Ten Tips for Reducing DC-DC Converter EMI
When not implemented properly, DC/DC switching power supplies can significantly degrade your wireless product’s performance. EMI from a switching power supply can reduce your radio’s sensitivity resulting in shorter range and dropped packets. Wurth’s Webinar titled " Learn the Ten Tips for Reducing DC-DC Converter EMI for Wireless", covers below tips and techniques for reducing EMI in your wireless design.
Tip 1 - Use low EMI converters
Tip 2 - Use proper PC board stackup
Tip 3 - Ground return plane must be solid
Tip 4 - Keep converter circuitry on same layer
Tip 5 - Keep converter circuitry close to IC
Tip 6 - Keep converter circuitry close to power input
Tip 7 - The output inductor should be shielded
Tip 8 - Orient the output inductor for low EMI
Tip 9 - Use local shield
Tip 10 - Locate antennas and coax away from DC-DC converters
Check out Learn the Ten Tips for Reducing DC-DC Converter EMI for Wireless for Ken Wyatt’s detailed discussion on tips and techniques you can use to improve your radio’s performance.
Decoupling capacitors near the output to ground also tend to help.
