Terasic USB Blaster
The Datasheet for the USB Blaster does not list a pin for TDI. So which pin should be used. I’m currently assuming its pin 9 which is listed as SDO. But I would like a proper listing for the TDI connection.
What is the part number for the USB Blaster you are looking at?
Terasic P0302
Hi mcconkeyb,
I supplied the pin table from the datasheet. I would also assume 9 but please consider reaching out to support@terasic.com for clarity.
