Tensorflow/ML/IoT Hardware
I just wanted to have your advice about a product design using components from Digikey.
I am trying to put together a small system/board using a microcontroller that could support high calculations such as deep learning implementation taking into consideration the memory too. Could you please guide me to a product with such capabilities in addition to the ability to use a wifi connection for IoT features?
Is there a processor that can support Tensorflow/Tensorflow Lite as a language?
I thank you very much for your help.
Hi @Mounir one of our best option at the moment are these Google based “Coral” accelerators:
https://www.digikey.com/en/products/filter/evaluation-boards-embedded-mcu-dsp/786?s=N4IgTCBcDaIMYHsBOBDANiAugXyA
They also come in stand-alone m.2 slot based devices…
Regards,
Hello @RobertCNelson,
Thank you for your reply. I went through its datasheet, I could not find the information on which programming language it does support.
Is it compatible with Tensorflow Lite? Also, Is there any “reduced” version of it because I only need the processor and Wi-Fi for connectivity only.
Thank you in advance for your help.
Regard,
There are multiple modules with different SBC’s the libraries can be found here:
Here’s all the different devices with this Module:
Regards,
Hi Mounir,
According to the TensorFlow website, the following platforms support TensorFlow Lite and have WiFi capability:
ESP-EYE - Espressif ESP-EYE
1597-102991299-ND - Seeed Wio Terminal: ATSAMD51
Hello @David_1528 @RobertCNelson,
Thank you for your replies. They are very helpful. The proposed options are interesting and fall into my project requirements.
I still have an inquiry about one board in this forum topic; Do you have in your stock the AZ 3166 or any other helpful information regarding it.
I really appreciate your time.
Regards,
Hi @Mounir
17 in stock today:
Seeed has good directions here:
and Microsoft here:
https://docs.microsoft.com/en-us/samples/azure-samples/mxchip-iot-devkit-get-started/sample/
Regards,
Hi @RobertCNelson,
Thank you for the quick reply.
Do you know how the AZ 3166 compares with the previously proposed Google-based “Coral” accelerators by you and the Espressif ESP-EYE and the ATSAMD51 proposed by @David_1528 ?
Thank you in advance.
Regards,
Of those 3, Espressif’s WiFi is more supported in third part applications then RTL8720DN (SAMD51) and finally the AZ3166’s WiFi…
The “Coral”, is a pure AI accelerator…
Regards,
@RobertCNelson and @David_1528,
Thank you very much for your help and time.
Best Regards,
