I’m testing a T9602 sensor using Controllino MAXI. I hooked up the connections and uploaded the code, the results are:
Humidity measurements respond successfully and accurately.
Temperature readings don’t respond (stuck at -39.77).
I doubted the code, therefore I tried another code and library, same results!
I suspect either the sensor doesn’t send a complete measurement cycle or I’ve got a faulty sensor.
I appreciate your advices and suggestions.
Hello @ScottRaeker, thanks a lot for your response.
I’ve actually used the library you’ve mentioned and got the same result!
Is there a way to check the sensor’s functionality and ensure it actually takes the temperature measurements?
