0412EHS-DF00
GFB0412SHG-F00
GFB0412EHS-F00
GFB0412SHE-F00
GFB0612HHG
GFB0412GHS-CF00
GFB0412SHS-DF00
GFB0812SHG-F00
GFB0912SHG-F00
GFB1212VHW
GFB1212VHW-TP05
GFB0812DHU-F00
GFB1212VHW-F00
GFB1212VHG
GFB1224SHG
GFB1212VHW-SP02
GFB1224SHG-F00
GFB1248VHW-TP15
GFB0424VHF
GFB0412HF
GFB0912DHU
GFB0412EHS-C
GFB0912SHG-SP00
GFB0412SHS-C
GFB0412GHS-C
GFB0412EHS-D
GFB0912DHU-F00
GFB0412VHF-R00
603-GFB0412ES-E
1688-1533-ND
1688-1534-ND
1688-2113-ND
1688-1390-ND
9GA0312G3001-ND
1688-1535-ND
1688-1389-ND
9GA0312J3001-ND
9GA0312K3001-ND
1688-1640-ND
1688-9GA0312G3D001-ND
9GA0312P3G0011-ND
9GA0312P3J0011-ND
1688-9GA0312K3D001-ND
1688-9GA0312K3D0011-ND
9CRA0312J401-ND
1688-9CRA0312K401-ND
1688-1643-ND
1688-2178-ND
9CRA0312K402-ND
1688-9CRA0312J402-ND
1688-2124-ND
9GV0312E302-ND
9GV0312G302-ND
9GV0312J3D01-ND
1688-1641-ND
1688-1642-ND
1688-1644-ND
9GV0312E3D01-ND
9GV0312E3D011-ND
9GV0312G3D01-ND
9GV0312K3D01-ND
9GV0312G3011-ND
9GV0312H3011-ND
9GV0312K301-ND
9GV0312P3G03-ND
9GV0312P3J031-ND
9GV0312P3K01-ND
9GV0312J302-ND
9GA0312P3G001
9GA0312P3J001
9GA0312P3K0011
9CRA0312P4K03
9GA0312G3001
9GA0312P3K001
9CRA0312P4J03
9GA0312J3001
9GA0312K3001
9GV0312E301
9GA0312G3D001
9GA0312P3G0011
9GA0312P3J0011
9GA0312K3D001
9GA0312K3D0011
9CRA0312J401
9CRA0312K401
9GV0312J3011
9GV0312H301
9CRA0312K402
9CRA0312J402
9GV0312E3011
9GV0312E302
9GV0312G302
9GV0312J3D01
9GV0312G301
9GV0312J301
9GV0312P3J03
9GV0312E3D01
9GV0312E3D011
9GV0312G3D01
9GV0312K3D01
9GV0312G3011
9GV0312H3011
9GV0312K301
9GV0312P3G03
9GV0312P3J031
9GV0312P3K01
9GV0312J302
